???what to expect from my TBI??
Old Jul 27, 2001 | 02:47 PM
pimpintheRS's Avatar
i am going to the track soon and i am putting in my 3.42's before i go i am running what to expect with a pretty much stock lo3 with the 3.42's and posi..oh yeah i have the big bad open element! and 1.75 inch lowering springs.. will i even break into the 15's?
Thanks??
Shawn?
Old Jul 27, 2001 | 07:00 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
My car ran high 15's stock with 3.08 open rear and open air filter. Those 3.42's will help you a lot but the 1.75 lowering springs are going to kill your traction unless you have LCA relocation brackets. Good luck
92 Camaro RS 5.0 5-Speed (Quasar Blue)
T-Tops
14" Open Air Cleaner
3.08 Posi-trac
Edelbrock TBI Intake
Crane cam
Ported & polished stock heads 3 angle valve job
HyperTech Chip
SLP Headers (Ceramic Coated)
UltraFlo cat-back exhaust
74 Dodge Dart Sport 360 (11.2 1/4 mile)
2000 Dodge 1500 Ram Sport
Old Jul 27, 2001 | 09:08 PM
lca relocation brackets cost how much? what do you think my time will be?
Shawn
91 RS 5.0 TBI
14x3 open element.. i liked alot
160*stat... made my car run a lil cooler
msd coil and taylor wires ...not noticed
with ac delco plugs.. i like
removed rear hood seal.. runs much cooler i liked
accel cap and rotor..not a real mod
coming soon 3.42's with slp posi.. my first big mod!!!
Clarion cd player 2 planet audio 6x9's 2 lanzar tweeters and one MTX 10" sub in a bandpass all running off 2 separate 200w amps
Old Jul 27, 2001 | 09:44 PM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
Get them from SPOHN, click on the banner at the top right of the page to go to his site, or here is a quick link http://www.spohn.net/index.cfm?fusea...t&productid=11
check out the rest of his stuff too
T-Tops
3.08 Posi-trac
Crane cam
HyperTech Chip
Old Jul 27, 2001 | 10:32 PM
JPrevost's Avatar
Car: 91 Red Sled
My relocation brackets are going in wednesday. When it's all said and done I'll have a good idea on how much they help. My car was lowered with the eibach prokit so like 1.25" all around.
, Jon (350 TBI!)
91 Red My website
Old Jul 29, 2001 | 08:56 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Definite you'll be in the 15's. And the 1.75" drop shouldnt cause wheel hop. When I had 2" drop all around it would hop alot. But then now I have the pro kit in the front and 2" in the back. And now it doesnt hop. Hmmm...confusing...
Chris
91 RS 305 TBI
Eternal Rev
Possibly one of the worlds only drifting Camaros!
Old Jul 29, 2001 | 11:29 PM
so i will get wheel hop that is going to suck but being in the 15's is something i like to here! what else should i do to make my tbi a respectable motor? i am thinking intake next. then headers and the lt1 cam... how does that sound?
thanks
Shawn
Old Jul 30, 2001 | 10:03 AM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I would do the headers and then the LT1 cam and the intake at the same time since you have to remove the intake to put the cam in. Once you see the new y-pipe with the headers you will understand y it should be changed next. The exhaust is VERY restrictive. I replaced ALL of my exhaust and ordered 3" parts for TPI car.
91 Camaro RS 5.0L Black Convertible 700R4
** Added so far **
*GM Wonderbar,Alston SFC's,spohn LCA's and Panhard rod
*Turbo City Inj Spacer
*Dual Snorkel Air Filter
*March Performance Pulleys
*GM 3.42 Gears with OEM Zexel POSI
*Edelbrock headers
*3" High Flow Cat
*3" Dynomax Exhaust
*Walbro 255 lph Fuel Pump
***Future 330hp Vortec Crate with LT4 hotcam and 454 TBI
S10K20
Oct 7, 2015 06:45 PM
Bigold4x4
Sep 28, 2015 05:21 PM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
