To Install or not to Install...that is the question
Old Mar 26, 2001 | 02:29 AM
CaptainMidway's Avatar
I have a set of 1 3/4" SLP's sitting in my garage asking to be installed!! But I've have mixed feedback on whether the loss of torque would be large or minimal when installing these on a LO3. Some have said yes..others no. I'm itching to install these, but don't want to lose drivability because of them. If that is the case they can wait for the 355 :-) I was just looking for some info to help me decide. BTW I plan on having 3.42's and a SLP take-off posi installed within the next month.
My mods are:
K&N Open Element, MSD 6AL, Taylor wires, 3" Flowmaster w/Cut-out.
Thanks,
CptMidway
1991 RS
A couple of mods.....still slow
Team Hells' A-Holes
Member of SDFB
http://www.SDFB.org
Old Mar 26, 2001 | 06:05 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
INSTALL!!! But be sure you do the y pipe and catback too!
To hell wiwh low end torque, its way overrated! (not like youd lose much at all anyways and the 3.42s will more than make up for that)
expect about a .3-.5 improvement
Old Mar 26, 2001 | 06:45 AM
Andys92RS's Avatar
If it were me, I would wait untill you get your 355 ready to install. If you haven't put headers on a third gen before, it can be a realopain in the *** . Especially when your talking about using 1 3/4 primaries. Remember your going to have a clearance problem with the right side hitting the steering shaft. It can be rectified with a larger engine mount off a truck. But once again. this would be easier to accomplish with the engine out.
If you do pan on putting them on you might want to use an engine hoist and move the motor aroung a bit, the headers will fit in easier. You are going to loose alot of bottom end with that bigoftube though, I think you should stay were your at untill you swap motors.
Hope I was a help.
Old Mar 26, 2001 | 07:14 AM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
I agree what Andy said. You will loose a lot of low end tq and it will be a b*tch to install because of the 1-3/4 primaries. I also heard something about using different size motor mounts to help with clearance when using them size headers. Seems like I saw it over on nethirdgen.org 84ZZ4 I think was talking about it. Anyways, its something I just remembered.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Mar 26, 2001 | 12:09 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
I agree with Pablo. Get them *****-fukaz on there. It'll make a difference that you can feel. Get a 3" cat-back to go with 'em...you won't be sorry.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Mar 26, 2001 | 12:47 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
I'd say why do twice the work? If you're going to put in a 350 engine soon, put the headers in at the same time. Its much easier that way.
And about the clearance problems, it was found you can move the steering column over a tad by loosening the bolts that hold it in place, moving it, then retightening them.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Mar 27, 2001 | 02:53 AM
Hey Kevin, you think replacing my mounts with new ones might help the clearance on the drivers' side?? The thing with the 355 is I dunno how later this year it is going in....anyone want to lend me some money??
Thanks for all the info....keep it coming guys!
CptMidway
1991 RS
Team Hells' A-Holes
Member of SDFB
http://www.SDFB.org
Old Mar 27, 2001 | 12:28 PM
Kevin91Z's Avatar
Replacing the motor mounts helped some people, and others it didnt. My headers went right in.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
redmaroz
Aug 16, 2015 11:40 PM
