A I R on exhaust
Old Sep 25, 2001 | 12:26 PM
92Camaro305TBI's Avatar
A I R on exhaust
I disconnected the tube leading to the exhaust manifold; I've been hearing somewhere that if you take out that smog system then it wont hurt anything put your emissions, and you wont feel a gain.
Anyway, i disconnect it, turned on the motor and nothing unusual.. plugged the hose(I could feel air sucking in) and heard a grinding noise. of course I let go and everything was fine. so I decide to drive around to see if I noticed anything, First I filled up my tank... when I got to 30+ miles My gauge was at 3/4.. which is not normal for me... well I just past 100+ miles and Im pretty close to 1/2 a tank.
So does it sound like Im getting less MPG??Ill know for sure when I empty the tank but I was wandering some of your thoughts on disabling the A I R system(is this the same thing as the Smog stuff)
Also when I step on it.. there a hesitation, put it does seem to pull a lil bit harder?
Is this my imagination or is there really a gain.
92 Camaro 305 TBI Automatic
2.5 high flow cat, 2.5 pipes, 3.5in tip
shift kit
Tinted windows(legal)
Spark plug wires and plugs...
14X3 O.E. K&N Filter
Future mods.
Headers
any other advise on getting to 300+ HP would be appreciated. Thanks
11.0 Et @64mph on the 1/8 reaction time was 1.0+ with a 60ft at 2.5?(First run ever, didn't know which light to go on)
System = Sony explode 5000 CD/MD receiver
Rockford 6x9 Fanatics
Rockford 4x6 Fanatics
Rockford 2 12" Hx2's
Rockford 1 farad cap
Rockford 800x2 Amp
Custom box
4gauge wire kit
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=6100
Old Sep 25, 2001 | 03:25 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Imagination, you don't get any gain from taking off ur A.I.R. System. If I was you, I would just put it right back on.
Eric Natzke
91 Firebird 305 TBI
"It Ain't Stock"
http://members.aol.com/j007golden/91firebird.html
For info on certain parts or mods go to the site below
http://members.aol.com/j007golden/modeval.html
Old Sep 25, 2001 | 03:33 PM
thanks for the advise, any reason why I shouldn't take it off completly? if its not going to hurt anything and if I could clean it up..??
firbird's Avatar
i did not take mine off for hp i took mine off for looks. but really i did not notice any thing really but i sure cleaned up my exahust and i dont have a cat so i guess the smog stuff really did not help, o and if you dont gut your cat or put a pipe in will your cat clog up because it doesnot have the smog suff?, its just something i heard before.
Old Sep 25, 2001 | 04:37 PM
And if I get the TES without AIR.. It would be useless....
firbird is there any special way to remove it or just take out all connecting part to it.?
thanks
Old Sep 25, 2001 | 05:47 PM
firbird's Avatar
i have edelbrock headders and i have got rid of the air tubes comming out of it and ported all the crap out of it, got it cheep.
what part are you talking about the cat?
aol im= firbirdgta
Old Sep 25, 2001 | 07:06 PM
JPrevost's Avatar
Car: 91 Red Sled
The air pump is there to help warm up the cat converter after a cold start and to basically get rid of any unburnt fuel. It's injecting oxygen rich air into the exhaust where VERY hot gas and hydrocarbons are exiting the combustion chamber. They combust in the exhaust manifold and help control emissions. I don't have the pump on my car and I just ripped off all the tubes. I have SLP headers and a 330hp 350 and I squeeked by emissions with just a cat and a muffler running at 220 degrees. As far as performance, zilch gain. Maybe 1hp but it shouldn't be noticable. If you want noticable, leave your a/c on.
If you want to get rid of it go for it, it shouldn't hurt your gas milage, it should help if anything. There is a tech article about how to remove the pump (really easy) and install a shorter belt. I can probably get pictures on my site soon.
, Jon (350 TBI!)
91 Red My website
Old Sep 25, 2001 | 09:05 PM
Thanks for the info...Im going to remove it as planned, And that explanation help a lot...
Pictures would be really great.
Thanks again
Old Sep 26, 2001 | 11:27 AM
Well I looked in the tech article section and didn't see it,
Can anyone help me out with a link?
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
