identify theese injectors
Old Feb 7, 2007 | 01:38 AM
1988-305-tbi's Avatar
ok so i was at the junkyard today and decided to pikup some injectors, first i got some injectors awhile ago i think it was out of a 4.1 liter caddy "tbi and today i got some out off a 1981 6.0 liter caddy
the ones from the 4.1 are red prongs with # GM34085 B D 2 3 GM
the ones from the 1981 6.0 are black prongs # GM61906 4 22 1
i've searched but come up with nothing is there a list any where of injectors with there flow numbers. i really want to know if thees flow any more than the stock 5.0 orange prong injectors. hope someone knows more about theese than me
Old Feb 7, 2007 | 02:09 AM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Regarding the "GM34085 B" injectors:
I had my hands on a pair of these awhile back. I never installed them on my engine, but I could not figure them out. I searched pretty hard, called some dealers, talked to some hard core TBI guys. I sent them back to the seller because they were not the number I bought.
I honestly have no clue what they are, and I put up one hell of a search and couldnt find anything. I would not install them without knowing the flow rating. I would either get them flow tested, or go and find out what injectors you need (information is on these forums), and search for ones with that specific number. That is a much better than pulling random injectors and trying to find out their flow rating, which can be a real pain.
I would think the 6.0 injectors would flow more, and then they COULD work, however you still need to find out the flow rating or you will not be able to tune the PROM to match the injectors.
Old Feb 7, 2007 | 02:17 AM
thanks for the reply darkshot kinnda what i figured, i think the injectors u are talking about are prob a bit less than the stock or close to it, and i hope the black ones are a bit more , im planning on smogging my car this week so maybe in the next couple days, after smog i'll play with the injectors and see if they add any performance,
Old Feb 7, 2007 | 05:53 AM
kdrolt's Avatar
Car: 93 GM300 platforms
Engine: LO3, LO5
Transmission: MD8 x2
Remember that the injectors are always sized by the factory to meet the power requirements of the engines that they're installed into. For the 4.1 Cad v8, that was IIRC a 140 hp engine. The 6.0 Cad (368 cid) was rated higher, but not by much.... around 180 hp.
So either sets of injectors are about the flow-equal for a 305 TBI (i.e. 51 to 55 lbs/hr). Neither would flow as much as a copcar LO5 or as a late TBI LO5 from a light truck/van. All those are 61 to 68 lbs/hr. I think the Cad injectors have been discussed before on TGO in more detail if you search. HTH.
Old Feb 7, 2007 | 08:51 AM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
From the info that I have seen the 6.0L caddy injectors are equivalent flow to the 350 injectors, so figure 61 lb.
Old Feb 7, 2007 | 11:21 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Search??
http://www.diy-efi.org/gmecm/compone...injectors.html
Old Feb 7, 2007 | 06:50 PM
tzfbird why did u post that? it doesnt list either of the injectors i was asking about, i've searched by the numbers on them and come up with nothing, plus i;ve never seen any injectors that are color coded, just different colored prong connectors
Old Feb 8, 2007 | 11:31 PM
vorgath's Avatar
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
Now you guys caused it .. now I'll have to look at all my injectors, first see which ones I got in my car, since I was sure they were orange/orange
hmmm not green/white
However the pic on the diy-efi site isn't working, so I'm probably thinking of the wrong spot on the injectors
92-Formula
Dec 12, 2015 10:34 PM
Linson
Sep 21, 2015 01:08 PM
abrilnelson89
Sep 17, 2015 10:41 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
