TBI acceleration
Old Sep 12, 2012 | 11:00 PM
Bulldog75's Avatar
Car: 1991 Pontiac Firebird
Engine: 5.0L 305
Transmission: automatic
TBI acceleration
There seems to be a lag or delayed reaction when hitting the gas. How to I get faster response time when accelerating? 305 TBI with a drop in air cleaner and 3" pipe straight high flowmaster exhaust
Old Sep 13, 2012 | 12:04 AM
rsmith085's Avatar
Car: '88 Camaro
Engine: L03 TBI
Transmission: WC T-5
Axle/Gears: 7.625 10 bolt stock 3.08's
Re: TBI acceleration
Could be a number of things.
First if the plugs, cap/rotor, fuel filter and wires haven't been replaced in awhile always start there.
TV cable could be out of adjustment not letting it downshift http://www.cpttransmission.com/tech_tvcable.htm explains the procedure better than I can it's been awhile since I've messed with one.
Yes a open element air cleaner makes quite a noticeable difference especially above 3000rpm
The exhaust on these cars sucks pretty bad being a single 2 1/4" pipe but without swapping the manifolds for headers your not going to gain a lot considering the motor doesn't rev very high and the cam is horrible.
The factory tune is pretty bad. It runs the engine quite rich and they don't run very much spark advance you can advance the timing at the distributor to 2 maybe 4 degrees BTDC but you'll need to run 93 and I wouldn't go more than 4 degrees because it'll start to knock at cruising rpm and the computer will pull out timing
The stock gear set is excellent for gas mileage but horrible for performance being an auto their 2.73's. Doing it on the cheap get a posi 3.23 or 3.42 from a fourth gen out the j/y.
Check out all the stickys at the top of this forum there's a ton of info on getting more hp out the TBI
Old Sep 13, 2012 | 09:59 AM
Bulldog75's Avatar
Engine: 5.0L 305
thanks for the great information.....
Old Sep 14, 2012 | 05:14 AM
ThreeOhFive's Avatar
Car: BMW 330i ///M Sport
Engine: M54 DOHC I6
Transmission: 5 speed
Axle/Gears: Stock
Out of curiosity, if you take a 305 RS, throw 3.42's in, 25-2800 stall, and a shift kit, with basic bolt ons such as exhaust and open element, would it be reasonably quick? All that can be done quite cheap.
I had a 1992 RS as my first car, TBI and auto with the 2.73's. It was decently quick, or so it felt, until I got stomped by a 200k mile Grand Am GT, and an old high mileage 350 Tahoe.
I have always wondered what some gears and a tranny would do in these cars. $400 buys you a used rear end and stall, installing both is a cake walk. Is it really that easy to make a respectably quick car, or is the LO3's cam going to make it fall flat on its face?
Old Sep 17, 2012 | 12:27 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
What you describe above I would consider the basics and is almost the blue print that a lot of us are using.
Ive done most of what you describe(I don't have headers but do have the rest in 3in.) with the timing also bumped to 4*
Its hard to measure apples and oranges so the best comparison I can think of would be what you started with compared to what you have now with whats been modified on the car. Personally I consider my car “much” quicker off the line compared to what it was and it will put you back into the seat enough to lock the seat belts. It gets it when I want it to with barking the tires from 1st to 2nd and chirping them from 2nd to third. It is really all I need for my DD.
For the OP,
Tune up, then bump the timing to around 4* as suggested above. Mine is set there and I get away with running a mid grade fuel,(89)
Old Sep 17, 2012 | 09:32 PM
Bulldog75's Avatar
Engine: 5.0L 305
THANKS FOR IN THE INPUT
Old Sep 18, 2012 | 06:16 AM
ex-x-fire's Avatar
Your most likely running alittle lean w/ that open air cleaner (alot more air), you need to be able to adjust your fuel pressure, check out the ultimate tbi mods or do the coin trick.
Old Sep 19, 2012 | 11:30 PM
Bulldog75's Avatar
Engine: 5.0L 305
Coin trick?
Old Sep 20, 2012 | 03:45 AM
1badeagle's Avatar
Car: 1984 Formula ws6
Engine: 370 LSX
Transmission: 4L80E with a brake and 4500 Stall
Axle/Gears: Moser 9" 4.30 gear
Put a quarter in the fuel pressure regulator so it increases the pressure at the injectors
Old Oct 9, 2012 | 08:47 PM
xstang77's Avatar
ive never heard of this please explain more?
Old Oct 10, 2012 | 06:21 AM
ex-x-fire's Avatar
The quarter is for shimming the pressure regulator spring, it makes the fuel pressure up go up slightly.
Old Oct 10, 2012 | 06:27 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
you could also add a lt1 cam in it for a ltle more hp fairly cheap . i picked mine up for 50 bucks on ebay
Old Oct 14, 2012 | 09:14 AM
bigreed91's Avatar
Car: 1990 camaro rs
Engine: 5.0L 305 tbi
after bumping my fuel pressure up to about 13.5 psi (i believe it was at about 11.5 stock) and adding a tbi spacer my throttle response improved quite a bit. I can't really vouch for a tbi spacer though since i added in conjunction with increasing the fuel pressure but its there. I also have an open element air cleaner and shorty headers so it aint bad off the line.
Old Oct 14, 2012 | 12:26 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
I would check fuel pressure and timing.
db057
Jan 10, 2020 08:55 PM
MartinD
Sep 22, 2015 02:27 PM
amcnellis
Sep 16, 2015 04:16 PM
ULTM8Z
Sep 16, 2015 09:15 AM
Stroopwafel
Sep 11, 2015 06:38 AM
