TBI HELP
Old Aug 5, 2009 | 11:09 PM
log93pow's Avatar
Car: 91 Camaro RS
Engine: Carbd 355
Axle/Gears: Currently 2.73
TBI HELP
I just rebuilt my tbi that belongs on my 88 chevy truck. Ya i know its not third gen related but the same tbi came on camaros. I have been having fuel leak probs with the tbi so i got the master rebuild kit which includes about everything except the diaphram. I put it all together and put it back on truck. Truck starts up but instead of the injectors spraying fuel they just drip. I went back and checked the little filter and o rings at the bottom of the injectors and they are fine. So i tried a different set of injectors i had from a different tbi. Put the new filters and o rings on and they still drip instead of spray like they are supposed to. If i dont figure somethan out i am going to throw the piece of junk in the yard and buy an intake and carb for it. Thanks
Old Aug 5, 2009 | 11:12 PM
quickkris2006's Avatar
Car: 1991 camaro vert
Engine: ls1 soon
Transmission: t56 soon
Axle/Gears: moser 12bolt 4.10 soon!
Re: TBI HELP
if u do decide to carb it u dont have to buy an intake manifold.. just a carb adaptor plate.. i have no clue y they would just drip. i havent taken mine apart
Old Aug 5, 2009 | 11:31 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
Re: TBI HELP
maybe its not the hardware but the wiring did u plug the injector plugs back on? and if not could have a wiring problem check main fuses
Old Aug 6, 2009 | 12:43 AM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
Re: TBI HELP
I did that after my rebuild. I couldn't understand why she wouldn't start up for about five minutes ah ahahaha.
Old Aug 6, 2009 | 11:34 AM
log93pow's Avatar
Car: 91 Camaro RS
Engine: Carbd 355
Re: TBI HELP
Thanks for the info guys. I guess ill go check the fuses
Old Aug 6, 2009 | 04:12 PM
Flip66's Avatar
Re: TBI HELP
did you check the fuel pressure
Old Aug 6, 2009 | 06:42 PM
log93pow's Avatar
Car: 91 Camaro RS
Engine: Carbd 355
Re: TBI HELP
No havent checkd fuel pressure yet
Old Aug 9, 2009 | 03:23 PM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Re: TBI HELP
Check fuel pressure first. Unplug the injector wiring harnesses off the top of the injectors. Take a 9-volt battery and quickly tap the electrodes and listen to see if you hear a clicking noise. Do this to both injectors individually.
Also, go to the parts store and buy a noid light. Plug this into your injector harness and see if it lights up. Following instructions!!
Either no fuel pressure, no injector pulsing or the injectors are stuck.
Old Aug 17, 2009 | 01:43 PM
ChevyCJ7's Avatar
Car: 1986 Jeep CJ7
Engine: 1987 Chevy 350 TBI
Transmission: TH350
Axle/Gears: Dana 44 Rear, Dana 30 Front-for now
Re: TBI HELP
Hi Everyone!
I have a Chevy 350 TBI (out of a 1987 3/4 ton truck) in a Jeep CJ7.
The throttle linkage was a mess when I got it. Replaced TBI from RV Moorse in Orange, CA.
Of course took it apart and now am having trouble putting all of the hoses and wires to and from the wires from smog stuff, intake manifold (Front & rear of intake hooking up the hoses). Can someone help with some simple step by step photos?
Thanks,
Ken
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
