whats a decent water pump
Old Dec 28, 2001 | 01:00 AM
killer305's Avatar
im looking into getting waterpump for my cmaaro and was wondering if you guys could give me some ideas, and or reviews or the pump you have
thanks
Old Dec 28, 2001 | 08:26 AM
scauffiel's Avatar
Stewart pumps - real good price and real good performance. Check www.summitracing.com for pricing/ordering...
Steve
Old Dec 28, 2001 | 09:14 AM
FRMULA's Avatar
Want to sav a lb or two then get an aluminum one.
Want to to save a few pounds and free up some horses, then get an electric one.
Othwerwise the stock pump works just fine.
Old Dec 28, 2001 | 09:19 AM
fast_broker's Avatar
I agree. Stock pumps work just fine unless you have some cooling issues, like clogging radiator, scale on inside of block, restricted air opening to radiator, no/small electric and/or direct fan, etc...
Old Dec 28, 2001 | 09:22 AM
bbtaz97's Avatar
Car: 91 RS
Engine: 350tpi comming soon!
Transmission: fixed the 700r4 again!
i would say to go with stewert water pumps... good quility and good prices..
Old Dec 28, 2001 | 10:58 AM
JRoy91RS's Avatar
Car: 91 RS Convertible
Engine: 355
Axle/Gears: 2.73 peg leg
Electric pumps should only be used for drag apps. Otherwise you'll drain your battery or fry your alternator if you drive around all day with an electric pump.
Old Dec 28, 2001 | 11:19 AM
Nah. Those pumps don't drain that much. Not any more than a nasty stereo and/or a nice set of driving lights. They just are not made to run that long. ie, not industrial-use motors on them. Only really made for short operations, as for street cruising and drag racing.
Old Dec 28, 2001 | 12:44 PM
killer305's Avatar
i couldnt find any sterwarts pumps at summit, do you know where else i can get one, are they avaliably in polished case. also what about the edelbrock pump, i know they are expensive, but are they worth it
Old Dec 28, 2001 | 12:49 PM
bbtaz97's Avatar
Car: 91 RS
http://www.stewartcomponents.com/
heres the link for there page.. and yes you can get polished finished ones.. check the siter out for more info.
Old Dec 28, 2001 | 12:57 PM
They are worth their weight in Gold if you need one. If you don't need it, they are a waste of money... Rather akin to an unecessary ignition upgrade or 1-3/4" tube headers when you only really need 1-5/8" tube headers. If you are not running hot (210+ all the time) and/or do not have a mondo engine combo, you won't see much additional cooling effect. IN fact, the coolant can move so fast with Stewarts at higher rpms that turbulence/cavitation in the coolant passages can cause local hot-spots, overheating and cracked heads.
They are GREAT for use in vehicles with the accessory pulleys that slow down the water pump, BTW, and run at low rpm in OD, still.
Old Dec 28, 2001 | 01:05 PM
killer305's Avatar
i just checked out there site and i found a posished aluminmun for 250$ who are they compaired tothe edelbrock victor, i think there the same price, but my catalogs are in the other room. 2 things, i have heavely modded 305 everything from msd probuilt, to crane cam so a waterpump is just to go with the pakage and to give it that extra nice look. im thinking im going to but a waterpump, underdrive pullies, and stainless steel hoses with my christmas $ so my engive bay will look that much nicer.
Old Dec 28, 2001 | 01:08 PM
Cool. Do it.
Old Dec 28, 2001 | 01:43 PM
bbtaz97's Avatar
Car: 91 RS
as far as comparing them to the edelbrock pump.. heres somr figures that i found when i was doing this same research..
Stewart pumps have a 1 year guarantee Edelbrock® pumps have no advertised guarantee.
Stewart Stage 1 part number 12105 for Chevrolet small block compared to the Edelbrock® pump under identical conditions: Flow in GPM
(gallons per minute)
RPM Edelbrock® Stewart Stage 1
1000 17 18
1500 25 32
2000 34 42
2500 42 55
3000 51 65
3500 59 77
4000 68 90
4500 76 101
5000 85 112
5500 93 122
6000 102 132
6500 110 138
7000 119 148
7500 127 157
8000 139 158
Old Dec 28, 2001 | 01:50 PM
One thing I bet you are not considering is parasitic loss from the extra work being done. The extra oomph that the water pump uses to flow that water will lead to lower rear-wheel torque/hp readings, as will a fan that doesn't flex properly at high rpms. So, unless you need the extra flow to cool something, you don;t need the pump. Yeah, it sure is shiny, though, can't beat that!!!
Just a reminder.
Old Dec 29, 2001 | 07:23 AM
scauffiel's Avatar
That's not necessarily true; depending on the cut of the wheel you can have a more efficient pump without an increase in parasitic loss. A comparison would be a submarine's propellor. The US's subs have a much more efficient prop which gives better thrust, takes less power to drive, and is quieter than the Soviet/Chinese variant.
Just my two cents,
Steve
Old Dec 29, 2001 | 09:52 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Another Stewart Components water pump recommendation here. I have their MP (Machine Polished) version. Too bad they no longer offer it. It wasn't as big a price jump as going to the hand polished one. Don't forget to get their high performance thermostat as well. Or just get a Robertshaw one and drill three 3/16 diameter holes in it. That's what they do. I made the mistake of forgetting to order it along with the water pump and had to pay extra shipping (nearly as much as the thermostat cost) to get it. Good luck, Lon.
Old Dec 29, 2001 | 10:24 AM
steve8586iroc's Avatar
Killer, whats the airfoil thinggy do on a tbi set up?
Steve
Old Dec 29, 2001 | 12:04 PM
killer305's Avatar
yeah but i would be getting underdrive pullies as well so would it componsate for the flow, and besides i thought a colder engine was better than a warmer one, second i just got a new thermostat so would i still have to get theres, and steveiroc its actually an airflow enhancer i got from www.cfm-tech.com, it replaces the stock restrictive rin around the tbi, and is also higher, so if you wanted one and had a stock hood you couldnt get one. i know i called it an "air-foil" but i still havent changed it
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
