5.0 build
Old Dec 11, 2010 | 10:15 PM
8732's Avatar
5.0 build
before i go blowing money on a 5.0 rebuild. here are somethings i need to know
should i just get a regular rebuild kit and stock replacement connecting rods or should i go with the forged set up on a 305?
keep tbi or swap a carb with the edelbrock torker intake and lunati cam both operate at 2500-6500 rpm. would that be too much for the 305?
i never really modded an engine so what would be good mods for this tired 305 to bring it back to life. its got a knock in it. the onlything done to car so far is magnaflow exhaust with tips and what looks to be new ypipe and a holley open element air cleaner.
someone please help me
Old Dec 28, 2010 | 02:27 PM
gheatly's Avatar
Car: 1982 Z-28
Engine: 5.7L Crossfire
Transmission: TH-350
Axle/Gears: GM Posi, 3.73
Re: 5.0 build
I would get a good rebuilt short block and spend as much money as you can on a good set of heads. A pair of Edelbrock Performer or Performer RPM can had for around $1000. If you have the dough, go for AFR 180cc heads.
You might also consider building a 350 instead of the 305. Won't cost any more and you'll have 50 extra CID. If you go this route, you will need to learn to tune, but if you want more power with the 305, you'll be in the same boat.
ALL stock GM connecting rods are forged. Unless you run nitrous or a supercharger, you don't need forged pistons.
I think a good TBI 350 would be great, and a lot of people on the site have done it before and can help you out.
Old Dec 28, 2010 | 02:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 5.0 build
If you put a carb on it, use any intake except the Torker.
Old Dec 28, 2010 | 05:11 PM
8732's Avatar
Re: 5.0 build
Thanks for the help I think ill get the 350 but is there any way I can stop the knock in the 305 untill i get done the 350? Also can I use different distributors with the tbi?
Old Dec 28, 2010 | 06:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 5.0 build
If it's already knocking, then it's already dead.
Old Dec 28, 2010 | 08:18 PM
gheatly's Avatar
Car: 1982 Z-28
Re: 5.0 build
Agree, engine likely already dead.
You need to use a computer controlled distributor. Should be able to use the one on your 305. Just check for wear. Likely will need a couple of shims to get the shaft end-play within spec.
Old Dec 28, 2010 | 08:28 PM
8732's Avatar
Re: 5.0 build
Crap looks like ill dump everything into 350. Any recommendations on shift point for a tach on the 305 so I can use shift light
Old Dec 28, 2010 | 11:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 5.0 build
On a dead engine, I'd recommend 0.
steimel94
Sep 23, 2015 12:48 AM
anesthes
Sep 21, 2015 10:24 AM
steimel94
Sep 20, 2015 12:46 PM
Mr. Chevy
Sep 11, 2015 06:06 PM
