Bad gas mileage after tune up
Subscribe
Sep 21, 2011 | 03:24 PM
I used msd coil and distributor cap. New autolite platnium spark plugs and borg warner spark plug wires.
Why am I getting worse gas mileage on my tbi camaro?
Reply 0
Sep 21, 2011 | 03:58 PM
Re: Bad gas mileage after tune up
Quote: I used msd coil and distributor cap. New autolite platnium spark plugs and borg warner spark plug wires.
Having any other issues? weird idle, loss of power etc?
Reply 0
Sep 21, 2011 | 04:14 PM
No just the engine stays really hot 210-220 the power is ok most of the time depending on the weather it gets 80 here and at night 40s. Idle is fine
Reply 0
Sep 21, 2011 | 04:28 PM
That a normal temp for your engine?
I would make sure your plug gap is correct. Also make sure you don't have wires mixed up.
Reply 0
Sep 21, 2011 | 04:42 PM
The gap I used was the one under the hood and yes my engine always runs about that until the fan brings it down a bit. My wires are ok it sounds smooth.
Reply 0
Sep 22, 2011 | 06:30 PM
you're not suppose to gap platnium plugs...
Reply 0
Sep 22, 2011 | 06:45 PM
Yeah whatever. Gap them carefully. Hey say you shouldn't but be careful. Never had a set be correctly gapped. Always one off. Drive it more. Use different gas and let us know what happens
Reply 0
Sep 22, 2011 | 07:24 PM
ditch the platinum plugs they foul too easily for these old engiens to run. If you dont feel a misfire. Then you shouldnt have your wires crossed. that is all you did?
Reply 0
Sep 22, 2011 | 07:40 PM
What was your gas milage before and what is it now?
Should of asked that first.
Reply 0
Sep 22, 2011 | 09:44 PM
Before it would go a tank a week and now it uses a quarter of a tank to drive 9 miles.
Reply 0
Sep 22, 2011 | 09:54 PM
Uh 9 miles for almost 4 gallons of gas?
Reply 0
Sep 22, 2011 | 10:13 PM
Thats beyond horrible. I would put regular plugs in it and see if that makes a difference.
Reply 0
Sep 23, 2011 | 01:02 AM
did you do the fuel filter? sure its not leaking fuel out of it? because 2.25 MPG isnt bad. its horrific. cannot be right
Reply 0
Subscribe
