TBI VRFPR
Old Dec 8, 2011 | 05:04 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Axle/Gears: 2.73 Open
TBI VRFPR
How does one go about converting their stock FPR unit into a vacuum referenced one? I've done quite a bit of searching and have not yet been able to find anything concrete on this procedure. The best I've been able to find is thomas1976's thread https://www.thirdgen.org/forums/tbi/...rfpr-pics.html But no specifics are provided
I've also read that some TBI vehicles came with stock VRFPR's- is this truth, and what vehicles could I find one on?
Thanks!
Old Dec 9, 2011 | 12:09 PM
Ronny's Avatar
Re: TBI VRFPR
GM sells or once sold VAFPR. I think was a marine application? Check rock auto or gmdirect....
Try turboCity for aftermarket.
Or Aeromotive has the best unit at higher cost.
Old Dec 9, 2011 | 08:05 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
I found a place online that sells them for $55 but being the cheapskate that I am I'd really like to fabricate one. I just can't figure out how the vacuum helps regulate the fuel pressure so if anybody has pictures/diagram of a VAFPR I can probably figure it out from that
Edit: And am I looking at the wrong site, or does turbocity sell nothing for our cars nowadays?
Old Dec 12, 2011 | 12:57 PM
Ronny's Avatar
Re: TBI VRFPR
Manifold vacuum under the diaphragm allows the diaphragm to reduce the FP by pulling down on diaphragm and the needle valve attached to diaphragm sealing the pathway to the return . WOT or 100MAP(no VAC) allows the diaphragm to increase the FP opening the pathway. I would go to aeromotive site as they may have some diagrams.
Old Dec 12, 2011 | 01:14 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TBI VRFPR
Pull the regulator off the TBI unit. On the side of the housing is a slot, need to cover that up. Can solder a strip of metal over it or such.
Drill a small hole in the cover and attach a small tube. This is connected to full time vacuum.
Will need another way of preventing the spring seat from rotating, that is what the slot was for. Although reducing the length of the tab on the seat may work. As a strip of metal soldered to the shell would still leave a shallow slot.
Of course make the regulator adjustable while working on it.
Do you have a spare TBI regulator to look at? I can post some pictures if not.
RBob.
Old Dec 12, 2011 | 03:24 PM
Ronny's Avatar
Re: TBI VRFPR
here is some info on GM VAFPR. part #'s photos and such
http://z28boy.cz28.com/main.htm
Old Dec 12, 2011 | 04:36 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
Awesome, thanks for all the info guys! Right now my FPR is off so I'll be able to know what you're talking about.
Now I just need to figure out how to get these injectors out (getting them cleaned).. is there something special I should be doing? or is it just the fact that it's 40 degrees here and everything's slightly contracted?
Old Dec 12, 2011 | 04:43 PM
Ronny's Avatar
Re: TBI VRFPR
could very well be cold temps. Once the top is off they generally come right out. Be care putting them back in. Oil the O ring.
Old Dec 12, 2011 | 05:10 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
I'll assume that's it then and I'll try again tomorrow. I even went at them with a damn vice-grip (I used padding of course), but I didn't pull really hard for fear of breaking them.
Also, I'm looking at the FPR now- I totally see what you mean RBob. I can definitely do that.
Old Dec 12, 2011 | 07:57 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: TBI VRFPR
i looked at doing that to. then i went to the external regulator route. it has a vacuum connection on it to use it also.
Old Dec 12, 2011 | 08:36 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
Your engine bay is soo clean.
I'd probably go with an external FPR, but they're so damn expensive. The only ones I could afford are the Cheap 1-140 PSI FPR's that are for sale on ebay all the time, and that looks like a potential recipe for disaster
Old Dec 12, 2011 | 08:53 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: TBI VRFPR
yep they are not cheap at all. i paid around 120.00 for the reg alone. another 25.00 in fittings. and i think the block off plate i have was 20.00 also.
Old Dec 12, 2011 | 09:08 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
Yeah haha. That's a sizable chunk of money for me that I could put towards rebuilding those heads I'm going to get. Time to see just how handy I am with a soldering torch
Old Dec 13, 2011 | 07:49 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TBI VRFPR
To get the injectors out use a flat bladed screwdriver and a piece of round metal. The piece of metal needs to be about 1/4" in diameter (round screwdriver shaft works).
Lay the round piece on the top of the pod, then use the screwdriver as a lever, tip goes under the center post while using the round rod as the fulcrum.
RBob.
Old Dec 13, 2011 | 05:05 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
RBob.
Worked like a charm.
Now when I solder the regulator I'm assuming I should use copper?
While all this stuff is out I might as well buy a bigger torx bit and take the throttle body off for porting
Old Dec 14, 2011 | 03:49 AM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: TBI VRFPR
Could also use fiberglass and resin if soldering is too much of a hassle.
Old Dec 14, 2011 | 07:08 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
Actually soldering would be easier for me, as I have everything I need to do that.
I'm guessing I should replace the diaphragm and gaskets as well? It's not brittle but it does look worn compared to the new ones.
Old Dec 15, 2011 | 09:58 AM
Ronny's Avatar
Re: TBI VRFPR
My diaphragm was 22 years old when it failed. car sat for months on end by prior owner w/o stabil. It failed cause I dead headed the spring and my TPI pump threw 45 lbs at it!
LOL
Old Dec 15, 2011 | 10:40 AM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
LOL
Haha well then I'll put off the diaphragm replacement. I just didn't know if the higher PSI would kill it (High will probably be around 30) or if a new one would be more effective.
When I get home I'll take the dremel tool to the FPR for a smooth and polish. My friend's going to give me a bigger Torx driver so I'll work on the throttle body this weekend.
Should I plug up the stuff in the car with a shirt or something? I walked by it last night and noticed the air smelled like gas. It hasn't gotten above 60 for the past few days though, so I don't think it's evaporating TOO much....
Old Dec 17, 2011 | 09:39 AM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
GODDAMNIT. Drilled too far through and ended up ripping the whole damn thing out. I couldn't see where the cap ended so I went right on through.. time for a trip to the junkyard.
Edit: Maybe all hope isn't lost. I just came across this on Ebay (pic below). (The one thomas1976 is running). It looks like the vacuum line on this one runs out the part I messed up. I'm thinking that I could run the line out the bottom, the same way, and shim the inside of the FPR with washers in order to achieve the desired spring pressure.
I got some info from the http://www.fl-thirdgen.org/tbiafpr.html and it turns out I should replace my FPR diaphragm while I'm out it.
Old Dec 18, 2011 | 08:22 AM
thomas1976's Avatar
Car: 91 Trans am
Re: TBI VRFPR
That is easy and works, only downside, requires removal to change FP.
I use the stock spring seat on top of the shims, just in case the spring would want to go sideways.
Old Dec 18, 2011 | 11:35 AM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
That's something I hadn't thought of; I will make use of the stock seat then.
And I know I'll have to remove the FP, but I figure that I can deal with that little hassle to save a few bucks. Plus, it requires far less fabrication than the other setup would.
Just out of curiosity, how much would a fully modified TBI sell for? Like VRFPR, ported throttle body, shaved throttle shafts, flow-tested injectors, and modified IAC port (pending one92rs's test)? I like doing this stuff and could use a little extra income.
Here's a rough sketch of an idea for a VRFPR that retains the adjustment screw with a vacuum port- This would have been pretty damn nice if i didn't f*ck up my first one.
Old Dec 18, 2011 | 02:35 PM
thomas1976's Avatar
Car: 91 Trans am
Re: TBI VRFPR
That is the basic concept of the VRFPR, I always wondered how well the adjusting screw would seal. Maybe something simple, like an extra rubber cap could do the trick, though there is little place to work.
Old Dec 21, 2011 | 01:12 PM
JohnBlazeLTZ's Avatar
Car: 1993 Caprice LTZ
Engine: 350 TBI
Transmission: 4L60 (700R4)
Re: TBI VRFPR
Hey... just so you know FAST355 would know all about this...
Old Dec 22, 2011 | 08:16 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
I've actually been reading his stuff lately (especially the ported 193 thread). It would be pretty nice if all of his threads could be consolidated into 1 mega-thread on TBI performance.
Looks like with my 55 lb/hr injectors I'm going to have to get the 12-40 psi spring from tbiparts.com. Putting my order for that and the new regulator diaphragm in tonight.
Old Dec 24, 2011 | 03:16 PM
camarorsssss's Avatar
Car: 1991 camaro rs convertible
Engine: Built ls1
Axle/Gears: 3:42
Re: TBI VRFPR
I am currently using an external vrfpr and believe my system is not plumbed right or the regulator is bad. I have 20 psi fuel pressure but when i give it throttle the pressure drops, but isnt the pressure supposed to increase with throttle increase? I am asking becuase if its the case where its the regulator i might be looking into doing what this board is discussing.
Old Dec 24, 2011 | 04:54 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
Camarosss, I couldn't answer your question- maybe someone else can
But here are the pictures of the finished product. It looks a little rough but I'll go at it again with solder and a file to smooth it out. I first filled in the hole with solder, then used a drill press to make a hole for the barbed brass piece($4 at Lowes), put the piece in, and then soldered the middle of it to the end of the FPR to keep it in place.
I then cut a piece of a tin can , secured it to the hole with some flux and then dropped solder over the edges.
The diaphragm and spring from tbiparts.com will be coming in next week. Everything cost me $50 in total, a savings of $45-50 over the pre-made unit.
- pics to come soon -
Old Dec 24, 2011 | 08:02 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: TBI VRFPR
have you put a pump in the tank that is better than stock (tpi) instead of using the stock pump?
Old Dec 24, 2011 | 08:52 PM
ex-x-fire's Avatar
Re: TBI VRFPR
Camarosss, make sure your hook into manifold vacuum, not ported vacuum. Make sure you have the inlet/outlet on the right side.
It should be lower psi at idle then increase alittle as you open the throttle.
Old Dec 24, 2011 | 09:14 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
So what hose should I hook mine up to? I was thinking about the one that should go to that pointless thing on the air cleaner- is that ok?
Here are the pictures promised
Old Dec 24, 2011 | 09:29 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: TBI VRFPR
like stated before it needs to be hooked to manifold vacuum. when the car is running around everywhere at normal levels vacuum will be present. when you floor it then the vacuum will be gone which will raise the fuel pressure. from there atmospheric pressure and vacuum will push and pull the fuel in making performance. my suggestion is to use some sort of air fuel ratio type information gauge. with that you will be able to dial the correct pressure in and getting it running perfect.
Old Dec 24, 2011 | 10:03 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
I'll look for the manifold vacuum port tomorrow. The Whatsup display on EBL should do the job for tuning. Next step: hit the junkyard and get a TPI fuel pump and look for a set of Vortec 305 heads
Old Dec 24, 2011 | 10:35 PM
one92rs's Avatar
Car: SOLD!!!!!
Re: TBI VRFPR
here is a pump. the same one i used.
http://www.ebay.com/itm/NEW-AC-DELCO...ht_1857wt_1270
Old Dec 24, 2011 | 11:02 PM
Ron_90's Avatar
Car: '90 RS
Engine: 305 TBI
Re: TBI VRFPR
Thanks, saves me the time I'd have spent looking for a good fuel pump.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
