Running crappy high rpms...
Old May 20, 2008 | 10:07 PM
v10viper04's Avatar
Car: 84' Corvette, 96' Caprice
Engine: LT1, L99
Transmission: T-56, 4L60e
Axle/Gears: 3.07 POSI, 2.93 Open
My engine seems to run fine until about 4800 rpms where you can literally feel the car stop pulling and run like crap until it shifts.... then starts to pull again... i am wondering considering i advanced my timing a little (like 1-2*) should i be running 91 octane instead of 87? is the 87 causing detonation which in turn would make it run like crap up high?
Old May 20, 2008 | 10:26 PM
90c350's Avatar
Re: Running crappy high rpms...
What are your cam specs? what fuel pressure are you running? Have you had any ecm tuning done? Does it just fall flat or is it popping and backfireing?? Need more info. It could be your cam/heads/valve springs/ tuning etc.
Old May 20, 2008 | 11:21 PM
v10viper04's Avatar
Engine: LT1, L99
everything is stock besides headers and it does backfire sometimes when its not 100% warmer up and when its warmed up it falls flat on its face. BUT when its up there if i let off the throttle a little it will pull again... full out up top it dies.....
Old May 21, 2008 | 09:07 PM
v10viper04's Avatar
Engine: LT1, L99
any ideas?
Old May 21, 2008 | 09:33 PM
90c350's Avatar
Your cam is probably all done by about 4500rpm with a stock setup. You may be runnning lean at the higher rpm with a stock tune. Can you tune your own ecm or are you able to datalog?? You will need a better cam, higher fuel pressure and some custome tuning to get her to run better. What injectors are you using the ones from the 305 or from a 350?? If you have the 305 injectors you will need to increase your fuel pressure or swap to a set of 350 ones. Lots of things that can be done but tuning is needed for the ecm and datatlogging as well. Hope this helps.
Old May 21, 2008 | 10:14 PM
v10viper04's Avatar
Engine: LT1, L99
they are the 350 injectors and i am running the 350 ECM.... i just don't understand why they would even let it rev that high it it falls flat on its face before the shift..? its bad for 0-60 times and accel...
Old May 21, 2008 | 10:40 PM
90c350's Avatar
Gm wasnt to worried about 60' times. You may also be a little lean at the higher RPM range do to your headers/exhaust and intake mods. Even though they are minor. Stock tbi units dont allow for much modding. Try increasing your FP a little and see what happens. Do you have an AFPR?? and what pressure are you running?? You need to get into datalogging to see what is going on though. Do you have a laptop??
Old May 21, 2008 | 11:22 PM
v10viper04's Avatar
Engine: LT1, L99
i might be able to borrow one, i was going to see how the fuel is doing by using the O2 sensor to see what it reads when it falls on its face. should be able to tell if its lean or rich. idk what pressure its running its all stock
Old May 22, 2008 | 01:15 PM
90c350's Avatar
Factory setting should be anywhere between 11-13psi. If your going to be reading the stock narrow band O2 sensor then be carefull because they are not very accurate out of their operating window. Ex-350to500mv would probably be a normall swing point for 13.5 to 15.1Afr.
Azrael91966669
25
Jun 20, 2017 04:04 AM
TheExaminer
Aug 26, 2015 04:59 PM
BBSDesigns
Aug 11, 2015 07:39 PM
bryan623
Aug 10, 2015 11:33 AM
