40 or 55? Which is it?
Old Mar 24, 2008 | 09:54 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I have the common 5235279 injectors in my car and I've been beating myself in the head as to what their flow rate is. I have been searching everywhere here and on the internet for the answer and it keeps coming up with these two rates. I want to tune my car and in tunerproRT it asks for the injector size. So which is it. 40 lbs per hour or 55 lbs per hour?
Old Mar 24, 2008 | 10:27 PM
alvanwie's Avatar
Car: 91 Camaro RS
Engine: 355 Vortec
Re: 40 or 55? Which is it?
55 lbs/hr
Old Mar 24, 2008 | 10:43 PM
ok then next question. when i input the injector size do I put 55 or is there a certain decimal after the fact like 55.10 or 55.64 and so forth?
Old Mar 24, 2008 | 11:12 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Just 55, no decimal needed.
Old Mar 24, 2008 | 11:53 PM
So in the INJ-MPG injector flow constant column in the tunerproRT I just change the 64.90 to 55.00 and save?
Old Mar 25, 2008 | 12:05 AM
Well I changed it from 64.90 to 55.00 and after I checked it again it changed to 54.57 . Is that the true flow rate of the 55 lb injector?
Old Mar 25, 2008 | 12:10 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
No, its just the nearest hex decimal equivalent to 55 lb/hr. Don't get too caught up in it. The fuel pressure is likely not exactly at where the injector is rated.
Old Mar 25, 2008 | 12:16 AM
I'm running 13 psi fuel pressure.
Old Mar 25, 2008 | 12:28 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The factory fuel pressure range is 9-13 psi, typically its set around 11 psi stock (I've seen stock TBIs running as little as 8 psi and as much as 16 psi), that means that you are on the high end of the spectrum. I use 11.5 psi as a starting point, since we can't seem to agree on 11 or 12 psi as a baseline for TBI flow ratings.
Old Mar 25, 2008 | 12:38 AM
I check mine regularly with my actron. just to be sure that my fuel pump is straight. you wouldn't happen to know how to delete the CCP do you?
Old Mar 25, 2008 | 09:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You wouldn't happen to know how to delete the CCP do you?
This depends upon whether the CCP system is still intact. If it is not longer present on the vehicle then there isn't anything in the calibration that requires changing. The default cal has the CCP code disabled and the output used as the shift light output.
If the CCP is still intact and you want to disable it for tuning in the VE tables. Then do this:
Find out if the CCP solenoid is NO or NC.
Set the Option Word bit for CCP
Set the Option Word bit for NC or NO soleniod operation
Set the CCP Enable temperature to 150 C
That will do it.
RBob.
Old Mar 25, 2008 | 01:12 PM
Yes i deleted it along time ago to clean up the engine bay. So without changing anything I shouldn't worry about it then? It's already disabled?
Old Mar 25, 2008 | 02:31 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Correct. The stock calibration is defaulted to the shift light on the CCP driver.
RBob.
