Subframe connectors, worth it?
Old May 24, 2001 | 06:13 PM
Taylor92RS's Avatar
I was thinking of putting a pair on my 92 RS until I saw the price of $151. All they are is two long pieces of steel right? Are they worth looking into?
Old May 24, 2001 | 06:39 PM
EVILFACE's Avatar
Yes, reguardless if your gonna do mods or not. They strenghen the frame and help eliminate most of the creaks. Also it's good to get a strut tower brace.
I have a MAC Panhard and Lower Control Arms that should arive sometime this week and up next is a set of SFC's from Spohn above and probably a edelbrock tower brace.
EVILFACE
88 Camaro
Stock 305 TBI Auto, Flowmaster, Full 3" Exhaust, B&M Megashifter, K&N Open Element
Runs A Blistering 16.5 @ 81.5 mph (due to major tire spin)
http://www.evilface.com/evilscamaro.htm
Old May 24, 2001 | 06:42 PM
soulbounder's Avatar
Car: 89 TTA
Engine: Turbo 3.8
Transmission: 200R4
Yes, they are worth it. There are several companies that make them; Spohn, Alston, Kenny Brown, Hotchkis, SSM, Jeg's, etc. They vary in prices but basically all perform the same function. Maybe some work a little better than others but you know how that goes. That is one of the must have mods of any thirdgen. They should have come from the factory with them. You can even make your own if you are good with metal and a welding machine and have access to a lift. Search the archives and you will find tons of posts on SFC's.
Old May 24, 2001 | 09:24 PM
JPrevost's Avatar
Car: 91 Red Sled
YES
, Jon (350 TBI!)
91 Red My website
Old May 25, 2001 | 09:12 AM
95Z28A4's Avatar
I can't speak for a thirdgen, but they made a world of difference on my 95 Z28 hadrtop. I used Global West weld in SFC's because they are the largest/stiffest (2") available that don't cause a loss of ground clearance.
Mike
Old May 25, 2001 | 09:41 PM
rsilver's Avatar
I put in alstons in my convert and I expected it to make a big difference but IMO
it was a marginal improvement. I know I am in the minority opinion. However, the Strut tower brace I put in (after the sfc's) made a lot of difference and I am sure that SFC's in conjunction with the STB is a worthwhile combo. Its probably like engine mods. Its the whole package thats important. Just my .02........bob
91 camaro RS L03 convert,
t-5, ultimate TBI mods,TBI spacer,SLP 1 5/8 headers,
3"cat back, 3.42 torsen posi,alston SFC's,Global West LCA relocation brackets, edelbrock STB
350 swap in progress
Old May 27, 2001 | 10:14 PM
Macgyver's Avatar
<h3>YES YES YES YES.</h3>
But it should be noted, On an F41 suspension, the effects are minimal save for body flex. That's why rsilver didn't notice much, he has soft springs and the converts are already braced from the factory.
If you upgrade your springs, your car will feel like a Go-kart
I had the F41 suspension, and Dirk was telling me they made his car feel like he was riding on a board. Then I installed WS6 springs, now I know what he's talking about
Old May 28, 2001 | 12:23 AM
snflupigus's Avatar
Car: 92 RS, 02 Tacoma, 2 73 Porsche 914s
yes they are just two peices of steel, but the length and angles on them have been designed, not made. DESIGNED. there is a difference, o ya, and theyve been tested too. so if you think you can just start connecting stuff with some steel plates or tubing. um , no.
wigmobile
Feb 26, 2025 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
ccop
Convertibles
Sep 14, 2015 04:13 PM
Nick McCardle
Sep 10, 2015 08:36 PM
