Cam Performance?
Old Mar 21, 2007 | 01:07 PM
91formulaNY's Avatar
Cam Performance?
My 91 Formula has a 305 TBI stock motor. I would like to know what would be a good choice for a higher performance cam, without going supercrazy . Can any give me a suggestion or two?
Also I have a hooker catback set-up with a single cat, what headers would go best with keeping the emissions?
Old Mar 21, 2007 | 01:24 PM
BMmonteSS's Avatar
Car: 84' Monte
Transmission: 700-r4
Axle/Gears: ferd 9" posi 3.50 gears
Re: Cam Performance?
How good are you at chip tuning? This will really govern how far you can go.
Old Mar 21, 2007 | 01:31 PM
Im not , lol. Is there a company or somebody that "Tunes" or "Burns" chips that i could order one from?
Old Mar 22, 2007 | 06:55 AM
BMmonteSS's Avatar
Car: 84' Monte
Nope, well there is tbichips.com.....but do a quick search on here or look at the current thread on what the concensus is of his "skills" on the boards. In a nut shell tuning an engine is WAY too complicated to do over the internet basd on a list of mods. If you really want to play with TBI you need to learn to burn your own chips, check out the "free tune" sticky at the top of the page.
If you don't tune your own chips, you might get away with an LT1 cam. Some guys have had problems with stalling and crappy mileage untill they retuned. You'll only relize about 1/2 the power of the cam without tuning.
Old Mar 22, 2007 | 07:45 PM
92 Camaro's Avatar
Car: 1992 Camaro RS, 66 Mustang, 78 t/a
Engine: 5.0 TBI, 289, 400
Transmission: 700R4, C4, th350
I dont plan on doing this, but what about LT1 cam with the tbi chip?
Old Mar 23, 2007 | 01:20 PM
BMmonteSS's Avatar
Car: 84' Monte
No different than a LT1 cam and a stock chip. The only thing he changes is WOT stuff and some constants. It's the low RPM tuning that causes all the drivability problems.
Old Mar 23, 2007 | 01:22 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
For headers, go with Hooker 2055's.
Old Mar 23, 2007 | 01:32 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
For 3" cat back, the hookers are a good way to go, although you cant change the spark plugs with them on the motor. Edelbrock also makes headers that allow you to have a little more room, but their doughnut gaskets are complete junk. Theyre made of paper and metal foil rather then compressed metal foil like they should, so they frequently fail. On the flip side, the ball joints on the hookers leak because teh angles are all wrong and the y-pipe is tin foil. Pick your poison...
Old Mar 23, 2007 | 03:29 PM
Car: 91 RS
Engine: 350 TBI
I can change the plugs on mine. Just can't use stock length plugs.
beastin91rs
Oct 9, 2015 07:38 AM
gta90
Sep 15, 2015 04:00 PM
ambainb
Aug 29, 2015 12:43 AM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
