I think its flooding
Old Jun 15, 2012 | 11:30 PM
camarowhiters's Avatar
Hi
I have a 90 rs all stock. The problem i am having is when i try to start the car it wants to start but then it seems to flood. I did have a code on the dash and it said the egr was bad. I have done some research and it doesn't sound like the egr can make it happen. I can look at the throttle body while turning over and the injectors are constantly putting fuel in the motor. Then i look at bottom of throttle body and it seems there is fuel coming out from where it is bolted on the motor.
Any thoughts would be greatly appreciated.
Old Jun 17, 2012 | 02:13 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: I think its flooding
As for the fuel flowing out, if it is between the manifold and the bottom of the TBI unit, the base gasket is dried out and needs to be replaced. Check that it isn't flowing out of the throttle shaft bores first.
A stuck open, or partially open EGR valve will cause the engine to be hard to start and will run lousy at low speeds.
A bad CTS (coolant temperature sensor) or connector can cause the engine to flood while cranking. The connector pieces tend to corrode and when they do the ECM thinks that the engine is colder then it really is and adds additional fuel.
RBob.
Old Jun 17, 2012 | 03:09 PM
UnderCover89TBI's Avatar
Engine: gone
Transmission: gone
Axle/Gears: gone
I think Rbob hit that nail flush on the head.
Old Jul 15, 2012 | 05:55 PM
I want to thank all of who replied to my thread. I have finally got around to replacing the sensor and also had to replace the plugs and other stuff. Although the plugs were ok i felt with the flooding the plugs were needed. I went ahead and replaced the egr because that is the only code i was getting. It runs fine now thanks again
Old Jul 15, 2012 | 05:56 PM
Thank you for your reply i replaced the sensor and other stuff it appears the sensor was the culprit.
Old Jan 16, 2013 | 02:49 PM
Brandong-91rs's Avatar
i think im having the same problem i was out driving one day and came out of a store car cranked up as usual and then died. after having it towed back home i noticed when i turn the key over it dumps loads of fuel into the motor and will not start and if it does start i have to hold my foot down on the gas and even then it idles really rough and dies out again. any ideas anyone???
Old Jan 16, 2013 | 05:45 PM
ex-x-fire's Avatar
The coolant temp sensor might be bad or have a poor connection.
Old Jan 16, 2013 | 05:51 PM
dads old blue 9's Avatar
Car: 1990 z28
Engine: 5.0
Transmission: t-5 wc
Axle/Gears: 4th gen 3.42 posi
yes I think the line in the tank (rubber) that conects fuel pump to metal pick up has a large split , even though you can see fuel in the tb its not getting enough this happened to me and its common and Quite misleading without checking the pressure with a gague . can you get it started and feather the pedal to keep it running? if so than that feul line is the culprit
Old Feb 6, 2013 | 03:14 PM
Gary 48's Avatar
Car: 1991 GTA
Axle/Gears: factory
I am having a similar problem. My 91 GTA TPI cranks fine and runs for the first few minutes ok and then begins to flood out.
Old Feb 6, 2013 | 05:34 PM
ex-x-fire's Avatar
Put a fuel pressure gauge on it, see if it holds pressure when the engine is off. Or see #7 above.
Old Feb 7, 2013 | 09:47 AM
Gary 48's Avatar
Car: 1991 GTA
Axle/Gears: factory
Thank you for the reply. I will try both the fuel pressure and the temp sensor.
Old Feb 8, 2013 | 08:38 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Once the pump stops running TBI systems don't hold fuel pressure.
RBob.
Old Feb 9, 2013 | 02:23 PM
Gary 48's Avatar
Car: 1991 GTA
Axle/Gears: factory
Ok, I changed the temp sensor and I also found a ground wire that had broken and fixed it. I took the car for a drive this morning and it ran great.Thank you guys for the help. When I got back, I turn the car off. I went to move it and it now it does not want to crank. I can hear the pump priming, I opened the fuel line and it has fuel to the fuel rail. I checked to make sure I had fire to the plugs and it does. What is next?
Old Feb 9, 2013 | 02:54 PM
ex-x-fire's Avatar
What does "does not want to crank" mean? Does the starter turn the engine or not?
Old Feb 9, 2013 | 03:22 PM
Gary 48's Avatar
Car: 1991 GTA
Axle/Gears: factory
This car has always cranked with out even turning a full revolution. Now it spins over and does not even attemp to crank. This happened last night also and befor i took it this morning it did the same thing and all of a sudden it cranked right up and cranked up several times during my ride today.
I just went out to the shop and the car cranked right up 5 times with out a problem.
Old Feb 9, 2013 | 04:01 PM
ex-x-fire's Avatar
So we have to replace "crank(ed)" with start, so we can understand your problem.
Check for spark & look to see if the injectors are spraying, you might have a bad ignition module.
Old Feb 9, 2013 | 05:58 PM
Gary 48's Avatar
Car: 1991 GTA
Axle/Gears: factory
I have spark. Does the ignition module control the injectors also.
Old Feb 9, 2013 | 06:32 PM
ex-x-fire's Avatar
The ecm gets a reference from the distributor to fire the injectors, are they spraying?
Old Feb 10, 2013 | 07:40 PM
Gary 48's Avatar
Car: 1991 GTA
Axle/Gears: factory
Is their some way to tell if the injectors are working with out taking the intake and fuel rails off?
Old Feb 10, 2013 | 08:21 PM
ex-x-fire's Avatar
Well your under the tbi board, so you can't check them like a tbi b/c you have a tpi, you'll need to get a noid light to check them.
Zane Story
Oct 8, 2015 12:40 PM
Wade787b
Sep 29, 2015 01:15 PM
jtmiller92
Jul 14, 2001 09:48 PM
Metalman
Carburetors
Jun 1, 2001 09:00 AM
82camarov6
May 3, 2001 07:43 AM
