good cam
Old Nov 11, 2009 | 02:10 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
good cam
HI there i am wanting to swap in a 350 in my car but i am also wanting to mod the 350 before i swap it into my car. My question is which cam would work good with stock lifters since i already bought some but i will replace the pushrods if i have too. So which cams do you guys think i should run or should i spend my money on something else.
Old Nov 12, 2009 | 06:25 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
Re: good cam
what kind of power do you want to make?
Roller or flat tappet lifters?
how much can you spend?
Old Nov 12, 2009 | 10:33 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: good cam
I am wanting some extra power to beat the tpi at least, as the price i really don't care as long as i could use my stock lifters i bought, they are rollers hope this helps also its gonna be a daily driver forgot to mention that
Old Nov 12, 2009 | 10:38 PM
ericjon262's Avatar
Re: good cam
what all is done to the car/ engine?
Stock heads?
stock intake?
headers?
Old Nov 12, 2009 | 10:48 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: good cam
I am going to install a L98 engine block all stock right now and some 2460 headers as the intake maybe a edelbrock performer and put a adapter plate not sure
Old Nov 14, 2009 | 08:41 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: good cam
Dont know how much this can help, but in the post are some cams that I am considering, lately the compcam's 08-500-8 and 08-408-8. I wanted to do the same thing with a L98, but since the engine came with remanufactured 193 casting heads instead of 083, I will probably be using some aftermarket heads.
Though according to the posts in the TPI forum, the L98 TPI folks are using even thougher cams then the ones I mentioned.
https://www.thirdgen.org/forums/tech...un-350-dd.html
Old Nov 14, 2009 | 04:43 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: good cam
Would those cams that you put work with my stock lifters
Old Nov 14, 2009 | 05:56 PM
thomas1976's Avatar
Car: 91 Trans am
Re: good cam
Im sure the stock roller lifters work perfect.
Old Nov 14, 2009 | 08:33 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: good cam
OK what about the springs should i replace those and would i need to modify anything for that cam
Old Nov 15, 2009 | 06:09 AM
thomas1976's Avatar
Car: 91 Trans am
Re: good cam
I think screw in studs are a must over 0.470 lift.
http://www.maxchevy.com/tech/2007/ii_12-stud-1.html
The LT4 stile retainer should be ok around 0.500 lift. Do a little search for some exemples.
Check out at compcams with the cam # for the correct valve springs.
Old Nov 15, 2009 | 02:18 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: good cam
I am gonna have to stay with the stock cam since i will have to replace my engine already since oil is going through the rings
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
junkcltr
Aug 2, 2019 11:12 PM
camaro71633
Sep 1, 2015 10:24 AM
cstrobel65
Aug 15, 2015 10:19 AM
TreDeClaw
Aug 14, 2015 06:58 PM
