Question about this open element... ASAP Replies
Old May 23, 2008 | 11:47 AM
RS-Chevy-SS's Avatar
Car: 1989 Chevy Camaro RS
Engine: L30 TBI 5.0L Vortec
Axle/Gears: Stock
Going to go buy the edlebrock open element from auto zone today... heres the question my stock air cleaner has the wire going from the coil to the dist touching it...Its not touching the coil just the wire is....Is this ok? Also when i throw this new element on will it be ok for it to do the same...Im kinda confused as too if the wires touch the thing will it short out...Thanks
Old May 23, 2008 | 12:24 PM
Axle/Gears: Stock
Re: Question about this open element... ASAP Replies
Update after looking at the same air cleaner on summit, it appears to be a drop base...Its the edlebrock 1221 will i have any issues as far as clearance on a 89 RS?
http://store.summitracing.com/partde...5&autoview=sku
Old May 23, 2008 | 12:37 PM
sinisterrs's Avatar
Car: 1991 Camaro RS
Engine: 305 5.0
Axle/Gears: 2.73's
i just put the same element on yesterday it clears you just have to take the spacer ring off from on top of the throttle body .....
Old May 23, 2008 | 12:44 PM
Axle/Gears: Stock
Ok cool so you bought the same one from autozone? What filter did you use? Are any of the wires touching?
Old May 24, 2008 | 01:40 AM
MiScHiEf's Avatar
Car: 88 Formula
Engine: 305 TBI
Acutally with the drop based air cleaners, such as the "1221" the TB Spacer needs to stay on, with it off it conflicted with my throttle linkage, and more. it's the "non-drop" that you take it off.
I also used the Edelbrock 1221, i just had issues getting the wing nut to go on, the rod was too short.
Basically instead of finding a different air cleaner i just found a slightly smaller air filter.
Diameter (in):14.000 in.Height (in):2.813 in, worked perfectly, barely a difference from 3 inches, and clears.
I had some extra dough in my paypal so the $62 didn't hurt me.. flows so much air too, sounds amazing, might even add the "Xtreme Lid" from K&N so it flows some threw the top.
Just see if it clears the coil, and the linkage, if not buy that filter, it'll be worth it
Old May 24, 2008 | 08:09 AM
Rockyd's Avatar
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
i bought the same one from autozone you have to leave the gold ring spacerso it will clear i have no issues of anything touching my cleaner you. i use a k&n filter i just looked around for the round ones i thought would fit and tried them out i dont have the number sorry but you should be able to fine it it is a 3 in. filter i think by 14in. but it works good
Old May 24, 2008 | 07:28 PM
Axle/Gears: Stock
Yeah thanks...I installed it yesterday..I have to ghetto rig the stud to get it to work..I installed the K & N today...All in all I see a big improvement in topend power and acceleration...Feels like it pulls more throughout the revs, What did you use for a stud because im not sure how long this one will hold up....Also i used a plastic spacer instead of the gold ring. The gold ring wasnt big enough for the cleaner it had a little play room but the plastic one is a tight fit...
Old May 24, 2008 | 08:00 PM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
I've used the stock air cleaner stud and ****. Just had to widen the hole in the new air cleaner lid for it to fit. Used a uni-bit but a larger drill bit would probably work. I also used a 2 1/2 inch filter element, can't remember if it made a diff with the stud height or not.
Old May 25, 2008 | 02:22 PM
Axle/Gears: Stock
Yeah with the 3" filter i have right now its wayy to big for the stock stud to work...Its too short...Anyone sell a longer one or how can i get one?
Old May 26, 2008 | 01:42 AM
BronYrAur's Avatar
Car: 91 Camaro RS Convertible
Engine: 305 TBI
Transmission: 5-Speed
I've used a 3" filter, just back out the stud until it's last few threads, it screws out of the throttle body. If it won't back out enough, just bend it.
Old May 26, 2008 | 06:35 AM
DM91RS's Avatar
Car: 91 RS
You brute...
Also if you cannot get any of the above to work go to a hardware store [Home Depot, Lowes, etc] and get a piece of threaded rod of the same size and bend it as needed.
Old May 26, 2008 | 03:03 PM
Axle/Gears: Stock
Originally Posted by DM91RS
You brute...
But the question is how the hell do you bend it? Also does the backing it out untill its last threads thing really safe? Is it a tight fit still?
Old May 26, 2008 | 03:57 PM
DM91RS's Avatar
Car: 91 RS
You a still need several threads to ensure that it does not pull out the threads in the unit itself when tightened.
As far as bending unless you have a vice you will have to be creative. A couple pair of vise grips has been my choice when confronted without a vise in emergency's. I have had one for so long at home and at work I forget what it's like without one......
Old May 26, 2008 | 04:11 PM
Axle/Gears: Stock
Here are some pics of my open element that i just installed along with a small video to let you hear the difference... Edlebrock base from autozone with a K &N 14X3 Air filter Click on the first one to watch the video
Old May 27, 2008 | 09:02 AM
RS305's Avatar
Car: 92 25th Anniversary RS
Engine: 305ci 5.0L V8
i had the same problem and went to autozone and picked up a spectre adjustable stud kit. it comes with a bunch of adapters that should screw onto the stock stud and extend it a little.
Old May 27, 2008 | 01:05 PM
Axle/Gears: Stock
Yeah, I already had bought that and got it to work with a **** load of washers, but I took the advice on the other open element thread and just unscrewed my original stud out a lil and it fit just fine, it gives it a more sturdy feeling then the extender.
Old May 27, 2008 | 01:22 PM
DWH's Avatar
DWH
Car: 1990 RS
Engine: TBI 305
Transmission: 5 speed
sorry if this sounds obvious, i'm new to working on my own cars. alright, so since you have that open breather, does that mean you don't need the air scoop thing that attaches to the filter anymore? cuz i'm thinkin about gettin an open breather. but your pic doesn't have an airscoop, and my car does. obvious answer? probably, but i would like to know none-the-less. if you need pics to clarify, i can easily do that
Old May 27, 2008 | 03:22 PM
DM91RS's Avatar
Car: 91 RS
The air scoop is to deliver cool air to the breather. Most people just remove it to remove clutter and make things purty....
Old May 27, 2008 | 03:47 PM
DWH's Avatar
DWH
Car: 1990 RS
Engine: TBI 305
ight, i think that's what im gunna do. it's a little rusty and looks like dooky anyways
Old May 27, 2008 | 05:53 PM
MiScHiEf's Avatar
Car: 88 Formula
Engine: 305 TBI
Um what do you guys mean by "air scoop" i have the open-element and the breather just sits there like the one in the pic here, i thought about an open breather too.. maybe im just missing something lol
Old May 27, 2008 | 06:34 PM
DWH's Avatar
DWH
Car: 1990 RS
Engine: TBI 305
for ppl without open breathers yet, we have an airscoop and an airhose that connects to the filter
Old May 28, 2008 | 10:53 AM
naf's Avatar
naf
If the stud is not coming through the top of the air cleaner far enough for the 'wing nut' (which looks crappy anyway), using the stock screw by widening the hole in the cover may give you the clearance needed. You'll notice the threads in the stock fitting extend below the lid onto the stud.
Old May 28, 2008 | 11:29 AM
Axle/Gears: Stock
Okay DWH and Mischief you guys are talking about 2 different things. DW is talking about the snorkel that mounts to the body right behind the hood to feed cold air to the stock intake air cleaner assembly, Mischief is talking about the crankcase ventilator that comes out of the passenger side valve cover. Also if you leave the Ventilator just to the side like mine pictured I suggest you wire tire the filter to the plastice housing like I have it. I found that the little filter portion of it kept getting sucked out of the housing and lost. Had to buy a new one to replace the brand new one because of that. Just to clear that up.
NAF,
I got the stock stud to work by simply screwing it out of the Throttle body while still insuring it had enough threads in the TB to make it secure, it works like a champ now with out any extenders.
Old Jun 6, 2008 | 11:16 AM
DWH's Avatar
DWH
Car: 1990 RS
Engine: TBI 305
following up on my posts in this thread. i bought the edelbrock 1221 and i put it on. i'll post pics when i get the chance
Old Jun 6, 2008 | 12:46 PM
Axle/Gears: Stock
Cool. Were you as impressed with it as i was?
MustangBeater20
Oct 29, 2022 09:20 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
dutch930
Sep 11, 2015 06:58 AM
redmaroz
Aug 16, 2015 11:40 PM
wruiz
Aug 13, 2015 09:07 PM
