305 Tbi to 350 vortec swap
Old Jul 2, 2013 | 11:57 PM
Kush Barnes's Avatar
Car: 88 Firebird Formula W/T-Tops
Engine: 5.0 (305)
Hi, I have a 88 firebird formula with a 305 tbi, I bought a 350 vortec out of a 99 Yukon and I plan on doing a swap, I know I will probably need a new intake manifold ( don't know which, if on a budget) , but what else would I need and what problems will I run into? I'm hoping it will bolt right up, what are my chances of that? Any help is appreciated, thanks.
Old Jul 3, 2013 | 12:07 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 305 Tbi to 350 vortec swap
you will need a tbi vortec intake like a edelbrock 3704 or gmpp 12496821. You will also need to install 55#hr injectors and have a prom programed .Changing the ecm from the 1228063 to the 122746 would be a good upgrade as well.
Old Jul 3, 2013 | 09:33 AM
Ronny's Avatar
2912 for Vortec http://www.edelbrock.com/automotive_...ictor-sb.shtml
Old Jul 3, 2013 | 09:42 AM
Engine: Lb9
Transmission: M20
Oops
Old Jul 3, 2013 | 10:07 AM
RS FOREVER's Avatar
Car: 1988 RS Camaro
Engine: 305 & 350
Transmission: 5 speed
ok guys i need some ideas. ok so i have a 1988 305 tbi 5 speed in wich i changed the stock exaust to headers with 3" pipes all the way back and now when i wanna put my foot to the floor it seems hesitate in 5th gear. i have also removed poultion pump crap. i guess i wanna know if messed somthing up or if i need to get more air down the intake because i opened up the exaust. friend said to check the egr valve haven't yet just wanna see what other people say
Old Jul 3, 2013 | 10:14 AM
Ronny's Avatar
7.4L TB from truck
Old Jul 3, 2013 | 10:38 AM
RS FOREVER's Avatar
Car: 1988 RS Camaro
Engine: 305 & 350
Originally Posted by Ronny
7.4L TB from truck
305 5.0L camaro
Old Jul 3, 2013 | 11:26 AM
Ronny's Avatar
Swap out the current TB for a 7.4L unit.
Old Jul 3, 2013 | 02:10 PM
gregl316's Avatar
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
I just got done doing that swap and it wasn't as easy as it should be. Start with reading the sticky about putting a 350 in place of the 305. There is alot to do if you want to keep the TBI. It isn't cheep that is to do it right. The guys on this form have walked me through it and answered all my questions.
Good Luck
Old Jul 3, 2013 | 07:20 PM
Engine: 5.0 (305)
Thanks !! I appreciate it!!
Old Jul 5, 2013 | 01:32 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
That's incorrect - you'll need 62 lb-Hr rated injectors from 5.7L (350) truck. 55 lb-Hr injectors were used on 5.0L (305) engines. Stock Vortec long block is excellent foundation for 350 TBI swap.
//RF
Old Jul 9, 2013 | 08:32 PM
gregl316's Avatar
Kush
This is a great place for info but... pay attention to who you take advice from. The guys that help me most have been around the block and are nominally supreme members. If it wasn't for these guys I would have never gotten it done. Read the sticky in the section about what you need to do the swap. Then decide if you want to do it, I am done except the finish tune and it is the most expensive car I've done.
Greg
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
apo_bailon15
Mar 28, 2016 05:20 AM
Tonyy_z
Aug 12, 2015 07:20 AM
92purpz28
Aug 11, 2015 02:30 PM
