Request for a Picture of intake manifold
Car: 92 Camaro RS, 02 TA WS6
Engine: 305 TBI (350 in progress), LS1
Transmission: 700R4, T56
Anyone have a picture of a 305 TBI intake manifold without the Air cleaner. Preferrably with a view behind the TBI (EGR area toward the firewall)?
Thanks,
Mark
Thanks,
Mark
Re: Request for a Picture of intake manifold
SP63,
Thanks, probably should have clarified. I need one in the car with the sensors and vacuum hoses hoooked up so I can verify my wiring and hose routing.
Mark
Mark
Guest
Posts: n/a
a vac line goes on the egr valve.... not much else back there.... on the manifold itself. but then again. im not objective. sorry.
i am going out to my car right now, and will take pictures for you.
Guest
Posts: n/a
the coil has the 2 plugs which only fit one way iirc. map, wiper motor, and that one in the center, bottom pic. i forget whatever it is.
thats all i saw, or else id have pulled the 14x3 off.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
The one in the center is the EGR solenoid that controls the opening/closing of the EGR.
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
heel4life, I have some perfect pics of stock set up, that I took recently by doing the lt1 cam swap in case I forgot how it went back togheter.
I can e-mail you them.
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
Originally Posted by thomas1976
heel4life, I have some perfect pics of stock set up, that I took recently by doing the lt1 cam swap in case I forgot how it went back togheter. I can e-mail you them.
Car: 91 Trans am
SP63 / Thomas 1976 and Dimented 24X7,
Thank you all very much for the pics and info. These show me exactly what I needed on the vacuum routing. by chance does anyone know the name of the silver mini "canister" located next to the EGR valve? I messed up my vacuum hose routing from there.
Thank you all so much.
Guest
Posts: n/a
SP63,
Thanks, that is the diagram that I used. However it dows not show that little mini canister device beside the EGR as being part of the vacuum system. That is what has me confused, but I think wiht the pictures posted I understand where I went wrong.
ambainb
Apr 25, 2016 09:21 PM
Dialed_In
Aug 20, 2015 01:45 PM
