da** spark plug..
Old Feb 7, 2002 | 08:46 PM
CamaroEFI's Avatar
da** spark plug..
somebody tell me how to get to the first spark plug on the right side of the L03 engine..that plug is really a pain in the a**
Old Feb 7, 2002 | 09:10 PM
deadtrend1's Avatar
right side meaning passenger or drivers side, either way of looking at it? I just regapped mine and i found it easier under the car, couple times you gotta go above the car to take the boot off. the front ones you get from the top. Pull off the boot, and take a 5/8 plug socket or deep socket. Use a breaker bar on the socket wrench if you got to, and pray that they arent cross threaded if its that hard to get out.
~Tim
Old Feb 7, 2002 | 09:20 PM
Chuck!'s Avatar
Car: 91 Camaro Z28
Engine: LS7
Transmission: M12/T56
Axle/Gears: 3.79
I got all mine from the bottom. Then there were two of us to do wires and they took about 10 minutes. Plugs took about 3 hours total though
Old Feb 8, 2002 | 11:17 PM
TBI305Camaro's Avatar
it only took me 30 min to get my plugs out and in from underneath the car on my back i didnt think it was that bad...not fun but not bad
Old Feb 9, 2002 | 12:58 AM
HrdRockA4305's Avatar
Its not so bad from under the car. Just work by feel and not by sight (preferably on a cold motor!)
Old Feb 9, 2002 | 01:46 AM
Jza's Avatar
Jza
I get all eight from underneath. One comes out pretty easily from up top, though, for a quick plug read.
Old Feb 9, 2002 | 11:29 AM
Joel Geerling's Avatar
Car: 91 Formula
Engine: 305 TBI
A good formula for making plug-changing faster on a third gen: remove your AIR stuff, replace your manifolds with non-AIR headers, and replace the stock air duct/cleaner with an open element. If you leave the A/C in, you may still need to go under the car for the one plug back by the heat/a/c stuff (and maybe loosen your psgr header!), but you'll save all that tissue on your arm!
Seriously, though, good luck with that plug - it's not impossible, just a PITA, esp. with the AIR pipes scraping your arm if you're above... I never thought of this before, but if you have a g/f or other acquaintance with skinny forearms, bribe them to do it!
Old Feb 13, 2002 | 09:21 AM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
or do what i do, just gut everything that doesnt make power...smog equipment, windshield wiper tank, air conditioning....
Old Feb 13, 2002 | 10:31 AM
FRMULA's Avatar
Remove the driveshaft, radiator, upper and lower hoses. Attach a cherry picker the engine, remove the motor mount thru-bolts. Remove the engine, replace plugs.
Istallation is the reverse.
Well doesn't EVERYONE do it this way??
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
