no cold start
Old Feb 3, 2007 | 04:04 PM
75lemans's Avatar
Car: 91 rs t top
Engine: 5.0
Transmission: 5 speed
no cold start
hi i have a 1991 rs with i 5.0 5 speed and i live in the cold so in the morning my car is very hard to start and when it does start i have to keep my foot on the gas every one i talked to says its the fuel pump is this true has it happened to any one else
Old Feb 3, 2007 | 08:52 PM
golden's Avatar
Car: '89 Firebird
Engine: 305 TBI (LO3)
Axle/Gears: 10 bolts 2.73
No It's not the fuel pump , if it was the fuel pump , the car wouldn't even start ... Does it have a check engine lighted ?
Old Feb 4, 2007 | 05:46 AM
75lemans's Avatar
Car: 91 rs t top
Engine: 5.0
it did until i took the light out it was for a coolant temp sensor whitch i replaced the lite went off for like an hour then right back on thats why i took the bulb out
Old Feb 4, 2007 | 10:56 AM
Camaro-please?'s Avatar
Car: 88 Camaro Sport Coupe
Engine: 305 TBI
I have the same problem but it the check light is on
Old Feb 4, 2007 | 02:04 PM
75lemans's Avatar
Car: 91 rs t top
Engine: 5.0
yea my light is on thats why i took the bulb out
Old Feb 4, 2007 | 03:40 PM
Engine: 305 TBI
so why do i have to keep my foot on the gas pedal then, if i dont the car will turn off
Old Feb 4, 2007 | 03:46 PM
75lemans's Avatar
Car: 91 rs t top
Engine: 5.0
yea i dont no mine is the same way only when its cold
Old Feb 4, 2007 | 07:29 PM
golden's Avatar
Car: '89 Firebird
Your engine's running too lean , Check the fuel filter ...
Old Feb 4, 2007 | 07:46 PM
75lemans's Avatar
Car: 91 rs t top
Engine: 5.0
you can smell the gas its definitly not running lean its rich if ne thing
Old Dec 18, 2007 | 11:13 AM
corrottop1's Avatar
Re: no cold start
Your idle problem is probably from the coolant temp semsor being bad as the computer get's a signal from the sensor and puts the engine on high idle till it warms up, hope this help's
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
