How do i adjust my idle?
Car: 1987 Camaro Z28
Engine: Carbed 355
Transmission: Borg Warner T56
Axle/Gears: 4th gen 10 bolt 3:73 Richmond gears
I want to adjust my idle on my car, it is idling around 800 rpms right now, i want it down to like 500 rpms so it has the lope from the radical cam that i put in it. i know it is more than just adjusting the idle screw, because the computer will correct that, How do i adjust it so it stays? its a TBI, 350
Car: 1988 Trans Am GTA
Transmission: TH-7004R
Re: How do i adjust my idle?
it should be just the idle screw, because the computer cant correct that because its not fuel injection. unless you have a computer controlled throttle but i doubt it.
Engine: Carbed 355
im pretty sure mine is computer controlled. its got a buncha wires going to it. but it is the factory throttle body
Car: 91 RS convertible
Engine: 330 hp vortec 350. TBI
Transmission: 5 Speed
Axle/Gears: 3.73 Moiser 12 bolt/Wilwood disc's
The computer does it. If you install a cam you will need to burn a chip and at that time you can change the idle.
Engine: Carbed 355
there is a way to change it though. like turn the key to accessory and jumper two connectors under the drivers side dash, where that plug in thing is near the center console, i just dont know which connectors to connect, thats what im looking for, i did it before, but i forget which ones to use
Car: 86 iroc, 02 v6 camaro
Engine: 350 HSR, 3800 V6
Transmission: T56, WCT5
Axle/Gears: 9in 4.11 posi, 3.23 LSD
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
You could take a look at where the base timing is set at. If theres room for some play back it down a tiny bit. There is a procedure to see and adjust your base timing so if you don't know it ask.
Also if you have the choice use a gun that will tell you revolutions per min.
Pull one plug wire. Simple, easy, effective. Don't expect the catalyst to be happy about a rough idle.
Engine: Carbed 355
i have a performance computer chip, made to the current specs of my car.
Engine: TBI,5.0
Just so you know adjusting your timing is a fairly common practice. It’s usually advanced to get a little bit better throttle response. If yours is at"0*"Than I would not go any lower than that.
Also, have you even tried adjusting your throttle stop screw? If not than I would do that first. Make a mental note of how far you turn the screw so you can turn it back to it soriginal setting if needed. When I say turn the screw I mean just a tiny bit.My stop screw takes a Torx style driver (star shaped).If you don't have one I suggest you pick up an inexpensive set similar to these. Either this style or the folding set. Not the bits that fit on to a driver. My concern would be having one get stuck inside and coming off of the driver.
This set is $8.99 at HarborFreight.
Car: check
Engine: check
Transmission: check
Now unplug the 4-wire connector to the IAC on the right side of the TBI unit.
Turn key off and remove the A/B jumper.
The engine idle speed is now under control the of the TBI unit's idle stop screw....
RBob.
Engine: Carbed 355
Jumper pins A & B together in the ALDL connector. Do a key-on, engine-off and wait 30-seconds as you walk around to the engine compartment.
RBob.
RBob.
unfortunately that is the only way. with a new cam you would want a new tune anyways.
