which tbi and intake ?
Old Nov 22, 2001 | 09:36 AM
PimpCamaroRS's Avatar
i plan on buying a 350 short block(rebuilt with good cam and pistons)then putting on some nice AFR heads or maybe the fast burn heads. now i need to know what would be the best intake manifold i could put in there to still let me pass smog in CA, and the best TBI unit that would bolt up to that intake. some prices and places to buy it would help alot. thanx
Old Nov 22, 2001 | 02:28 PM
also i some people have told me it ould be a smart idea to get an adjustable fuel regulator. if so, is there a specific kind i should get?
Old Nov 22, 2001 | 09:14 PM
well since u guys aren't helping some one told me a good combo. a rebuilt 350, with a desent cam, super ram intake, holley 670 TBI, Fast Burn Heads, and some good hooker or SLP headers. i dont really care if some of it is not emmissions legal as long as my car passes the sniffer. what you guys think about my combo and how much HP you think i could squeze out of that? thanx
Old Nov 22, 2001 | 10:47 PM
XFire83's Avatar
How are you going to use a Super Ram intake with TBI? Just use the Holley TBI intake. It is already machined for use with the 2" throttle bores. Also, if you get an engine with Vortec heads, the is a TBI manifold for that, as well.
Scott
Black 1983 Trans Am
350 Cross-Fire Injection
T5 World Class
3.42 Locker
7747 ECM
Flowtech Headers
!Cat
Factory 98 WS6 muffler (oval tip)
Old Nov 22, 2001 | 10:48 PM
XFire83's Avatar
Oh, and the Holley unit already HAS an adjustable Regulator on it.......
Black 1983 Trans Am
T5 World Class
3.42 Locker
7747 ECM
Flowtech Headers
!Cat
Old Nov 22, 2001 | 10:53 PM
so what would u guys request on a good intake, tbi, and head combo.
Old Nov 22, 2001 | 11:10 PM
NJ SPEEDER's Avatar
vortec heads, vortec tbi intake, and a cam that will make power up into the 5500 rpm range. the cam will be a matter of taste mostly, but i would prolly go for an LT4 hot cam or something similar.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Nov 23, 2001 | 12:29 AM
how many horses you think i could get out of that combo.
Old Nov 23, 2001 | 06:04 PM
Tas's Avatar
Tas
the ONLY aftermarket TBI intake that is legal in CA is the Edelbrock Performer TBI. If you want to get more power from it you can have it bored over for the 670 Holley intake. I doubt they could tell it from stock.
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
Old Nov 24, 2001 | 01:02 AM
XFire83's Avatar
Here, Check this out:
This aluminum small-block Vortec manifold was designed for maximum horsepower with throttle body fuel injection and EGR usage. The manifold will fit all Vortec design cylinder heads (P/N 12529093, 12558060, 12497186, and 12464298). Technical Notes: To use EGR, the gasses must be plumbed from the exhaust manifold into the intake manifold. Many exhaust manifolds have drilled and tapped holes that can be used to fabricate a tube. An example is the 1996 and later pickup truck with RPO L31 350 engine, which uses exhaust manifold P/N 12557828, EGR pipe P/N 10220275, and fitting P/N 12552329. That combination will fit this manifold for late model pickup trucks. Vacuum controlled EGR valve P/N 17052693 can be used on some models.
dutch930
Sep 11, 2015 06:58 AM
z28addict8490
Sep 5, 2015 03:56 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
