anybody ever see a hood scoop plug for a formula?
Car: C1500
I'm going to make a cold air setup like the one in the '87 hotrod magazine article. If I could find, or make a plug for the hood scoop for when it rains or snows this would be great.
Car: C1500
DUMB DUMB DUMB Why would anyone cut a hole in a cowl hood?! Totally stupid and a waste of good sheet metal. After it's done it will look unprofessional.
Try an open element filter and remove the block off plate from the cowl. You can find a older TA in a bone yard which had cross fire injection to get the screen for the cowl.
Other nicer options are:
VFN 4" cowl hood
HAWKS Ram Air Hood
RAM Air box
Dual Snorkel Air Filter housing
VFN 4" cowl hood
HAWKS Ram Air Hood
RAM Air box
Car: C1500
Yeah, why would they. WTF. It doesn't say to cut a hole in the hood.
I re-read it.. my bad. The hole is cut in the aluminum sheet that attaches to the underside of the cowl... Then the filter lid seal against the aluminum... AHA!!
I would try this and USE K&N's new filter top for even more air flow.. This should work pretty good on my 383. Then I'll compare this to the "Ram Air Box" I have, and to just an Open element.
1992 Trans Am
May 10, 2023 07:19 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
ElPaleterro85
Aug 13, 2015 03:49 PM
