305,081's and a lT1 cam
Old Jun 4, 2011 | 05:05 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
I have been reading through all of the threads and I have pulled together a 305, (1)081 cylinder head and a lT1 cam (191/196 B body replacement cam, and a 705 LT1 cam 201/201). I have a set of TPI manifolds with air tubes (required here) that have the 2.25 exhausts (I bought these several years ago). I plan on pocket porting the 081's.
Will this rebuild of this engine be a good combo power-wise? I will be using a 3" cat and dual mufflers (2.5")
Old Jun 11, 2011 | 11:52 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Re: 305,081's and a lT1 cam
Probably not much over stock even if well tuned. I wouldn't do it. A pair of headers will probably yield more power.
Old Jun 11, 2011 | 01:42 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
well the cam will build more power for sure. but it'd be nice to just go ahead and change the heads to a better flowing head and put some emission legal headers on there.
Old Jun 11, 2011 | 09:41 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
This is POOR advice!!! The 081s really don't flow much better and suffer on the exhaust side compared to the 187s. You will LOSE power everywhere under 5,000 rpm with the LT1 cam.
Old Jun 11, 2011 | 11:07 PM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Wow, thanks for the advice.
Old Jun 11, 2011 | 11:17 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Just realized I worded that weird. The LT1 cam is a GO with chip tuning, but I was talking about the 081 heads would lose you power with only the LT1 cam. You can make some AWESOME torque with the LT1 cam and Swirlies. The best addition for a stock L03 is a full exhaust system from the head ports out and don't use parts designed for a L03.
Old Jun 12, 2011 | 12:18 AM
gwarren007's Avatar
Car: 1992 RS
Engine: 305 (LO3)
Axle/Gears: 2.73?
Would you use the 2.25 Tpi manifolds if you already had them?
For the 305 engine:
187 heads (have)
97 LT1 cam 201/207 (have)
305 .030 over (have pistons and rings)
Stock intake, tbi air inlet CAI
run stock injectors with Caprice 350 fuel pump, but up pressure to 15-18psi?
Old Jun 12, 2011 | 01:58 AM
Engine: gone
Transmission: gone
Axle/Gears: gone
fast I said the cam will build more power and i would change the heads to a better flowing head. I didnt give an exact example I know but I did not mean run the 081's by any means. Can you please reword that otherwise everyone will assume im a complete idiot. (i know i am but anyway)
Old Jun 13, 2011 | 10:44 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Honestly I wouldn't even bother getting an LT1 cam after using the ZZ4 cam. It's not hard to tune in and it made a big SOTP improvement over the peanut cam. Just make sure you get a good stall and gears with it.
Jake_92RS
Jan 28, 2020 10:37 PM
midge54
Dec 27, 2019 04:14 PM
Street Lethal
Apr 30, 2019 12:14 PM
beastin91rs
Oct 9, 2015 07:38 AM
theurge
Aug 21, 2015 12:46 PM
