Anybody ever use one? Will they work with our TBI intakes? Here are a few I'm looking at.
http://www.jegs.com/cgi-bin/ncommerc...&path=76%20537
1989 Pontiac Firebird Formula LO3 Auto
-180 degree stat
-Hooker Cat-Back
-vinyl security shade, velcro t-top bag
*****Possible summer '01 mods*****
Dual Snorkle, Auburn Posi, Keyless Entry, Wonder Bar from my IROC, 4th gen seats, T/A tail lights
http://www.geocities.com/krt80/
-180 degree stat
-Hooker Cat-Back
I dont think that those plates will work. If you look at the pics you can see that it bolts to the carb/intake mating holes. Stock TBI manifolds dont have the holes in the same place. What it does..or at least should have are lift "tabs" bolted to the manifold/head mating bolts - on drivers side back bolt and passenger side front bolt (or vice versa). You just need the chain and hook (not to be confused with the ball and chain). Thats what mine had anyway. You can use an tbi/carb adapter plate which will mean your engine will be held by 3 bolts....hmmm
iron block + aluminum manifold / 3 bolts =
your call.
89CamaroRS
Power Rating: 1.21 Jigowatts
Mods:Flux Capacitor
Future Plans: Time Travel
your call.
89CamaroRS
Mods:Flux Capacitor
I'd just like to have something where the engine could be completely assembled outside of the car, then hoisted in. It would just be a little easier(or a luxury).
Use the stock hooks that already exist on your intake. One is near the front the other is near the rear. They were used by the factory to install your motor. Have used these successfully to pull and replace a motor.
- 412ci/sb
If you do want to buy that plate, put a TBI gasket on it and drill your own holes for it. try to center it up as good as you can and then you can pick up carbs and TBI with you plate. I dont think it would be that hard. And 3 bolts is plenty to pick up and engine. Everyone i have ever seen pulled only had 2 bolts and the was no problem with them.
Last time around I got one of those load leveler deals from one of those traveling tool shows that come around occassionally for $20. It worked out real good for me - especially since I was by myself.
Harbor freight sells the same thing. I'm sure you could find it around for less like I did. I used the chains that came with it, a few nuts and bolts...
http://www.harborfreight.com/cpi/taf...temnumber=5402
'89 Formula - Thunderchicken - 355 Vette L98/T-5/3.45 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Sorry.. double post.
[This message has been edited by Brian Shaughnessy (edited April 06, 2001).]
Quote:
<font face="Verdana, Arial" size="2">Originally posted by Josh91Bird:
</font>
Didn't have a clue that those were for that. Ok, it makes sense that the factory would already have hooks on it. Thanks.<font face="Verdana, Arial" size="2">Originally posted by Josh91Bird:
</font>
Quote:
<font face="Verdana, Arial" size="2">Originally posted by Brian Shaughnessy:
</font>
That's what I used for taking my old engine out and putting the new one in. Worked great except we had to be careful with the vortec heads and how the bolts are straight up and down in the head. Used extra large washers so it didn't hurt the heads and the ARP bolts worked flawless.<font face="Verdana, Arial" size="2">Originally posted by Brian Shaughnessy:
</font>
The old intake is cake to take off, then just reuse the bolts and that 4 point hoist on a good cherry picker. Don't cut corners during the install process that could cost you $$$ if something goes wrong. Just my opinion and no those adaptor plates won't work with a TBI system.
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
- Holley 670 TB unit w/ 1/2" spacer/adapter
- Edelbrock RPM vortec intake
- 350ho 330hp vortec crate motor
- 8" harm. balancer
- Stewart stage 2 water pump w/160 thermo
- SLP tri-y headers to full 3"
- Rebuilt trans w/ SLP shift kit
- Centerline 16x8's all around
- 36/24 mm sway bars
- Full poly bushings, even motor mounts
- SLP LCA and panhard
- Alston SFCs
- Edelbrock 3 point STB
- Global west steering brace aka wonderbar
- Eibach pro kit springs
- Bilstien high perf. struts and shocks
- All this and I still have AC
DP, sorry
[This message has been edited by JPrevost (edited April 06, 2001).]
Well this engine is just a new L03(if it were my car we were doing this for it would be something else).
