Times from a mild port job on my TBI
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Axle/Gears: 3.73 S60
Go here and you can see the differances between the weeks and what I did to the car.
All I did was from May 4th running between 16.2-16.4 to May 11th running 16.0 (except one run I forgot to turn off the AC) was I took off the air cleaner abd did the mild port job on the TBI..
All I did to the TBI was remove the ridges and smoothed out the bores.
Kat
90 RS 305 TBI A4
Dumb ***/**** poor/orginating memeber of the infamous NE Crew
Time to see, believe this in me,This pain that i feel deep inside
Kat
90 RS 305 TBI A4
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
Good job man. Just keep pluggin' away little by little and before you know you have a quick little car. I like the commentation on each time slip
Seems like your having a great time,and thats what its all about.
82 Z28 383, Ported 215cc Dart Iron Eagle Heads, Comp custom grind roller cam, Speed Pro .250" domes, Wheeler Motorsports 4340 I beam rods, Eagle 5140 steel crank, Weiand Team G intake, Holley 800 DP, hedman headers
Trans: Turbo 350 w/ 4000 stall -- Rearend 7.5 w/ Richmond 4.10's, Auburn Minispool
Best ET: *NEW ENGINE* untried at track!!
89 RS, L03 305, Hypertech Chip,cat delete, Dynomax exhaust,K&N open element Filter,160 stat, MSD coil --Trans:700R4 Corvette Servo -- Rearend: 7.5 GM 3.42 w/ posi-lock
New Best ET: 14.91 @92.9
Bassett Racing
Mid Atlantic F Body -82 Z28 Page
R.I.P. Dale Earnhardt #3
[This message has been edited by Basett Racing (edited May 12, 2001).]
Seems like your having a great time,and thats what its all about.------------------
Bassett Racing
good deal!!!!!
looks like the car is coming along nicely. do a little with the suspension and the rear to get the hook you need, with a set of 3.73's you should be able to go well into the 15's.
lata
tim
91 Camaro RS-LO3,Auto.
14.209@95.46mph
Best 60' 1.917
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
lata
tim
14.209@95.46mph
Best 60' 1.917
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
NJSPEEDER, Umm I do think that I actually have 3.73's.... Just a peg leg rear doenst help at all.
As for hooking. Umm I usually dont have a problem with it at all actually.
Kat
Kat
Car: 91 Red Sled
Kat, you going to be at the e-town Nationals Aug. 4th?
, Jon (350 TBI!)
91 Red My website
, Jon (350 TBI!)
91 Red My website
Car: Camaro Vert
Engine: 355 HSR
Transmission: A4
I might just to see if I can get anywhere at all.
hehe hopefully by then I might have a full exhuast on the car and maybe a posi of I am lucky
Kat
hehe hopefully by then I might have a full exhuast on the car and maybe a posi of I am luckyKat
evilstuie
Jan 9, 2020 08:29 PM
