my car cuts out and surges at idle when its warm? need help
Car: 1991 rs 305 1992 rs 350 1988 350 tb
Engine: 305 carb , 350 carb , 350 tbi
Axle/Gears: stock
My car (1988 rs with a 350 tbi motor) when i first start it from a cold start it'll idle a little high for a while then go down (but drives great) and after it warms up it will have a fluxuating idle. when i drive it it'll start to cut out either like its getting too much air or too much feul, in the last week i have replaced alot of parts trying to fix this problem such as : spark plugs, temp sender, tps, iac, both injectors, feul regulator, map sensor, feul pump, feul filter. i am running out of things to replace.
any ideas? i just bought the car 2 weeks ago and when i got the car it had a leaking injector so it ran really rich, could it be an 02 sensor causing this problem?
any ideas? i just bought the car 2 weeks ago and when i got the car it had a leaking injector so it ran really rich, could it be an 02 sensor causing this problem? Supreme Member
Engine: gone
Transmission: gone
Axle/Gears: gone
Re: my car cuts out and surges at idle when its warm? need help
im battling a similar problem. but mine is at idle. it'll bounce then die. I have changed numerous parts to no avail. any reputable automotive repair facilities in your area you can possibly take it too?
Sometimes the tps can be changed but may not be functioning properly. has to have certain parameters.
It is possibly your ignition control module is malfunctioning. it is about 45 dollars new (although I do recomend buying an AC DELCO version, which could be more).
Check the grounds carefully, esp. the ecm grounds at the back of the heads.
Check the coolant temp sensor resistance at different temps.
The tbi base gasket has known to go bad & cause a vacuum leak.
The tps is slotted, it has to be set to the proper voltage.
Engine: gone
Transmission: gone
Axle/Gears: gone
The tps on my car is not adjustable.
Axle/Gears: stock
my tps isnt adjustable either, i ran some codes and i got a map sensor code, but my map sensor is brandnew im going to check the ground for it and maybe make my own ground.
The reason i replaced temp sensor is because when the car was running bad i could un plug it and it would run fine for about 2 minutes then it would act up again but even since iv replaced it its still acting the same. same with the map sensor i will unplug it and it will run okay for a bit then go back to running like s**t.. maybe bad grounds on each of them, i also wanted to check to see if my vacuum hoses where hooked up in there correct spots is there anywhere i can find a vavuum diagram?
thanks for the help guys,
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
Check the map sensor vacuum line
Axle/Gears: stock
iv replaced it... along with the other vacuum hoses.
Did check the connector for power?put your finger in it a turn the key.JOKE.Get a test light and check it out.
Axle/Gears: stock
yes its getting power and proper ground
Car: 1989 RS
Engine: 305 tbi-mild build
Im having sort of the same problem. except i got rid of the idle problem with bad plug wires. Now it wants to cut out and sputter with no power when i go down the road. The engine just wants to fall on its face. Think it could be my timing or that module? Ive never checked my timing before.
db057
Aug 11, 2015 10:11 PM
