crossfire 1.6 rocker arm upgrade
Old Mar 29, 2014 | 08:41 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
What 1.6 ratio rocker arms work great for the 83 crossfire injection 305 with stock head and camshaft ? Where can I get Pontiac valve covers?
Old Mar 31, 2014 | 04:10 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: crossfire 1.6 rocker arm upgrade
I don't know the crossfire LU5? heads, but mainly the stock 3d gen heads use self aligning rockers on a 3/8 in. stud. You will probably need self-aligning rockers, narrow body or not will probably not matter if you have perimeter valve covers.
I have 1.5 Scorpion roller rockers on my DIY 360, I know they also make 1.6 roller rockers http://www.scorpioncheckout.com/Sear...lts.asp?Cat=54
Old Mar 31, 2014 | 04:48 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Crossfire used either 416 or 601s and perimeter bolt valve covers.
Old Mar 31, 2014 | 04:49 PM
KITT1983's Avatar
Will that work with a flat tappet cam
Old Mar 31, 2014 | 05:09 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Sure will, just make sure that you get non self aligning rockers on the older perimeter bolt valve cover heads.
Old Mar 31, 2014 | 05:48 PM
thomas1976's Avatar
Car: 91 Trans am
Looks like Fast did his homework
Found a NSA/SA rockers related tread https://www.thirdgen.org/forums/tech...-arm-self.html
Old Mar 31, 2014 | 09:40 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Learn something new everyday. I never had run across those early 081 heads. I wonder if the early 083 heads were the same way.
Old Apr 26, 2014 | 06:01 PM
KITT1983's Avatar
What style heads does a 1983 305 CFI have ?
Old May 4, 2014 | 05:53 AM
thomas1976's Avatar
Car: 91 Trans am
According to this and other post https://www.thirdgen.org/forums/tech...-arm-self.html prior to 1987 use non self aligning rockers.
Can always check and verify under the valve covers.
Old May 4, 2014 | 07:27 PM
KITT1983's Avatar
Yeah there are not self aligning rocker arms on factory 83 CFI 305s. But I want to upgrade to 1.6 ratio self aligning rocker arms
Old May 5, 2014 | 03:18 PM
thomas1976's Avatar
Car: 91 Trans am
Then why are you looking in to self aligning rockers?
Old May 5, 2014 | 05:22 PM
KITT1983's Avatar
because i want self aligning rockers
Old May 6, 2014 | 05:18 PM
thomas1976's Avatar
Car: 91 Trans am
Was wondering because generally, guide plates with not self aligning rocker arms is supposed to be better.
Old May 6, 2014 | 11:04 PM
steveo_'s Avatar
common wisdom is that you run SA rockers OR guide plates, not both.
if you want SA, just dump the guide plates... i assume that's your plan?
but that's dumb too, since NSA (guideplates, no tabs on the rockers) yeilds a much more stable valvetrain at high rpm.
although i do know one "rebel" that's run chinese made SA aluminum rockers with a guideplate setup on a nos monster for many race seasons pulling low 9s, and the valvetrain is the only thing that hasn't broken.... so... i guess it depends...
Old Jul 24, 2014 | 08:00 AM
KITT1983's Avatar
Does milage on the motor matter ? Will this kill my motor
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
