Oil Pressure
Old Jul 26, 2001 | 11:05 AM
Kirkfry350's Avatar
Oil Pressure
Having problems with the oil pressure staying close to zero at almost all the time.
What could cause this?
Seems to happen up till about 3200 RPM then it climbs to rouglhy 100.
Any ideas would be greatly appreciated.
John
Old Jul 26, 2001 | 11:36 AM
Brian Felts's Avatar
Car: 89 RS 355/ 89 IROC Convert
Engine: Hot Cam 355/TPI 305
Transmission: All 700r4's
Before you get to worried I would replace the sending unit.
Brian
1989 Camaro RS
305 .030 over Hydro Pistons
Vortech heads milled to 58cc...Performer RPM intake....LT4 cam..Crane Gold rockers...FastChip custom chip...ALum. Driveshaft...3.73 gears with Posi...underdrive pullys...Rebuilt 700R4 with Vette Servo and B&M shift Kit...MSD ignition...A/C Delete No SMOG junk....1997 SS leather interior...B&M Shifter... Ultimate TBI mods...14X3 K&N open Element Non-Drop...Hooker headers....3" exhaust with Flowmaster Cross flow 16X8 Wheels from 97 RS Spohn LCA's Spohn Panhard Bar..LETS PLAY FORD!!
www.geocities.com/feltsb
Old Sep 17, 2013 | 10:00 AM
Biggd4355's Avatar
Re: Oil Pressure
Brian
1989 Camaro RS
Where is the sending unit located?
Old Sep 17, 2013 | 03:51 PM
punkmaster98's Avatar
Car: 1984 T/A
Engine: LQ4
Re: Oil Pressure
Its right above the oil filter. you cant miss it. I had this same issue last month.
Old Sep 17, 2013 | 04:13 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: Oil Pressure
Brian
Yep, Good place to start.
Old Sep 17, 2013 | 04:21 PM
Richboll's Avatar
Engine: 305 TBI
Re: Oil Pressure
Here's a link that might help
http://www.oreillyauto.com/site/c/se...e+sending+unit
Old Sep 17, 2013 | 04:40 PM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
Re: Oil Pressure
I agree, The day I bought my car on the way home my oil pressure dropped to 15, pulled into my driveway and it dropped to zero. It was only the sending unit, $15 if I remember right.
Old Sep 18, 2013 | 05:29 AM
Schurkey's Avatar
Re: Oil Pressure
Sending units are a known problem with these vehicles. The usual result is that the thing sloshes when you remove it--the seal deteriorated and the sending unit is now 2/3 full of engine oil, and heavy as hell.
83 Crossfire TA
Jan 3, 2016 01:26 PM
angel2794
Sep 8, 2015 06:22 PM
Strick1
Sep 4, 2015 07:11 AM
solocus
Sep 2, 2015 12:14 PM
