sluggish after headers
Old Mar 21, 2001 | 05:24 PM
speedlvr's Avatar
I have the custom chip in and have just installed headers but there is no exhaust from the headers back yet. I took it out for a test drive and it was very sluggish. Can running a setup like this make it run sluggishly?
I'm getting dual exhaust on next week.
Old Mar 21, 2001 | 05:51 PM
Tas's Avatar
Tas
ya you are loosing your scavanging effect and the lack of backpressure has pushed your HP band so high that your car is not set up to handle it.
-Tas
'89 Formula WS-6
[soon to have Hooker 1-5/8" 50 state legal headers installed]
305, TBI, auto, 14x3 chrome flat based open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips....
Super GRK_Taz World
EFI & Intake Options
AOL IM: superGRtaz
Old Mar 21, 2001 | 06:43 PM
speedlvr's Avatar
Thanks Tas. I was pretty sure it was the lack of back pressure. Can you explain the scavenging effect?
Old Mar 21, 2001 | 07:22 PM
Tas's Avatar
Tas
Imagine exaust gasses are like a ball going through a tube. Each time the exaust valve opens, a ball comes out. These ***** are tight against the wall of the tube so behind them a vaccume effect is formed, this vaccume effect pulls on the ball behind the first one making it come out faster than it would if it was by itself. By making the tube longer after the headers, there are more pulls on the later ***** by the previous *****. If the tube is short after the headers, there is little if no pull on the ***** behind the first one. This makes the later ***** come out slower than if there was a vaccume type pull(also called a pulse) infront of them. That is my version of the scavaging effect
-Tas
[This message has been edited by Tas (edited March 21, 2001).]
Old Mar 21, 2001 | 09:04 PM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
heres my version.
know how you want cold air going into your car? cuz its thicker and more dense. well..
you want hot air coming out, cuz thin hot air moves faster.
Since you have nothin after the headers, they arent heating up at all either. Along with the problem taz explained. You want to keep the gas inside the header tube hot, so it flows out easier.
thats my version.
Old Mar 21, 2001 | 11:51 PM
speedlvr's Avatar
That's pretty cool how that works. I guess you could also say that a guy with a car that has no exhaust isn't getting his ***** sucked hard enough. And that does suck.
But starting next week, my ***** will get sucked real good.
Old Mar 22, 2001 | 12:09 AM
Tas's Avatar
Tas
DAHAHA mine too. I'm tired of seeing my headers in the box. I want the fricken cat to get here so I can put them on.
Old Mar 22, 2001 | 10:05 AM
snflupigus's Avatar
THATS THE FUNNIEST POSTS IVE EVER SEEN HERE. !!!!!!
BWAAAHAHAHAHAHAHAHAHHH!!!!!!
Old Mar 22, 2001 | 10:10 AM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
are sure it just doesnt sound really loud and therefore you think you should be going faster? Also you have your O2 sensor hooked up right? Make sure there are no leaks as those tend to make performance lackluster. You dont need back pressure.....you need velocity.
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 224/230 duration and .477/.480 lift. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, 3000 stallconverter. Edelbrock TES, 3inch cat, flowmaster with single 2.5 inch exit.
Best time yet to come
12's?? :crossthumbs:
This is a Pic of my car in race trim www.tbns.net/billyjay/camero.jpg
Yes I know how to spell camaro- so dont ask. I didnt make the link
Old Mar 22, 2001 | 02:35 PM
speedlvr's Avatar
<font face="Verdana, Arial" size="2">Originally posted by snflupigus:
</font>
I couldn't pass that one up.
As far as it being loud, that came across my mind at first. But that notion was zapped when I punched it and it still oozed down the road. O2 sensor is new and installed securely.
Old Mar 22, 2001 | 09:19 PM
snflupigus's Avatar
must be the ball sucking thing then.
Old Mar 22, 2001 | 09:31 PM
Aaron91RS's Avatar
Car: RS
Axle/Gears: 9" for the ladies
thats my version.
</font>
Yes make sure the headers get heated up and this will cause the ***** to come out faster. But make sure the headers don't get too hot and start to turn different colors but you still don't have good suction. Otherwise you will end up with blue *****.
Old Mar 22, 2001 | 11:37 PM
speedlvr's Avatar
This has turned out to be quite a "hairy" topic, hasn't it. Two smileys on the legend are appropriate for this topic. >>>
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
sac92transam
Oct 7, 2015 02:31 PM
Bigold4x4
Sep 28, 2015 05:21 PM
