planning on switching from stock carb to tbi
Old Oct 7, 2008 | 10:54 PM
87z28maro's Avatar
Car: 87 z28
Engine: HO305 with a 4 barrel
so i used the search function and i want to get my facts straight. i have an 87 z28 camaro with the 4 barrel 305HO and i want to do a tbi swap. what i want to do is just grab the intake manifold with the throttle body in tack along with the distributer, wiring harness, computer, all the sensors, and fuel pump. oh yeah ill aslo grab all of the emmission garbage since i live in CA...oh yay smog ***** -rolls eyes- ....so what i need to know. the intake will bolt right to the heads right? will the wiring harness just plug in place of the carb's harness? or will i need to splice wires. any thing else i need? i didnt find any writups so does anybody have a good one?
-joe
p.s. dont know if it makes any difference but it has an automatic....pretty sure its the 700r4
Old Oct 8, 2008 | 02:23 PM
87z28maro's Avatar
Car: 87 z28
Re: planning on switching from stock carb to tbi
bump for the morning crew
Old Oct 9, 2008 | 09:12 AM
87z28maro's Avatar
Car: 87 z28
anybody?
Old Oct 9, 2008 | 09:15 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
You need my manifold and throttle body that I'm selling.
Old Oct 10, 2008 | 02:17 AM
87z28maro's Avatar
Car: 87 z28
lol dont quite have the money for it just yet. maybe in a few weeks. the only tough part im having is so far all of the camaros ive found while scouting the yards are all v-6s. on the plus side i found the iroc hood i wanted to replace the crapped out fiberglass cowl induction hood i had
Old Oct 10, 2008 | 02:24 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Cool.
Not sure about the wiring harness. I would think that the firewall connectors would be similar. Best bet is to research the pin outs. Just find a donor car and pull all the wiring from that goes from the ecm, out near the fender and all the way to the fire wall connector. If the firewall connectors are not pinned out the same, then I would think either changing the pins or taking the entire electrical wiring would be necessary. Since the switches are all in the same place (that is with a Camaro, birds would be different... power mirrors and headlight switches come to mind) estimate a good couple days of work to switch out all the wring. Not too hard, just a bit of time.
Research about the speed sensor (VSS). Some cars have electronic and some have mechanical. Make it easy and get a donor that is the same as yours. Look at the trans and see if you have a cable or wires.
Manifold will line right up. I suggest getting a good, non air gap manifold (edelbrock performer... that will work with CA emissions) and get an adapter plate. Stock manifolds will work, but regular sbc manifolds are cheap.
I got some part stock tbi as well. i just installed a L31 350 with all new top end.
Old Oct 10, 2008 | 02:28 AM
87z28maro's Avatar
Car: 87 z28
Originally Posted by graebz28
Cool.
thank you sir. do you know of any place i can get the pin out diagrams so i can start laying it out? i want to make this as easy of a swap as possible and do it right the first time...unlike my dad with his suzuki samurai but thats a different story...
Old Oct 10, 2008 | 02:42 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Go to sleep! j/k. Library or GM dealership. There have got to be someone online here that has them or has done what your doing. Hopefully some others will chime in. I know someone here put together a disk with alot of info in it. Was only $20 or so, but worth much more.
I think my haynes manual had some info on this. I check when I get back home next week.
Old Oct 10, 2008 | 02:47 AM
87z28maro's Avatar
Car: 87 z28
thank you! and yeah...i have sleeping issues. got used to hanging out with friends til like 3 am then they all moved lol
Old Oct 12, 2008 | 02:31 AM
87z28maro's Avatar
Car: 87 z28
anyone else have some input?
Old Oct 14, 2008 | 08:38 PM
87z28maro's Avatar
Car: 87 z28
bump
Old Oct 16, 2008 | 12:27 PM
fbody5's Avatar
i want to do the exact same thing with my ta good luck let me know how it goes
Old Oct 16, 2008 | 01:14 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
The best and easiest approach is to have a complete donor, which is not always possible. With respect to smog test (we both live in kalifornia) you'll have to go to referee station and declare that you did a complete engine swap from 87 or later passenger car! You can not swap in truck based TBI system (against the rules by eco-*****). Look for any TB equipped V8 camaro or B-body (305 preferred, but 350 can be modified easily).
Get a complete harness, ECM sensors, TB, (i.e everything that's connected to harness ) and transplant onto your HO. You'll need FP upgrade. The key to this is planning...
If your HO is in good shape (near stock) - transplant should yield fuel consumption improvement and drivability.
//RF
Old Oct 16, 2008 | 03:24 PM
87z28maro's Avatar
Car: 87 z28
whats fp upgrade? is that like the programming of the computer? sorry if its a newb question
Old Oct 16, 2008 | 03:59 PM
RFmaster's Avatar
Car: 75 Beast
FP = Fuel Pump
Carb needs about 4 to 6 PSI of fuel pressure to be happy. TB requires 12 to 15PSI, and TPI 40 to 48 PSI. There are many pumps - be careful how you select one.
No problem.
//RF
Old Oct 16, 2008 | 04:32 PM
87z28maro's Avatar
Car: 87 z28
FP = Fuel Pump
No problem.
//RF
ooh lmao sorry. i knew about the puel pump already. almost did a fuel injection swap on the wrangler i owned before my camaro. only reason why i didnt do it was because everything kept breaking on it. my sister killed a set of spider gears, i killed a transmission due to burn outs, snapped a driveshaft yoke, all sorts of fun things. but yeah. this is definately going to be a fun swap.
Old Oct 16, 2008 | 05:25 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
See Brian at tbichips.com He's got a great fuel pump at a great price. Been running mine for a while now and very happy!!
He will do custom chips as well. HIGHLY RECOMMEND HIM!
Old Oct 17, 2008 | 02:40 AM
87z28maro's Avatar
Car: 87 z28
sweet thanks. so about the wiring. does anybody know a place online where i can find a pinout of the bulkhead connectors for both engines? its kind of a long trip to go to a dealership and i dont have the money for the trip right now. 50 miles one way. sux living in a remote area.
Old Oct 17, 2008 | 10:25 AM
RFmaster's Avatar
Car: 75 Beast
There is no bulkhead connector for the ECM harness.
GM used a gromit to pass through wiring harness through the firewall. Take a look at the following two photos of a TBI harness removed from '90 B-Body. Third photo shows ECM to harness connector.
CCC and TBI system shared a lot of circuits between each other. Perhaps it is possible to re-pin existing harness from CCC to TBI. However, IIRC CCC did not use IAC which requires a four wire circuit! So in the end swapping a harness is probably simpler.
Take a look at your ECM and post part number - it should be a 7 digit number starting with 122xxxx.
For your TBI conversion you can use any suitable passenger car ECM for example 1228746 or later 16136965.
//RF
Old Oct 17, 2008 | 02:29 PM
87z28maro's Avatar
Car: 87 z28
are the connectors where each wiring harness plugs into the dash harness the same?
Old Oct 17, 2008 | 02:37 PM
RFmaster's Avatar
Car: 75 Beast
I am not sure - There are probably minor differences which can be readily resolved by comparing the two harnesses side by side. Underdash connections include ALDL I/O connector, SES light, P/N switch and ignition hot. That should be it.
//RF
Old Oct 17, 2008 | 02:38 PM
87z28maro's Avatar
Car: 87 z28
alright cool. i have a friend going towards a dealership so ill try to get wiring diagrams while im down there.
Old Oct 17, 2008 | 03:24 PM
RFmaster's Avatar
Car: 75 Beast
So, which ECM do you have (for your CCC) and which one are planning to use with TBI??
//RF
Old Oct 17, 2008 | 03:32 PM
87z28maro's Avatar
Car: 87 z28
//RF
um...another newb question.... wheres the computer at? and as for the computer for the tbi i was going to use which ever i pull with the wiring harness. hoping to find the manifold, tb, wiring harness, and computer on a camaro around the year of 87.
Old Oct 17, 2008 | 03:35 PM
87z28maro's Avatar
Car: 87 z28
nevermind just went onto autozone.com and found where it is. its gonna take a bit to get the seial number
BRoss99
Aug 10, 2025 05:08 PM
MustangBeater20
Oct 29, 2022 09:20 PM
pimp2303
Jul 27, 2017 02:03 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86IROC112
Aug 17, 2015 02:00 PM
