Hedman Headers
Old Nov 6, 2011 | 03:49 PM
NeNick95's Avatar
Engine: 5.0 TBI
Hedman Headers
A simple question i don't know but I've been interested in these Hedman Headers from SummitRacing and I wonder if I could replace my exhaust manifolds. But I dont know if it would effect my emissions or is a waste.
Old Nov 10, 2011 | 06:22 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Axle/Gears: 2.73 Open
Re: Hedman Headers
If you got the Hedmans you'd probably have to weld the AIR tubes on in order to make them emissions compliant, but if your state doesn't check thoroughly you'll be fine without them. If you have an EFI car you will have to weld in an O2 bung though- or you could get collector connectors with an O2 bung already welded in
Old Nov 11, 2011 | 10:46 AM
Ronny's Avatar
Re: Hedman Headers
find headers that are emishions complient? with air tubes...
Old Nov 11, 2011 | 11:20 AM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: Hedman Headers
But the ones with AIR tubes cost a good amount more- it's far cheaper to fab your own AIR system if you have a friend that's good with a welder and don't live in California.
All the AIR tubes do is supply additional air to the cat during cold starts, so they're pretty worthless
Old Nov 11, 2011 | 11:26 AM
Ronny's Avatar
Re: Hedman Headers
emishions testing..
Old Nov 11, 2011 | 12:05 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: Hedman Headers
Doesn't matter if they don't look under the hood. I know in MD they just hook up the sniffer and if you pass you're good to go
Old Nov 11, 2011 | 04:25 PM
NeNick95's Avatar
Engine: 5.0 TBI
Re: Hedman Headers
Ill try those out then Thanks for helping
Old Nov 12, 2011 | 10:45 AM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Re: Hedman Headers
Hooker 2055's have them. You should also consider going to a 3" cat and cat back too. Uncork some power.
Old Nov 12, 2011 | 03:35 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: Hedman Headers
Yeah that's the thing with the Headmans, the only Y-pipe they make that fits the headers has a 3 inch single out, so you have to either dump it before the axle or cut the Y-pipe and weld a 3 inch pipe in place of the 2.5 inch pipe
Rousseau92maro
Feb 1, 2016 05:12 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
redformula88
Oct 14, 2015 06:08 PM
italiano67
Sep 22, 2015 08:42 AM
