LT1 Cam swap
Old Jan 10, 2002 | 10:13 PM
88IROCZJG's Avatar
Car: 1988 IROC-Z
Engine: stock L03
Transmission: auto
LT1 Cam swap
I have read about guys taking the cam out of an LT1 motor and swapping it into there TBI car. Will I need anything other than the camshaft to make it work? Should I be looking for a specific year or anything like that? How much HP increase should I expect from swapping cams? Will it change the tone of my exhaust much? Anybody got an LT1 cam for sale? Sorry I'm asking so many questions, just curious. Just wanna say thanks in advance.
Old Jan 11, 2002 | 01:35 AM
V8Astro Captain's Avatar
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I'd get new valve springs just in case. Call Summit, they can set you up with the right ones.
Old Jan 13, 2002 | 11:12 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
I installed a new true roller timing chain while I was at it from Summit. I re-used my old springs, but new ones are a good idea.
Old Jan 15, 2002 | 08:42 PM
Buck268's Avatar
My engine has about 40K on it, is it really worth it to change timing chain/gear when doin a cam swap?
Old Jan 16, 2002 | 12:46 AM
BahamutRS's Avatar
If you have the cash, you might as well. Otherwise don't worry about it.
Old Jan 16, 2002 | 02:52 PM
Buck268's Avatar
If I put in a used LT1 camshaft, do I need to use assebly lube? (or what ever it is). If so, how many miles b4 I should change oil. If not, any 'special' lube proceedures to make sure valvetrain is oiled up? I will be swapping this spring (maybe early summer), and while my dad is expereinced with cars, he has never done a cam swap. So I am trying to find ALL info I can.
Old Jan 20, 2002 | 02:27 PM
NTChrist's Avatar
I just got off the phone with a Summit sales guy, after ordering the $42.95 set of K-Motion valve springs.
The Summit guy was telling me that the springs wouldn't work very well, because roller cams need more spring pressure than flat tappet.
Is this true? Are these springs going to work?
Old Jan 20, 2002 | 02:33 PM
Tas's Avatar
Tas
I think those are the ones Shane B. had lots of problems with. Try emailing or aol IMing him.
Old Jan 20, 2002 | 03:50 PM
ShaneBuss's Avatar
I actually had problems with the valvesprings that come in the VORTEC heads.. I had like .520 lift and they just wouldnt hold up ;-)
If i was you i would get the LS6 valve springs.
I ended up going with kmotion valve springs and they were great, but i went with the top of the line ones... not the $40 springs.. i cant remember the part #
Old Jan 20, 2002 | 08:02 PM
NTChrist's Avatar
Thanks for the input, Tas, Shane B. They're kind of already ordered, so I don't have a lot of choices.
NJSPEEDER was the one who recommended them, so if NJ's got any advice concerning K-motion and LT1 cams, I'm all ears....
1984HO
Mar 19, 2021 11:59 AM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
Cameeeero
Sep 18, 2015 04:00 PM
dbrochard
Fabrication
16
Aug 19, 2015 06:21 PM
