how much difference you think im gonna notice?
Old Jan 19, 2002 | 11:09 AM
TBI305Camaro's Avatar
ok i have a 305 TBI with 101k miles on it. it has the stock coil, cap, and rotor...well i just ordered a 53,000 hypertech coil, cap, and rotor i already have brand new accell wires and bousch platinum plugs...how much better you think my cars gonna run with this stuff? lately it seems like when i get paid 3500 rpm it kinda hesitates alittle...im thinking the coil is shot.
Old Jan 19, 2002 | 12:12 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I thought the Hypertech kit was an HEI vacuum advance system.
They do have a system for our cars, but it's a 45K voltage coil.
If you ordered the one for the vacuum advance, and the internal coil, then it's not gonna work with the stock ECM, or clear the firewall for that matter.
Part #4052 is the wrong one.
#4054 is the right one.
AJ
Old Jan 19, 2002 | 01:10 PM
i ordered 4054 says itll fit 87-93 camaro/firebird/caprice 305/35o TBI
Old Jan 19, 2002 | 02:44 PM
91Bird305's Avatar
Car: 1991 Pontiac Firebird
Engine: 3.8
Axle/Gears: Dana 60
Well it depends. IF your iginition right now runs pretty rough then ur gonna notice a HUGE difference. But if ur igintion runs pretty good right now, u will only notice a slight difference. Either way ur gonna notice something and its worth the upgrade because it works its hardest when u have it at WOT.
Old Jan 19, 2002 | 10:50 PM
i figure the stock rotor has to be shot by now having that many miles on it and its never been replaced...plus cars seems to have alittle more trouble starting than it used to hopefully the coil will help that to i also noticed that by removing my AC and smog deleting the pulleys that it makes my car run alot smoother
chazman
Aug 28, 2018 03:25 PM
InfinityShade
Feb 21, 2016 01:29 PM
RedLeader289
Jan 22, 2016 03:05 PM
DJanes97
Sep 1, 2015 02:55 PM
tmellott89
Aug 16, 2015 02:58 PM
