LT1 cam and rockers
Old Oct 7, 2001 | 05:27 PM
Neo's Avatar
Neo
LT1 cam and rockers
I am getting a cam and 1.5 rockers from a 1997 Camaro.
1) Will these rockers work?
2) How much will they help?
3) What are the stock size rockers on my L03?
4) What if any modifications do I have to do to fit this cam in place of my current one?
Mike
1991 Chevrolet Camaro RS 305 TBI
My Website
Administrator at Auto-Clubs.net
Moderator at ColoradoF-Body.com
My Baby
Old Oct 7, 2001 | 05:46 PM
Tas's Avatar
Tas
Same shet. No advantage but wear and miles. Stock are stamped 1.5s as well. Roller 1.5 or 1.6 would be an advantage. Cheapest self aligning 1.6 rollers I've seen are $191.
[This message has been edited by Tas (edited October 07, 2001).]
Old Oct 7, 2001 | 05:53 PM
Neo's Avatar
Neo
Do I have to do anything for the cam of will it fit the same?
Old Oct 7, 2001 | 08:12 PM
NJ SPEEDER's Avatar
the rockers will be the same. working with a full roller type rocker woudl be a good idea by reducing soem frictional loses in the valve train but it is not necessary if you don't wanna spend the $$$. 1.6 rockers will increase the lift of the cam but they will put the valves a long way into the holes, soi you woudl be looking at a major reduction in vacuum which can make the ecm unhappy.
you will not need to change anythign to use the 1.5 rockers. if you decide on 1.6 rockers you may need to change to aftermarket valve covers sinc esome brands do not clear the stockers.
hope this helps.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Oct 7, 2001 | 09:11 PM
NTChrist's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Neo:
Do I have to do anything for the cam of will it fit the same?</font>
I think he was asking about the cam, rather than the rocker.
To answer your question, no there's nothing major that has to be changed, except there's a dowel pin on the end of the cam (I believe for the water pump) that needs to be ground down, so it doesn't interfere with the timing cover. Pretty straight forward.
No guts, no glory.
Old Oct 7, 2001 | 09:53 PM
Neo's Avatar
Neo
Yes I was refering to the Cam.
That is it, even though the LT1 uses a opti instead of a distributer?
Old Oct 7, 2001 | 10:12 PM
Tas's Avatar
Tas
you have to grind down or pull out the pin on the front of the cam if its still there.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Got Beach?
Old Oct 7, 2001 | 10:59 PM
NJ SPEEDER's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Tas:
</font>
this is a sometimes yes sometimes no thing. it sems the cams from the earlier LT1 years have an extra long dowel pin that would need to be cut down, but my cam from a '97 T/A had a normal hydraulic roller sized dowel. i know they changed the optispark in '95, that may eb the difference, not sure though.
later
tim
Old Oct 8, 2001 | 05:00 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Dont use 1.6 roller rockers with an LT1 cam on stock heads. The lift will be too great and the springs will coil bind, or hit the valve guides. Stick with 1.5's.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 9, 2001 | 06:18 PM
DM91RS's Avatar
Car: 91 RS
The LT4 cam had a longer pin that I pressed in far enough to work. (If you came up with one of those cams)
[This message has been edited by DM91RS (edited October 10, 2001).]
Old Oct 13, 2001 | 11:31 PM
Tom91Bird's Avatar
Car: 1991 Firebird
Engine: 383 stroker
I've heard that even 1.5's with and an LT1 cam with bind. I'd look further into new springs as well.
Old Oct 14, 2001 | 04:36 AM
DM91RS's Avatar
Car: 91 RS
I think that new springs are a plus, but the LT4 cam that I just installed does not bind. The cam change is a good mod.
91 RS 5.0 TBI....LT4 cam....Edelbrock headers....3"Dynomax exhaust....5spd.... 3.08.....Ultimate tbi....afpr...
Old Oct 14, 2001 | 04:38 AM
DM91RS's Avatar
Car: 91 RS
I did forget to mention that unless you are planning to change heads or your valve seals don't leak this is a perfect time to change the seals when you change the springs.
Old Oct 16, 2001 | 10:02 AM
FiReBReTHa's Avatar
lol, im sorry, but, why is the cam a good mod?
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Oct 16, 2001 | 10:57 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Because it works great. I did it too and instead of falling down at 3600 it now keeps pulling to 4000+. Just do it and you will a
see.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC Ex.
14.94-92.00 mph
SPDC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Old Oct 16, 2001 | 04:16 PM
DM91RS's Avatar
Car: 91 RS
Dyno Don has said it all. It will pull eazy to 6000 in 1st and 2nd gear. I normally shift at 5500. This with the stock intake and heads. I want to install a Performer RPM intake just to see what can be gotten out of the stock heads and then maybe some 081's or Vortec's. Try it you'll like it. The grease wash's off your hand's. LOL
91 RS 5.0 TBI....LT4 cam....Edelbrock headers....3"Dynomax exhaust....5spd.... 3.08.....Ultimate tbi....afpr...ZR 255-50's...Koni's
Old Oct 16, 2001 | 06:46 PM
DM91RS's Avatar
Car: 91 RS
Dyno Don, I forgot to ask. I that an off the shelf cam and what is the part # and price?
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
masonta
Sep 1, 2015 06:40 PM
