Cam Swap
Old Jun 17, 2001 | 05:29 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Cam Swap
Easier to change cams by pulling the engine or by trying to do it with the engine in. Have the equipment to pull the engine but all the wires and sensors are scary. All I would be doing is changing cam, intake, and valve springs.
Old Jun 19, 2001 | 04:22 PM
Spyder's Avatar
Its not too bad to do it in the car. You do have to take off alot of stuff though. If you don't want to worry about the sensors this is the way to go.
Old Jun 19, 2001 | 04:33 PM
About how long of a job is this, to do a cam swap with the engine in the car? I have general knowledge and the guy I would be doing it with has built engines and all of that good stuff? Thanks, Brady
Old Jun 19, 2001 | 05:51 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
I just installed a LT1 cam last weekend.It took me about 15 hours, but I was installing a new intake manifold also (took some time switching things over).I was able to do it with out completly removing the air cond. condenser.I loosened the clamp that holds the steel lines to the frame and rotated it up out of the way.(Pablo was right)
Good luck
Dave
92RS LO3 700R4
open air element
ultimate TBI mods
LT1 cam
Edelbrock TBI performer manifold
180 thermostat
Hooker headers
3"cat back
Zexel Torsen posi with 3.42 gears
[This message has been edited by JokerRS (edited June 19, 2001).]
Old Jun 19, 2001 | 06:29 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
Joker, did you change the springs as well? and what about the computer chip?
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, no cat,SLP 1 5/8" headers and y-pipe March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 190ltr/hr fuel pump,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops
0-60mph-7.2s-Gteched
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Old Jun 19, 2001 | 08:51 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
I used my stock springs.The 95-97 LT1 cam has .447 and .459 lift.I consider .450 lift about max for stock springs.I haven't had any valve float or coil bind.Its running fine with a stock chip(no trouble codes).It idles smooth, and it will now pull to 6000RPM.It lost alittle low end power but I expected that.It acually hooks up alittle better now.I'm sure a custom chip would help some but it runs respectable the way it is.
92RS LO3 700R4
open air element
ultimate TBI mods
LT1 cam
180 thermostat
Hooker headers
3"cat back
Old Jun 20, 2001 | 08:32 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
from all the stuff that ive read , you defintly wanna swap out the springs soon after installing an lt1 cam. as someone pointed out to me.. lt4 springs and retainers will help in this area... paceparts.com has a good deal on them if your lookin for them..
91 camaro RS
- 305 TBI
Mods: Performer TBI intake, 1" TBI spacer, K+N, jet fan switch ,160 thermo,Accel control module, Jet Stage 2 chip, edelbrock TES headers, Compleate 3" Flowmaster exhaust, Edelbrock springs, KYB struts and shocks, 700R4 built by TSI, SLP tq converter, b+m trans cooler, white guage faces, megashifter..
next month: spohn LCA's and panhard rod, BMR relocation brackets, 323 gear, lt1 cam , 350 heads
Old Jun 20, 2001 | 10:27 PM
bbtaz97 - what kind of 350 heads do you have?
Old Jun 23, 2001 | 12:10 PM
JokerRS's Avatar
Car: 92RS
Engine: 357
I guess it depends on what you are building whether or not you want to change springs.I have 92000 miles on my engine(not exactly new).I am just trying to have a little more fun on the street.I'll probably never get it to a strip.I wont put a dime in my junk LO3 heads.When I've used up this motor I will put my money in a 350.As I said before the coils are not binding and the small valves are not floating.I'm shifting at 5500RPM.Is the boogey man going to get me or what?I was changing the intake manifold anyway so I bought a used cam for cheap and installed it with my used roller lifters.I got a nice bang for the buck out of the cam change.The reason I am responding in depth like this is because I know from reading this board that there are alot of people out there looking for some cheap HP for a well used motor.I've built some hot 350's ,but I cant see putting to much money in a LO3.Some may want to prove something, and thats ok.I respect that.But if you are like me and just want more power under your right foot there are cheaper ways to go rather then trying to build a killer LO3.
Have a nice weekend.
Dave
92RS LO3 700R4
open air element
ultimate TBI mods
LT1 cam
180 thermostat
Hooker headers
3"cat back
anesthes
Mar 10, 2016 10:35 PM
beastin91rs
Oct 9, 2015 07:38 AM
Cameeeero
Sep 18, 2015 04:00 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
