how much power will I feel in a 90rs f/m intake swap?
Old Oct 8, 2008 | 12:00 AM
mike85's Avatar
Car: 89 camaro rs, 86 iroc-Z, 05 cbr900r
Engine: 305-383
OK, I GOT A NEW TOY, SHES A 90 CAMARO RS 305 700R4. FROM WHAT I SEE SHE IS ALL STOCK EXT. A 14IN HOLLY BREATHER AND SOME DRESS UP. ITS ALSO TBI, I AM GONNA GET THE HOLLY DUAL PLANE INTAKE WITH THE ADEPTER ALL FROM SUMMIT. IM GOING TO THROUGH A CAM AND LIFTER SET IN IT AS WELL. CAN ONE OF YOU VERY EXP. CHEVY GODS GIVE ME A LINK TO A CAM THAT WORKS WELL WITH STOCK HEADS.. I HEAR THE STOCK TBI UNIT IS GOOD 4 300 HP BEFORE YOU NEED THE PROJECTION FROM HOLLY.. I DONT WANNA DO ALOT TO IT AS IT WILL BE LADY DRIVEN BY MY G/F AND MY DAILEY DRIVER, CAR LOOKS AMAZING!! IM LOOKING AT MABEY 400.00 FOR SOME MODS 4 NOW.. IT ALREADY HAS FLOWMASTERS ON IT.(SOUNDS DEEP) WHAT HP #'S DO YOU THINK I CAN GET A LO3 TBI TO WITH 400.00 WORTH OF MODS.. MABEY 260????? ALL HELP AND BETTER PARTS SUGS. ARE WELCOME AND WANTED
Old Oct 8, 2008 | 02:38 AM
92whiteta's Avatar
Car: 86 WS6 Firebird
Engine: 355
Axle/Gears: 2.73 open
Re: how much power will I feel in a 90rs f/m intake swap?
look into the stock lt1 cam it will make good power in a 305. i am getting ready to put one in my 305 tpi. the best part is the cam is cheap you can get one usualy around $50 - $60 if you find the right person.
Old Oct 8, 2008 | 05:54 AM
scottkb1975's Avatar
From: I live in South West Louisiana Born and raised
Car: 92 Camaro and a 98 Z71
Engine: 5.7 in both
Transmission: 700r in the camaro 4L80E in the Z71
Axle/Gears: 3.73/28 spline truck/car 3.73 28 sp
I put the edlbroke intake on mine. Of course I did yank out my 305 now and have a mild stroker in place. I wanted that little more in the peddle. The other guy is right the stock LT1 cam should be banging in it. With the edlebroke intake though you do not have to use the adapter and you will get better performance. You might even beable to run a spacer under the TBI with the edlebrok. I can not I went to a taller filter on my car until I put my cal hood I can not go any higher I am hitting now. They sell the edelbrok on summit.
Old Oct 9, 2008 | 01:06 AM
mike85's Avatar
Engine: 305-383
I MAY BE WRONG.. IM JUST GETTING INTO THE CHEVYS, IVE HAD A IROC Z AND NEVER MODDED IT MORE THAN THE INTAKE AND PULLYS.. TILL NOW.. BUT I HAVE HEARD THE STROKER COMES FROM PUTTING A 400 CRANK IN A 5.7,350?? THERE HAS GOT TO BE MORE, I GOT A 400 SB.. ITS A JUNK RUSTED BLOCK, CRANK IS FINE.. EVEN HEADS ARE FINE.. WHAT WILL THE STOCK 400 HEADS DO FOR THAT TBI 305? HELP IT OR HURT IT? I AM GONNA MEET WITH THIS LADY, YES LADY.. THATS SEXY..LMAO.. I FOUND A LTI CAM ON CRIAGSLIST FOR 75.00, I WENT AHEAD AND GOT IT.. WILL I NEED TO CHANGE THE LIFTERS? OR ANY VALVETRAIN? WILL IT WORK WELL WITH THE STOCK LO3 SETUP? THANKS AGAIN.. OHH AND SINGLE PLANE VS. DUEL PLANE.. WHAT SHOULD I RUN? AND WITH INTAKE DOES NOT REQUIRE THE ADAPTER, I WOULD RATHER IT BOLT UP AND USE A SPACER.. I GOT A 3IN COWL.. KEEP ITCOMING.. WHATS SOMEGOOD CHEAP MODS THAT YOU CAN REALLY FEEL?? THIS WILL BE HELPFULL 2 ALOT OF US.. THINGS YOU HAVE DONE AND FELT A BIG DIFF.
Old Oct 9, 2008 | 01:15 AM
mike85's Avatar
Engine: 305-383
OHH AND IS THAT INTAKE YOUR TALKING ABOUT MADE FOR THE TBI SYSTEM? IF SO IM NOT GOING THAT ROUTE.. THOSE INTAKES ARE STUPID EXP. MY DAD HAS THE HOLLY PROJECTION ON HIS 91 Z28, ITS SNAPPY AWSOME THROTTLE RESPONSE.. JUST LIKE 700.00.. HA I WILL GO OUT A LIL SLOWER AND CHEAPER.. SHE LOOKS GOOD AND FAST ANYWAY..LOL.. SHE A 14 SEC CAR.. HEAVY CHEVY
Old Oct 9, 2008 | 01:49 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Uuuummmm, ok. dude turn off the caps and read the stickies. nuff said.
Old Oct 9, 2008 | 01:58 AM
mike85's Avatar
Engine: 305-383
OK DUDE.. LMAO WTF IS STICKIES?? WHAT IS NUFF? I CANT SEEM 2 FIND THAT IN WEBSTERS...?? THIS IS A TECH SITE FOR CAMAROS, NOT GRAMMER SCHOOL.. BUT I WILL SEE IF TURNING CAPS LOCK OFF WILL GIVE ME SOME HP!! YEA.. THX, BEST upgrade ever.. wow at the diff. ENOUGH SAID
Old Oct 10, 2008 | 10:43 AM
All right I was sayin turn off the caps because it's the equivalent to screaming on the web and if you look at the top of this board you will see where the stickies are. Where it says "STICKY" Smartass.
Old Oct 10, 2008 | 12:05 PM
mike85's Avatar
Engine: 305-383
I STILL DONT SEE ANY STICKEYS.. I SEE AVOID CAPS LOCK ON IN TITTLE, IF THIS IS LIKE ME SCREAMING.. READ TO YOURSELF.. YA ARE NOT GIVING ANY IDEAS.. I DONT NEED SOMEONE TO TELL ME HOW TO TYPE, YEA IM A SMARTASS.. THE BIGGEST AND BEST IN SC!!!
Old Oct 10, 2008 | 01:18 PM
vette9190's Avatar
Car: 1991 Chevy Camaro RS
Transmission: 700R4,
Axle/Gears: 3.73 w/SLP Zexel Torsen Limited Sli
robertfrank
I modded my TBI before I changed to TPI.
But I don't think helping rude and inconsiderate people is what this board is for. Its for helping nice and decent people.
YES!!! Using caps when posting on the web is considered screaming this is common knowledge to any intelligent person who has used the internet more then once. It called etiquette. look that one up in websters.
The "sticky" is a post located at the top of each forum. Some have multiple stickies. they are clearly labled as such. They are posts with answers to common questions that have been asked hundreds of times. Also try the search forum feature you'd be surprised at how quickly a little effort on your part will go to helping you.
OH AND IF YOU WANT HELP AROUND HERE DON'T BE A SMARTASS WORD GETS AROUND AND NOONE HELPS SMARTASSES.
Old Oct 10, 2008 | 05:45 PM
Ok, obviously you're a child so I will explain this to you like I would my children.
First, Look at the top of the screen of the TBI forum
second, Look about an inch down the page where it says "sticky threads" in the bold black line
third, read them. simple enough.
If you want help on how to make your car faster we will be more than happy to do so. BUT........... If you come in here like a "Red Bulled" up 15 year old kid who has a ******** complex then that will get you nowhere. So..... calm down with the attitude, be alittle more polite and we will help you.
Old Oct 10, 2008 | 06:50 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
STOP YELLING!!! Settle down.... Lose the caps.... There is plenty of information at your disposal on this site and in this area of the forum.
Old Oct 11, 2008 | 02:11 AM
mike85's Avatar
Engine: 305-383
Yea ok. I told you there not at the top of every page, You have to look for them, but the other dude did use a proper word. Bot anyway, Being as nice as can be, I have had alot of wrong info, (really none has helped yet) I work on cars, atv's, motorcycles... typeing correct is my last concern... but if it makes all the peace, Sorry dude, I think you should say the same.... You could have told me how to find that from the start, But ohh well.. but my intake, duel plane vs. single?? whats the pros and cons???
Old Oct 11, 2008 | 04:30 PM
OK since you've chilled out I'll give you a hand. There have been MANY threads on the subject of "dual versus single" and it really depends on what you want out of your car. Dual plane intakes are better suited for the street and provide better lower to mid RPM power and torque in most cases. Single planes are better for people seeking more higher RPM power. TBI doesn't suffer from torque loss from single planes like carb vehicles do. If tuned in right from what I understand they perform pretty well. BUT........ If you want alittle more power out of what you have now I would recommend either the Eddy 3704 or the Performer RPM intake. Both are dual planes and the 3704 is a direct replacement where as the RPM I believe you have to elongate the 2 center holes of the intake to get them to bolt up correctly.
Another question is what exactly do you want out of your car? A peppy daily driver? A strong 305 or a more street strip vehicle?
Old Oct 11, 2008 | 06:04 PM
vette9190's Avatar
Lots of guys who run TBI like the lt1 cam it a direct bolt in for our cars its a mild cam but a big step up from the little peanut cam that comes in the engine. I would recomend this its about the biggest cam you can use with the stock heads. And speaking of heads THe LO3 in the car came with swirl port heads they flow for s*** I would change them . you cam probably get both the cam and some 081 Tpi heads cheap from the boards here check the classifieds or post in the parts wanted section. those mods with any of the intake recommended here should help pick the pace up on this car nicely.
by the way i picked up a lt1 cam for $45 and 081 heads for 30 here on the boards so the heads need to be cleaned up but for less the 200 your lookin at pretty decent gains in power.
Also if your gonna do more then a few mods you will need a custom chip burn
but not a generic aftermarket unit check out the prom burning sections for more on that
Old Oct 11, 2008 | 07:51 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I had a 1990 305 TBI - Did every mod in the book, including new intake, headers, LT1 cam, 1.6:1 rollertip rockers, ported/polished #416 heads, etc, so on - and what I learned was 1) there isn't much you can do without a custom chip, 2) it's next to impossible to get a custom chip made without getting the equipment, taking the learning curve, and doing it yourself, and 3) you still don't "feel" much of anything from it all.
305 mods aren't for daily driver rides - there's too much needs tweaked after a mod to be able to drive it daily (ie. you'll have more than a single day of downtime with the car, o if you need the car tomorrow, don't mod it today).
Wanna feel it something - spend the cash on better rear end gears! TBI cars come with 2.73 peg legs, swap in a 3.08 or 3.42 posi rear end and you'll feel much more than any engine mod will give without alot of time and headache. That's a one day swap, cheap, easy, and gives way more "feeling it".
Old Oct 11, 2008 | 08:56 PM
mike85's Avatar
Engine: 305-383
Yea i heard the heads are sh!$.. So I already have a set off a 98 gmc denlui, All I know is that the are vortec heads, I picked them up for 100.00 so If they wont work.. ohh well.. lol.. I was told they will bolt on and preform decent. It is a dailey driver, I just need more power, I lost a race for 500.00 vs. a lti impala.. UHGGG So i need more, I lost by a fender.. Im only looking to make mabey 300 hp, oh it has 3.73's and its spins both tires everytime, No one wheel peel here.. lol.. Thanks everyone!! Keep them coming!!
Old Oct 11, 2008 | 09:53 PM
vette9190's Avatar
vortec heads require a vortec specific intake and have 64cc chambers versus 58cc on the stock heads.
Old Oct 11, 2008 | 11:16 PM
I have to slightly disagree with this as far as the 081's. They really aren't any better than the swirlies unless ported and even then the stock heads make more torque. I know I ***** this thread out alot but I did alot of research for this.
https://www.thirdgen.org/forums/tbi/...-synopsis.html
I hope this helps.
Old Oct 11, 2008 | 11:44 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I hope this helps.
I agree here, the 187s will beat out the 081s until about 4,500 rpm with most cams. The 081s require more spark advance and fuel for the same output, which means fuel consumption will be higher as well.
Old Oct 12, 2008 | 03:35 AM
mike85's Avatar
Engine: 305-383
Thanks again!! About how much would it cost me to have my heads breathe better? Or should I look for others? I can get the stock tpi, 86 iroc heads cheap, they any better? I have a hard time finding any valve covers for my car because of the bolts being in the top.. where do I look, well, I need diff heads.. Or should I have mine done, I can also get a set of world prouducts heads for 600, but was not wanting to spend that at the moment.. any suq..
Old Oct 12, 2008 | 07:26 AM
Car: 1992 RS
Engine: Carbed 350
If you lost by only a fender, that LT1 was in dire straits anyway. I own a 1990 305 TBI with all the mods, a 1992 with a 350 carb and a ton of mods, and also own a 1997 Z28 with a LT1 - Trust me - You'll never beat a decent running LT1 with a 305, at least not economically. It could be done, but the time and money invested in it would be - unless it was a project car, you have unlimited time/cash to throw at it, and are extremely bored! There's no replacement for displacement - the lesson learned here is to not race a 305 against anything for cash! Wanna throw cash away? Invest in Wall Street!
I'd say leave the g/f's car alone, and get yourself a project that isn't required to be driven daily so you can spend the time and effort required to go out and lose your cash & your license street racing - women are particular about having a decent running car. Keep playing with hers and you'll be out a car AND a girlfriend!
Old Oct 12, 2008 | 08:33 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
With a few parts, you can beat a stock LT1 with a 305 easily. Think twice before picking on a lowly RS with your LT1.
http://www.chevyhiperformance.com/te..._ii/index.html
Old Oct 12, 2008 | 10:00 AM
I have owned my car for over 5 years and it's been DD'ed for the entire time and I know from experience that with good planning you can do MANY mods to a 305 daily driver in one day and not have alot of down time. I have to do alot of my mods in either one day or over a weekend because I need the car to go to work. The longest my car has been down was a week and that was when I gutted my engine harness. So if you have everything you need and not have to go back and forth to the parts store to get stuff it can be done.
Old Oct 13, 2008 | 06:19 AM
mike85's Avatar
Engine: 305-383
has alot to do with the driver, I eat him out the hole, Bad.. he slowley catches up in a 1/4.. with his stock rear, my posi, and 200 more in mods.. i can kill him all day
Frozer!!!
Jan 19, 2024 04:55 PM
gta90
Sep 15, 2015 04:00 PM
InfinityShade
Aug 22, 2015 08:00 PM
flash2042
Exterior Parts Wanted
Aug 7, 2015 05:58 PM
