Please help, so fed up with this car
Old Jan 17, 2011 | 05:18 PM
crazymonkey16's Avatar
Car: 1990 Camaro RS
Engine: L05 TBI
I'm seriously considering junking this thing. It used to run fine, and now I can't get it to do more than crank. I changed cap and rotor, set the timing, replaced plugs and wires, it ran fine, then all of a sudden it just died. I haven't been able to start it since. One of my injector fuses was blown, so I replaced it, still nothing. I checked all my wires, ohm-tested my injectors, replaced the fuel filter, checked fuel pressure, it was good, checked my ignition coil, everything checks out... what on earth am I missing? The security system is working fine, checked all that out... what else is there? Somebody please help, i need this car to run, it's my daily driver, and if I can't get it on the road I'm gonna have to junk it and buy a new one... i'm sure it's an easy fix because it ran so well before, but I feel like i've checked/replaced everything and it's still not running... even if you just have random ideas, please throw them out here. I'm seriously desperate.
Old Jan 17, 2011 | 05:30 PM
bigj350's Avatar
Car: 88Fbird,88Formula,04 GP,04 Durango
Engine: LO3,L98,3800,HEMI
Transmission: 700r4, 4l60e, 545rfe
Re: Please help, so fed up with this car
Did you test the ignition module?
Old Jan 17, 2011 | 06:27 PM
Car: 1990 Camaro RS
Engine: L05 TBI
Yes, I tested the ignition module, it seemed to check out.
Old Jan 17, 2011 | 06:42 PM
bigj350's Avatar
Did you take it somewhere to be tested to be sure?
Old Jan 17, 2011 | 09:19 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What was the fuel pressure when you tested it?
Old Jan 17, 2011 | 10:34 PM
DROBECO's Avatar
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
so the car fired and ran after you changed the cap and rotor? and then died?
always remember. fuel. spark and air check first to see if you're getting fuel i assume you are since you said fuel pressure was good, then check spark you can pick up a spark plug tester at a local auto store or you can back yard mechanic it up and pull the plug and get your friend to test it against metal a rubber handled screwdriver works best for that.
Old Jan 17, 2011 | 10:54 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
bad computer
Old Jan 18, 2011 | 09:46 AM
Ronny's Avatar
pickup coil?
do you get a blink of CE then soild when you place ign on-engine not started?
Old Jan 18, 2011 | 10:56 AM
Car: 1990 Camaro RS
Engine: L05 TBI
See, that's the thing - my fuel pressure checked ok, but that's what i'm not getting... my plugs are sparking just fine. We can get it to start with starter fluid, but as soon as it burns through the starter fluid it dies.
Old Jan 18, 2011 | 11:38 AM
bigj350's Avatar
I know you checked the pressure and the ohms but have you checked to see if the injectors are actually spraying? Also, is possible you may have too much moisture in your tank? It happens. I had a durango that did that once in a while during the winter.
Old Jan 18, 2011 | 10:28 PM
Engine: gone
Transmission: gone
Axle/Gears: gone
Probably bad ignition control module. I know you had it tested. screw those tests. It controls injector firing as well as spark. And i have seen them miss either one or both. replace it. Its going to go out eventually anyway. Throw in a new one and if it fixes it good. if it doesnt. You have a spare throw it in your trunk area for someday when it goes out.
Old Jan 18, 2011 | 11:27 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
injector fuse blew for a reason-sounds like there is a
wiring or ECM problem,check for battery voltage at the
injectors-they are supplied with voltage with the ignition
on and the ECM grounds the other side to actuate them.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
