dieseling problem with a 86 TA
Old Sep 27, 2001 | 04:25 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
My buddy has a 86 TA with a 305 TBI. Everytime he shuts it off, with the trans in park, and the engine hot, it diesels on anywhere from 3 seconds to 3 minutes at about 100rpm.
If he shuts the engine off with it in drive, the it shuts right down normally.
any ideas whats going on here??? thanks a ton for the help.
Old Sep 27, 2001 | 07:39 PM
JPrevost's Avatar
Car: 91 Red Sled
Try and decrease base timing. Sounds like it's a little to advanced and running a little on the hot side.
, Jon (350 TBI!)
91 Red My website
Old Sep 27, 2001 | 08:20 PM
firbird's Avatar
yea sounds like it too advanced, wow a ta tbi. lol 3 min thats a long time, i just thought tbi would shut down because the injectors would not keep injecting. what temp is it running most of the time, just courious.
Old Sep 27, 2001 | 09:53 PM
JPrevost's Avatar
Car: 91 Red Sled
In 86 there was no TBI so are you SURE it's TBI? The TBI and carb look the same. They use the same air cleaner.
, Jon (350 TBI!)
91 Red My website
Old Sep 28, 2001 | 10:48 AM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
um thats interesting. i was just going off what he told me. ill have to check the tbi/carb issue when i go up there today. ill also try and pull some timeing out. how much would you think i should take out? and what should the timing be at?
Old Sep 28, 2001 | 12:18 PM
JPrevost's Avatar
Car: 91 Red Sled
I think timing for a carb was 6 base but I don't know since TBI the base timing was actually 0 from the factory. I'll bet it's a carb, I'd pull out a few degree's of timing. Turn off the car. You can tell when you have to much timing when the car is hard to start.
Old Sep 28, 2001 | 03:47 PM
NTChrist's Avatar
Yeah, it's got to be carb. Shut the ignition off, the injectors die. The engine will stop.
No guts, no glory.
Old Oct 1, 2001 | 09:44 PM
88blkiroc's Avatar
Car: 88 IROC-Z
Transmission: TH350
Axle/Gears: 3.45
ya it is carb my bad
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
