How to change to carb
Old Apr 23, 2001 | 06:47 PM
Happy17yearold's Avatar
How do i go about to change my car to carb.....what are the advantages and disadvantages......how much will the whole process cost........thanxs
1988 Firebird trans am 305 tbi LO3......Hey for 600 bucks i cant ask for more but i am going to swap the engine and spank some rice
Old Apr 23, 2001 | 07:02 PM
jase's Avatar
Hey dude,check out the tech articles.And yes it can be doneunder 600.You can go to a junkyard and pick a carb,distr.,and intake man.for that price or cheaper.You have to change distributors because of the computerand may need a new fuel pump or just a regulator.You will lose gas milage,have cold start ups(depends on where you live),and more tuning to get your mixture right.
Old Apr 23, 2001 | 07:06 PM
I live in miami so and once in a blue moon it gets into the 60's.....Ill go look at the tech article....is carb better for performance.....gas mileage is not my worries right now
Old Apr 23, 2001 | 07:08 PM
cobrakiller1989's Avatar
it will cost you money and cost you performance. The problem with a stock LO3 is not the TBI, but is the heads, intake and cam. A carb might be a good choice if you have a 300+hp engine, but you TBI is jsut fine for your 305.
Old Apr 23, 2001 | 07:13 PM
So what would be cheaper.......getting new heads,cam,intake and installing them......or should i buy a used 350 and rebuild it and pay someone to install it.......right now i dont want to build the ultimate street machine but just want to get into the 250 hp range....im only 17 and have a part time in my dads body shop so finance is an issue but i can save up and do chunks at a time
Old Apr 23, 2001 | 09:19 PM
jase's Avatar
If you shop around and do a little research,both ideas are great.you can shop around for heads,cam,ect.or build a mild 350.A 305 has potintal but is about 45 cubic inches smaller than a 350.A 350 has alot more potinetal and would be cheaper in the long run.you can get an easy 300 horses with a cam,heads,and exuast.I would go with a 350.
Thats my 2 cents.
Old Apr 23, 2001 | 09:42 PM
Basett Racing's Avatar
I would stay with TBI and either mod your 305 or get a 350. A good stock 350 with a halfway decent cam will produce 275-300 all day long and with the TBI you'll have a much more streetable car. To put it shortly, there really isn't a carb you could buy that you could put on a stock L03 that would noticably improve performance.
82 Z28 350, Ported #882 Heads, Performer RPM cam and intake, hedman headers,650 Demon carb,
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: 12.52@107.2
Future plans: Dart headed, Roller cammed 383 in early '01
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
R.I.P. Dale Earnhardt #3
Old Apr 23, 2001 | 09:50 PM
NJ SPEEDER's Avatar
step one: disconnect negative battery ground(standard first instruction)
step two: disconnect brain from anything that resembles technology
step three: drag nuckles on floor
step four: install carb
you are gonna lose a ton of gas mileage, driveability, and perfromance potential.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Apr 23, 2001 | 11:54 PM
JPrevost's Avatar
Car: 91 Red Sled
lol, Tim I like that step 3
Step 3 part b)buy carb
Step 3 part c)rebuild carb often (usually every other oil change )
Step 4 part b)tune carb with nose and eyes, ex. of rich condition "ah ****, I can't see, I can't stop crying" ex. of lean condition "are the headers suposed to be bright orange?"
Step 5:
get beat by Tim who runs 14.2 with STOCK cam and STOCK TB!!!!! hahaha
Really though, there is no reason a carb will make more performance if you do it right. Why would you want to get rid of a simple EFI system for a complex mechanical setup when they make the same power when done right? Do a search for TBI advantages and you'll see lots of reasons why TBI rocks.
, Jon (350 TBI! it's trenuous and efficacious while getting 23mpg highway with off the shelf eprom)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 24, 2001 | 12:53 PM
chevyboy07 91's Avatar
Yo happy,
Where in MIA do you live??? Anywhere near UM???
Old Apr 24, 2001 | 06:22 PM
near miami senior high.....I live near 17th ave and flagler
Frozer!!!
Jan 19, 2024 04:55 PM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
nuggie
Aug 25, 2015 01:27 PM
BlackphantomZ28
Aug 22, 2015 01:00 PM
