Spectre Plenum
Old Feb 9, 2009 | 11:36 PM
Gladstoneiroc's Avatar
Car: 91 Camaro RS
Engine: 5.0L TBI (ebl inside)
Axle/Gears: 3.42 lsd 10 bolt
Spectre Plenum
Will the 4" tall plenum fit under a stock camaro hood?
Old Feb 24, 2009 | 08:21 AM
Car: 91 Camaro RS
Re: Spectre Plenum
Looks like it will easily. Now, I need to plumb a duct from the plenum to the tpi air box and relocate the IAT sensor.
Old Feb 24, 2009 | 10:24 AM
Ronny's Avatar
Re: Spectre Plenum
Not so cold air! I needed to use a one inch plastic riser. Bought ebay. some in 3.5 inch and 2.00 inch height I recall. 3.5 would not clear my hood. The 2.0 inch plus riser did. well not really it is about .1250-.1875 too high. My glass hood has a buldge in it. I think bulge better than stock! I could not determine a place to mount for better cold air. Suggestions welcomed.
Old Feb 25, 2009 | 04:45 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Re: Spectre Plenum
Gladstone is that the 4" tall spectre on a stock L03 and under a stock hood?
Old Feb 25, 2009 | 06:44 AM
Car: 91 Camaro RS
Re: Spectre Plenum
Well, it is a L03 with ported stock parts, so it retains the the same height. Stock hood without insulation.
Old Feb 25, 2009 | 06:57 AM
ownor's Avatar
Engine: LS1 / L03
Re: Spectre Plenum
That's interesting, thanks for the insight. i definately need some kind of CAI for my formula.. is this the Spectre plenum p/n 9841?
JEGS says it's 3.5" tall and has a 4" single inlet.
Old Feb 25, 2009 | 05:07 PM
Car: 91 Camaro RS
Re: Spectre Plenum
I'll check the part number when I get home. I'm not sure how I am going to convert from 4" to 3" and span over the serpentine belt. I might have to put 3" exhaust pipe to couple between adapter and hose.
Also does anyone have a picture of how the IAT sensor is routed when mounted into the tpi/v6 camaro air box? I want the wiring to look close to stock and I'm not sure what angle was taken.
Old Feb 28, 2009 | 07:18 AM
ownor's Avatar
Engine: LS1 / L03
Re: Spectre Plenum
hi, got the p/n for me? thanks!
Old Mar 6, 2009 | 10:01 PM
Car: 91 Camaro RS
Re: Spectre Plenum
Sorry about the delay, the part number is 9841. I'm think that I can build a build a better system with: a 4" to 3" coupler; to abs plastic 3" tube; to 3" coupler; to tpi air box. I would have finished tonight, but Home Depot is on winter hours and closed at 9pm.
Old Mar 6, 2009 | 10:11 PM
Car: 91 Camaro RS
Re: Spectre Plenum
This coupler versus this coupler.
ABS plastic pipe about 9 feet too long.
Three inch to three inch coupler
, similar piece at Advance for $12.
Old Mar 6, 2009 | 11:55 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Spectre Plenum
As long as your using a stock intake or a low rise carb intake, it will fit. With aftermarket intakes with high rise plenums, there is typically not enough clearance.
Old Mar 7, 2009 | 04:16 AM
ownor's Avatar
Engine: LS1 / L03
Re: Spectre Plenum
thanks for the p/n as well as your other suggestions and thoughts. that definitely sounds like something to look into. i'll be using a performer tbi so i'll check and measure the height compared to a stock intake, but i'm sure there's not much difference.
can you use the IAT in EBL to compensate for the cooler air? @dimented, that was an interesting post you wrote over at the open element thread.
Old Mar 7, 2009 | 07:42 AM
Car: 91 Camaro RS
Re: Spectre Plenum
You might be able to go with the 2.4" tall one, but the inlet may hit the water outlet.
Old Mar 7, 2009 | 11:45 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Re: Spectre Plenum
I managed to get an xtreme velocity carb hat to fit with the performer RPM and TBI adapter plate. Its close, but it clears. The hat I have is about 3.5" tall or so (I can measure later if need be). One thing you may need to do is use a bolt instead of a wingnut. I remember that being an issue that there was not enough room for a wingnut.
I dont have any pics, but I do have a video of the setup after I put my TKO in and re-installed the EFI. http://www.youtube.com/watch?v=Gv7c-...eature=channel With the hat facing forward, there was enough room for a 3.5" MAF sensor and cone air filter. Tight fit, but it did clear the water neck. In the summer, I reinstalled teh TPI airbox to keep the incoming air temps within reason.
In the winter, you may want to run a cone air filter within the engine compartment to keep the temps up. TBI does not like extremly cold air. IIRC, the EBL has the blended CTS/IAT term to compensate for the changes in incoming air temp. It wont be perfect, but it can go a long way to helping correct the fueling when its cold out.
Old Mar 10, 2009 | 06:46 AM
Icarus 402001's Avatar
Car: 92RS
Re: Spectre Plenum
Going to open element in January actually reduced my throttle response and dropped my mileage from 24 mpg to 21 mpg. The only change I made was removing the TPI air box. This was throughout January this year with 10-20 degree temps outdoors. That is contradictory to expexcted results.
Old Mar 10, 2009 | 09:14 AM
ownor's Avatar
Engine: LS1 / L03
Re: Spectre Plenum
what is it that you guys are referring to as TPI airbox
can't figure out how you would use it with a TBI.. pics appreciated
Old Mar 10, 2009 | 03:07 PM
Car: 91 Camaro RS
Re: Spectre Plenum
Previous post about cadillac/tpi hybrid.
Old Mar 18, 2009 | 01:03 PM
Car: 91 Camaro RS
New pictures
I do not have any vehicle results yet, but I show later this week after I fabricate my new belt tensioner.
Old Mar 20, 2009 | 04:57 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
Re: Spectre Plenum
Looks great.
Was you original intent to use 3.5" tubing? I am just wondering why you went with the 4" spectre piece rather than the 3".
I want to do the same, but I do not think I can with a bird. My old formula had tpi, but it used the canister type filter. I really want to go ram air, but that is still kind of pricey for me.
Old Mar 21, 2009 | 05:39 AM
ownor's Avatar
Engine: LS1 / L03
Re: Spectre Plenum
yeah it's a nice setup! but as graebz mentioned, i don't think it can be done with a bird.
which ram air options are you talking about - ram air hood? (they're ugly, too!)
Old Mar 21, 2009 | 12:33 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Re: Spectre Plenum
Yeah, but you could add a few 90s and run it to threw the battery tray on either side. I did that with my last TPI motor rather than using a bird TPI canister.
Old Mar 22, 2009 | 08:36 AM
Car: 91 Camaro RS
Re: Spectre Plenum
Well, I wanted to use tubing that would match well with the tpi box, so I chose 3". With these adapters, the path of the air looks to be relatively smooth as their is not many changes in diameter.
I remember reading somewhere on this site, that the tpi air box did not show to be a restriction until 320 - 350 hp. However, if anyone could put any flow data on it, that would be appreciated.
This picture is clearer and shows the modified belt tensioner.
Old Mar 23, 2009 | 11:44 AM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Re: Spectre Plenum
Yeah the hood. I guess those hoods are love/hate. Some love the 4th gen LT1 style, others the 98+ LS1 version, and some hate them both. I love the look of the 98 TAs with the RA hood, so I kind of want that look on my old bird. It does not look nearly as cool as the 4th gen, but I hate to own a car that I need to drop the motor from underneath.
toronto formula
19
Oct 6, 2015 12:27 PM
italiano67
Sep 22, 2015 08:42 AM
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
