Throttle Body Spacers
Old Sep 16, 2008 | 08:30 PM
Stu's Firebird's Avatar
Car: 1992 Pontiac Firebird
Engine: 305 5.0L V8
Transmission: Stock
I was searching the summit racing website and I ran across this throttle body spacer. I want to know does anyone think it would fit on a stock 92 firebird TBI 305 V8. It is a 1 inch spacer would it fit and also would it clear the hood? Also, would this put much hp or anything?
http://store.summitracing.com/partde...5&autoview=sku
Old Sep 17, 2008 | 12:42 AM
vorticaldavid's Avatar
Car: 1992 Camaro RS Convertible
Axle/Gears: LS1 posi/disk 3.42
Re: Throttle Body Spacers
yes it will, but you can find these on ebay for much cheaper
Old Sep 17, 2008 | 03:22 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
https://www.thirdgen.org/forums/tbi/...epower-tv.html
Old Sep 17, 2008 | 03:27 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
come on guys, at least you could have TRIED the search function. or just have a look at the recent topics.. this was only posted some days ago, or for the last post, only some hours!
Old Sep 17, 2008 | 07:58 PM
Shakermaker05's Avatar
Car: 1991 RS
Engine: 305 LO3
Axle/Gears: 2.73's : (
Old Sep 19, 2008 | 11:14 AM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
ive never seen any spacer do that much. ill have a spacer on mine wheni put a plate nitrous kit on it.hah
Old Sep 24, 2008 | 09:44 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Other posts say a TB spacer doesn't show any difference. I've done the TBI airflow mod and the injector spacer on my '88 and it seems to idle smoother and respond a little better. Later.
Old Sep 25, 2008 | 12:43 PM
titchener's Avatar
On a stock TBI engine I'm sceptical that these spacers have any benefit, especially on 305's. In the carb world open spacers are used as minor tuning device, adding open spacers improves the high RPM flow a little, bumping the peak torque point up in RPM and if the engine is capable of it, increasing the peak HP a little. If the engine isn't capable of making HP at the higher RPM the spacer will hurt power a little, so dyno tuning is often used to find out if a spacer helps an engine.
On a stock L03/L05 engine, the stock TBI is capable of flowing enough for around 295 HP, and since stock L03's make around 170 HP and stock L05's around 210 HP, it doesn't appear that more airflow is needed with these engines, so I don't see how a spacer will help.
But there could be other reasons for a gain, apparently on some manifolds raising the flow entry point up off the manifold floor a little helps it enter the ports better.
It would be interesting to see a careful back to back dyno test on a spacer, the only ones I've seen made some other changes at the same time so it wasn't clear what affect the spacer alone had.
One thing is certain, if it does have an effect, either good or bad, on a stock engine it won't be very large.
Paul T.
Old Sep 25, 2008 | 03:12 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I just put a TNT spacer on my car a couple of days ago and this is what I have noticed.
The good.
A "deeper" idle . engine at idle sounds alittle meaner.
Better throttle response. Not alot but a noticable improvement
Better midrange torque. The car seems to pull much better in the midrange. Feels snappier.
The bad.
Warmup idle seems alittle poorer, almost like a carb car in a sense. not a big deal though.
Had to cut a hole in my hood. Getting a mustang scoop anyway so it's of no concern to me.
Other than that I'm pretty pleased with mine. It's definatly alittle harder to put on than most people say and make it work correctly. I had to remove the throttle bracket and enlongate the holes about a 1/4 inch to the rear to be able to slide it forward and I put 1/4 spacers under it to correct the cable geometry. I didn't have a problem with the fuel lines so it's all good there.
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
