TBI 400
Old Nov 26, 2011 | 12:41 PM
ryan.1e's Avatar
Car: 1986 Camaro IROC Z-28
Transmission: t56
Axle/Gears: Stock Axle, 3.23 rear gears
TBI 400
have a question that i haven't found an answer to elsewhere. has anyone ever heard of putting a tbi fuel injection system on an old chevy 400sb? i can tell you it runs, but it won't time correctly nor will it idle. i'm thinking that the 350 computer and a set of 24lb/hr injectors aren't enough, but the 454 components seem to be too much... to the extent that the 454 parts make the 400 run so rich it looks and sounds like a deisel. with the 350 parts after the engine warms up it runs fine, but i don't have time to wait for it to warm up.
Old Nov 26, 2011 | 01:26 PM
ex-x-fire's Avatar
Re: TBI 400
The stock tbi injectors are rated around 62lb/hr. The 24s your talking about are for a port inj. system like a tpi or lt1.
You either need to replace your fuel pressure regulator w/ an adjustable one or make yours adjustable, look on the web for that.
Check your fuel pressure, your pump might be weak, most guys replace tbi pumps w/ tpi pumps. With a tpi pump, more fuel is returned to the tank via the return line, so over pressurizing isn't a problem.
I don't know if your running an open element air cleaner, they are harder to run in cold weather, as some tbi system don't have an air sensor, even then it won't cure a cold stumble. You might have to run a stock air cleaner w/ a working hot air tube durnig the cold months.
Old Nov 26, 2011 | 03:36 PM
big hammer's Avatar
Car: 2002 ws6, 2011 sierra 6.2L 6 speed
Engine: ls1
Transmission: M6
Axle/Gears: 3:42's
Re: TBI 400
word. a little more fuel pressure via tpi pump and adjustable regulator may just be the ticket.
i always wondered how much low end torque a 400sb would make with swirl port heads and a tbi...
Old Nov 27, 2011 | 11:20 AM
ryan.1e's Avatar
Transmission: t56
Re: TBI 400
i can tell you, once the 400 is warmed up, i'm scared to think what more it could do with more than stock equipment... it already will break both tires free in all 5 gears . on a dyno the engine pushed 396hp and 415tq @ 5250rpm and 46000rpm respectively at 6500ft. on a side note, i've replaced both the fuel pump and installed a manual regulator... then took it back off and replaced a spring in the factory regulator, and it didn't change the cold issue. it runs better with the stock parts... i'm thinking i just need to get a new chip burned specifically for this engine, or put a holley avenger or hp efi computer in and be done with it.
Old Nov 27, 2011 | 12:22 PM
ex-x-fire's Avatar
Re: TBI 400
Do you adjust the pressure using a gauge?
Old Nov 27, 2011 | 01:58 PM
ryan.1e's Avatar
Transmission: t56
Re: TBI 400
made adjustments in 1 psi intervals from 10psi to 35psi (35 being far over anything neccessary for a tbi system) it ran progressively worse. all things considered, i am seriously considering it being a timing issue. going to look into some of the tuning applications.
Old Nov 27, 2011 | 05:51 PM
ex-x-fire's Avatar
Re: TBI 400
Tee up a vacuum gauge to the map sensor hose, I bet your cam is too wild for tbi. You'll want atleast 17" or more at idle. You might try the fitting at the brake boaster so you know its 100% manifold vacuum, not ported. You might also be able to advance the timing too, this'll help make more vacuum. These are really senstive to low vacuum & they usually run rich.
Old Nov 27, 2011 | 07:49 PM
ryan.1e's Avatar
Transmission: t56
Re: TBI 400
nothing says frustrating like having 22" of vacuum and completely unable to adjust the timing without killing the motor... past 4 degrees of advance it dies, less than 4 degrees of advance and vacuum falls off sharply and the engine dies before you get to 2 degrees... the timing is advanced/retarded by the computer based on throttle position, rpm, and knock sensor imput... the service code that is flashing is the basic diagnostic mode... i wonder if the knock sensor is causing the problem... too bad it wont even start without the bloody little bugger.
Old Nov 27, 2011 | 07:50 PM
ryan.1e's Avatar
Transmission: t56
Re: TBI 400
holley avenger or hp efi here we go.
Old Nov 27, 2011 | 10:08 PM
xch3no2's Avatar
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Re: TBI 400
A 46mm throttle body to provide necessary air,
http://rvmorsemachine.com/product.htm
The ECM to run it,
http://www.dynamicefi.com/EBL_Flash.php
Old Nov 28, 2011 | 03:32 PM
Ronny's Avatar
Re: TBI 400
needs a tune. A corrected prom.
Verify your injector # on top of injector. should be visable. Provide your max est. HP and we can suggest the fuel pressure needed.
Old Dec 4, 2011 | 02:59 PM
gregs78cam's Avatar
Car: 1978 Camaro
Engine: 385 Dual TBI, '7427
Transmission: 4L80E
Axle/Gears: 4.10, Posi
Re: TBI 400
If you have 22" of vacuum, then your cam is not the problem. I agree with Ronny, what injectors do you actually have? That number needs to be set correctly in the ECM/PCM. What computer are you running? If you have a relatively stock cam in it, which sounds like the case, then setting the injector specs correctly should get you really close. Also do not adjust the timing at the distributor. The engine timing should match the base timing in the chip.
Old Feb 9, 2012 | 08:32 PM
ryan.1e's Avatar
Transmission: t56
Re: TBI 400
Finally, finally, finally. thanks to a little (long effing time) searching for the right bloody gm truck, i have a 1974 400 sb chevy running a stock style throttle body fuel injection system. after finding the computer and injectors from a 1990 gmc seirra 3500 with a 454 and a manual tranni, i can focus on the paint. can't wait to actually get this car out on a section of road longer, straighter, and paved to see what it can do.
Old Feb 10, 2012 | 10:31 PM
ryan.1e's Avatar
Transmission: t56
Re: TBI 400
Saturday to bring a day of asthetic work and some tuning. if the weather is nice, i may take it out on a road run to see how she does... we'll see
Old Feb 11, 2012 | 10:29 PM
ryan.1e's Avatar
Transmission: t56
Re: TBI 400
And a nice Saturday for it to snow it was. Maybe tomarrow will work out to play around outside.
Old Feb 18, 2012 | 10:00 PM
bluers91's Avatar
Car: 1991 RS Camaro
Engine: 350 TBI
Axle/Gears: 3.42 Posi
Re: TBI 400
If you had an ebl flash you could really fine tune it. Sounds like it will be a nice setup.
Old Feb 18, 2012 | 10:16 PM
EagleMark's Avatar
Re: TBI 400
I've never seen a stock car with more than 19 inches of vacuum, how did you get 22 with a cammed motor? Something is wrong?
If you have a CEL well you need to fix that first...
Also never seen 24lb TBI injectors so need to find out what you really have? I don't have any 4.3L TBI injector numbers but this is a start...
5235279 - White / Green - 5Opph (overrated @ 55pph) - 5.0L / 305 Cars/Trucks
5235206 - Orange / Black - 61pph - 5.7L / 350 Cars/Trucks
17084327 - Yellow / Brown - 65pph - 5.7L / 350 Police Package
5235231 - Red / Blue - 80pph - 7.4L / 454 - 88-90
17084304 - Black / Blue - 76pph - 7.4L / 454 - 91-93
17104288 - Pink / Purple - 46pph @13psi - 7.4L / 454 - 94-95 *used @ 26-32psi for 67-72pph
Old Feb 18, 2012 | 10:18 PM
gregs78cam's Avatar
Car: 1978 Camaro
Transmission: 4L80E
Re: TBI 400
Computer from a '90 GMC w/manual trans will probably be a 1227747, which is ok, but you should look into swapping in a '6395 or '7427 from a '93 or '94 truck, much faster datastream and MANY more paramters to tune with.
Old Feb 18, 2012 | 10:32 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: TBI 400
my 92 rs with stock engine, ultimate tbi, shorty headers, magnaflow catback, and no ac or dash vacuum hooked up has 21" of vacuum. figure that is why i get great gas mileage at 23mpg.
Old Feb 19, 2012 | 12:39 AM
EagleMark's Avatar
Re: TBI 400
That is fantastic vacuum! Possible at sea level, I keep forgetting I am at 2000 feet so 19 - 19.5 is max here. 19 to 21 is possible on stock engines. Lower at higher elevation... Or your vacuum gauge a little off. His would be way off!
Point was 22 inches of vacuum from a big cammed motor is not right. 396 HP engine on dyno? No way he has 22 inches of vacuum... or 24lb injectors...
Last motor I did with 375 HP on Dyno was 80lb BB injectors set to 16 PSI to get enough fuel for WOT High RPM without going lean. Played with timing, min air setting, idle to 850 and got 15 inches vacuum at idle.
Also are you disconnecting timing set wire before setting timing? Has to be dis connected and with big cam 4 degrees should be fine, but then must put that amount back in Initial Timing setting in bin file or you will have to much timing at top. Intial timing in stock bin is set to 0.
That will also set a code, clear codes, start engine.
It is a lot of work to tune TBI system for big cam engine. No way it will ever run good on stock bin...
Old Feb 19, 2012 | 12:43 AM
EagleMark's Avatar
Re: TBI 400
Colorado springs elevation 5870–7200 ft so I think he meant 2 inches vacuum with that motor!
Old Feb 19, 2012 | 07:54 AM
one92rs's Avatar
Car: SOLD!!!!!
Re: TBI 400
im thinking his is a little off. i think he put in the wrong number or he is taking vacuum while at high idle but i still dont see it.
and yes sir i am at sea level. and the car runs great as well. and it darn well better with all the work i have done on it.
Old Mar 10, 2012 | 09:08 PM
ryan.1e's Avatar
Transmission: t56
Re: TBI 400
not quite. after replacing the tach and the exhaust so i could hear the motor i found out that it was "idling" at 2000 rpm, in colorado springs. the cam is just a rv cam, nothing too wild or special. now that i have gotten a few more of the bugs worked out of this monstrosity of a headache, i can tell you that at 6500 ft. i am sitting about 14lbs of vacuum at ~800rpm with the distributor set at 4 btdc. it runs smooth, but is a little sluggish. the injectors in the throttle body are too corroded to read the numbers so i'm not going to worry about it. it runs and for now, thats what i need, now that it's drive-able i dropped it off for paint. in a couple of weeks, i'll be ripping the 400 out and putting a 383 mill with a holley powered tpi.
i started out to see if it would work, i'm pleased to say that with a few of y'alls' help it does, now it's time to get serious and do it right. post some pictures when i get around to it.
Old Mar 10, 2012 | 09:10 PM
ryan.1e's Avatar
Transmission: t56
Re: TBI 400
btw one92rs, are those actual vette rims or aftermarket knockoffs? if real, did you have any fitment or clearance issues?
Old Mar 10, 2012 | 09:19 PM
ryan.1e's Avatar
Transmission: t56
Re: TBI 400
Yeah, maybe next time i take the bloody muffler off and make sure the tach is working right before i play with timing or vacuum.
not a big cammed motor, and 39 was a typo, never caught that, thanks. 296 was the dyno measurement.
yeah, again, i had the wire disconnected, the bad thing is with it connected the engine wouldn't start at the time.
this is my first foray into fuel injection, and i learned a lot about how this stuff goes together. now that i know, what not to do, and i did it without blowing up an engine in the process, now i will spend the money to build the car right and make it worth driving.
Old Jul 2, 2012 | 05:24 PM
ryan.1e's Avatar
Transmission: t56
Re: TBI 400
New chips, new sensors, throttle body, wiring harness, fuel pump, headers, and no field problems/ work bs to deal with... and i have a 400sb running with "factory" tbi. only been really driving it for 2 days. will post part numbers, pics, and maybe a video later. all i can say is it's been a bitch, but these last two days have made it worth it. haha.
Old Jul 2, 2012 | 08:11 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: TBI 400
my wheels are voxx misano wheels. they are not vette wheels. they were bought for an 04 gto so the offset is totally different. 1.5 spavers front and 1.25 rear.
Old Aug 28, 2012 | 05:15 PM
ryan.1e's Avatar
Transmission: t56
Re: TBI 400
thanks! they do look great
Old Sep 17, 2012 | 02:08 PM
ryan.1e's Avatar
Transmission: t56
Re: TBI 400
So, now that i have 1, found a cherry 1986 iroc, and 2 have come to own a ls1 and k-member for it, i am now selling my 90 rs with the 400 sbc and rebuilt t-5. anyone interested send me a PM. I am asking $4,000 for it, however any reasonable offer will be considered.
Hotrodboba400
Dec 10, 2019 07:07 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
Glowsock
Sep 11, 2015 11:09 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
