iac reset, can it go wrong?
Car: have a 92 camaro rs...in pieces
Engine: none now...probably 383 stroker
Transmission: none yet
Axle/Gears: none
Short and sweet. Did a rebuild. Engine would idle around 650/700 once warmed up. Kinda seemed like a possible miss or something. Anyways. I bumped idle speed via the screw that was originally plugged. Been messing with diy prom data logging. Chose to try and reset the idle speed/IAC via the writeup here on TGO. Not liking what its doing. Tried a different way, somewhat similar to TGO writeup but slight differences in instructions. Either way I don't like whats goin on and not sure if its a byproduct of me trying this IAC reset. First thing. Once warmed up idle is like 1000 in park. Drop to drive or reverse and idle drops to like 650ish but climbs back up to like 1000ish. If I drop outta gear into neutral or park RPM'S shoot up to 1800ish and really slowly come back down to 1000ish. Doesnt seem right. When I follow reset procedure I set the idle around 600ish. Does whats goin on sound normal? Plus my BLM and especially my IAC counts seem odd.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: iac reset, can it go wrong?
Did you try setting it like this
Reset the IAC valve pintle position by performing the following.
- Depress the accelerator pedal slightly.
- Start the engine and run for 5 seconds.
- Turn the ignition switch to the OFF position for 10 seconds.
- Restart the engine and check for proper idle operation.
That's it.
Also if you mess with the idle control screw than I believe you must adjust the TPS .(Throttle Position Sensor) maybe someone can verify that.
That's it.
Axle/Gears: none
I have not...
I set it this way.. https://www.thirdgen.org/tpimod2 followed by this way... http://www.gmcmidwestclassics.org/We...0the%20TBI.pdf
I have a tendency to over analyze.
As stated before. Initially bumped just RPM via the throttle stop screw. Then I started to think that in doing this without resetting the IAC my readings might be skewed. So I followed the TGO method. Didn't like what it was doing with my RPM's so I assumed maybe I reset it wrong. Tried again using the PDF stated method (slight variations). Either way right now I know it's wrong. BLM's are 128 across the board and IAC counts 1. Don't think that's right.
I will try the method you stated. Thanks
Car: check
Engine: check
Transmission: check
To set the IAC, warm up the engine and with no other loads on it set the idle stop screw so that the steps are between 5 and 10.
If you want to raise the idle speed it should be done in the PROM.
Unless the proper IAC parameters are changed the ECM will only control the idle once at 195 - 200*F.
If pins A & B on the ALDL connector have the 10K resistor between them, the ECM will target a higher idle speed.
RBob.
RBob.
Axle/Gears: none
RBob. Just to clarify. Do I need to use the reset procedure (or any steps in the reset procedure like disconnect IAC) in conjunction with your suggested method or just warm up, set steps between 5 -10 and be done with it?
Idle speed seems like it needs to be higher, some mods. Guess I'll bump in PROM.
Engine temps never exceed 190.
As far as the rpms.. so if I have my aldl cable plugged in (switch on resistor) it will automatically raise rpms vs not connected?
Thanks.
Thanks.
Car: check
Engine: check
Transmission: check
That could be an issue, it is calibration dependent. Has to do with the IAC step table versus kick down steps. See the IAC Logic write up in the DIY_PROM Tuning Guide Book sticky.
RBob.
Axle/Gears: none
That's it. Do this after you increase the idle speed in the PROM.
If the resistor is in place the ECM will target a higher idle RPM. No need for the resistor to be used when data logging the '8746 ECM.
Makes me wonder how guys are running 180 stats.. Maybe thats addressed in the IAC logic sticky you suggested
I enter CL at 155dF.
Axle/Gears: none
I run a 180dF therm. Today temps were 45-50dF environment. I ran 189 on Xway at 70 mph. At 75dF I see 190. At 85dF I see 195. Coolant temps are determined by more than just a therm(radiator capacity, air flow, coolant, load).
The steps from 166 through 298 are all listed as 65. So my understanding is that no matter whether the temp is 180, 190 or 220 the steps are the same... Unless there are other tables to be considered on top of the step vs temp table.
Car: check
Engine: check
Transmission: check
Note that Ronny is running an EBL Flash ECM. The IAC logic is completely different then the '8746 stuff. And much better.
> I assume this "IAC step table versus kick down steps" in my
> prom is "IAC steps vs Enigne temp"?
Most likely, but there is another parameter that it is related too:
LD527: FCB 65 ; Kickdown steps
This is covered in the IAC Logic write up, at the very end.
RBob.
RBob.
Axle/Gears: none
This is borderline turning into PROM discussion and maybe should continue in my thread in the DIYROM section. Either way.... I tried searching and either I missed it or couldn't seem to find an answer... What would you label this as? (---->LD527: FCB 65)<----- Would this be considered an address, code, hex? Other question, I cant seem to find a way to search for (LD527: FCB 65) in tunerpro unless i just don't know how. This is your post from the IAC logic... Where is this code from? How is the ECM read in this format? Sorry if it's a repeat question but I couldn't find an answer. THANKS
FYI, have reverted the IDLE screw back to where I believe it was. No more rpm's hanging.
Code:
Code: *============================================== * IAC MOTOR POSIT vs COOLANT * (IN STEPS) ASDZ, 5.7L V8 TYPE $42 ECM * * * TBL = STEPS *============================================== ORG $05F5 ; ; STEPS ; Deg c Deg f ;--------------------------------- LD5F5 FCB 24 ; HOT HOT LD5F6 FCB 24 ; 136.0 277 LD5F7 FCB 24 ; 107.0 225 LD5F8 FCB 24 ; 91.0 196 LD5F9 FCB 24 ; 80.0 176 LD5FA FCB 24 ; 71.0 160 LD5FB FCB 24 ; 63.0 145 LD5FC FCB 24 ; 56.0 133 LD5FD FCB 40 ; 49.3 121 LD5FE FCB 50 ; 43.3 110 LD5FF FCB 65 ; 37.0 99 LD600 FCB 80 ; 30.5 87 LD601 FCB 90 ; 23.5 74 LD602 FCB 100 ; 15.5 60 LD603 FCB 110 ; 6.0 43 LD604 FCB 120 ; -8.5 17 LD605 FCB 145 ; COLD COLD *==============================================
Car: check
Engine: check
Transmission: check
$527
The dollar sign is to designate that address as a hex value.
Code:
IIRC, there is a patch method demo thread in the DIY_PROM Tuning Guide sticky that further explains this stuff.
RBob.
Axle/Gears: none
Thank you... As always, RBob, you the man.
....and thank you again. I understand nothing from the readings yet but I'll keep reading until that light bulb in my head lights.
I have no 527 physical address (unless the "7" is translated through hex with a letter like "A" or "B") but instead I have a value of 538 (IAC - Max throttle follower steps)
Axle/Gears: none
IAC throttle follower is a different table than the one RBob refered to(coolant)
Must be there. Used the search function in TP? Maybe listed under RPM vs coolant temp? For instance if coolant is 20dF you can command a higher RPM during warm up?
Car: check
Engine: check
Transmission: check
Then the parameter doesn't exist in the XDF file. This is not unusual. Here it is in the hex editor of Tuner Pro (CTRL+H). Changed it so that it View's as decimal. Also note the values in the steps vs. coolant table.
RBob.
RBob.
Axle/Gears: none
Steps in the table are not much different at normal operating temps in the pic you posted as compared to my table...
So then should I look into adding it?
Axle/Gears: none
So I went ahead and added it. Not sure if I did it right or not. Used a $42 mask as a template. (see pic). Questions....
1) I used same parameters from the $42 and applied to $61. Will this be okay? (note pic)
2) Is the $42 (IAC Position vs Temp) similar to the $61 (IAC Steps vs Engine Temp)? As in with me adding the IAC kickdown to my $61 is the IAC steps vs temp table fine (will new kickdown parameter recognize/work with it) or do I also have to add the $42 IAC position vs temp table and eliminate the $61 IAC steps vs temp? Hope this is a clear question.
3) Depending on the answer to my #2 question.. If just the new kickdown parameter is fine and no other changes necessary, if you note the pic the $42 kickdown is 25 and IAC position is different from my $61 kickdown of 4 and Steps table. Should I change the kickdown in the $61 to 25 and adjust the Steps vs temp to mimic the $42 IAC positon table?
Thanks,
ROB
Thanks,
ROB
Car: check
Engine: check
Transmission: check
In the $61 XDF, need to change the address of the kick down steps. It isn't in the same location as the $42 mask. See the editor entry of "Address (Hex)", change the address to "0x527"
RBob.
RBob.
Axle/Gears: none
Thanks RBob. Address changed. Pic posted.
The fact that a parameter as "kickdown steps" was not included in the XDF makes me question/curious how many other parameters are lacking/not shown.
1) So in following the IAC LOGIC thread, if you note the pic, my steps at 166F+ are 65 and so are the kickdown steps. So the ECM as you stated in the IAC LOGIC "attempts to control the high idle rpm once steps are below kickdown value". So with the kickdown at 65 does that mean that the ECM will not attempt to control the high idle rpm at all?
2) I assume the "IAC" values (steps) are the same values seen when datalogging (IAC count)? If I remember correctly a higher "IAC" count corresponds to something like a vacuum leak, so you'd basically want lower IAC counts? So would I wanna change my steps in the "IAC vs coolant"?
Or am I just totally confused right now?
Car: check
Engine: check
Transmission: check
The P4 and SFI-6 systems have a reduced XDF along with a full XDF to help in this regard.
The 65 kick down and 65 in the table is likely OK, it will control the idle at that point. If you are concerned about it, make the kick down steps 66.
That will allow the ECM to more quickly obtain the proper idle RPM.
On a side note, check the IAC steps at key-on, engine-off. See if it stays at the park position or if it moves according to the engine CTS. The '7747 cranks at the park position, the '8746 may or may not.
No, just over thinking it a bit.
RBob.
