cam question
Old Feb 10, 2002 | 07:46 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
cam question
hey guys i have a 305 TBI in my 89 formula 5spd. it is a hyd. roller engine and my question is if i wunted to put just a hyd. non roller cam in how would i go about this? would i just change the lifter and thats it. also i am doin this cause i heard a 305 with the crane cams 2050 compu cam in it and it is nice a lopey and i love it. but its not a roller cam. does any1 know of a good lopey cam i coudl put in and not mess up my comp and retain my roller setup. thanks
Old Feb 10, 2002 | 08:05 PM
NJ SPEEDER's Avatar
are you interested in a sweet sounding idle or power?
that is basically teh decision you are asking about. the flat tappet set up woudl also require a new set of pushrods, longer sinc ethe lifters are physically smaller.
if you are interested in what is probly the best 305 cam that woudl create a little bit of a lope at idle you are gonna hafta pay though. trick flow, yes the head people, have a couple of grinds available. they are pretty sweet looking, but theyare pricy, around $280, but model tfs-31402000(summit part number). lift is .452/.465 with a dur of 214/220 at .050. it has a lobe seperation of only 110 degrees, this will require a chip, but you will get a lot of combustion pressure and a nice lopey idle.
later
tim
Old Feb 10, 2002 | 08:12 PM
Tas's Avatar
Tas
I think a LT1 B-body cam has that seperation if I remember right. Might need 1.6 rockers to get that lift though.
Old Feb 11, 2002 | 03:19 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
I ran the 2050 in my 92 truck for 4 years. Had a lifter trash the cam so I converted over and put the LT1 in. The LT1 cam made the truck pull much harder than the 2050 and didn't throw the computer into fits with the "Lopey" idle. The idle really wasn't that lopey put the idle was jumpy due to the lobe separation. I would recommend sticking with the roller cam and if you want lopey go with a LT4 hot cam on 1.5 rockers instead of the 1.6's. That will keep your lift down to a useable level.
Old Feb 11, 2002 | 03:33 PM
Car: 89 Formula
Engine: Carbed 5.7
i thought the hot cam was to much for a 305? also were can i get just an lt4 cam new
Old Feb 11, 2002 | 06:04 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i have a 91 305 tbi bird, when i bought my cam i compared crane to slp...i found slp was the better of the two........you have to remember slp works on our cars primarily so they can put a little more time into developement,crane works on everything......my cam is part number 51002 duration at .050 is 206/212 seperation is 112......havent put it in yet tho
Old Feb 11, 2002 | 07:01 PM
wasp's Avatar
lift .480/.487 3 degree advance built in
Old Feb 11, 2002 | 07:18 PM
Car: 89 Formula
Engine: Carbed 5.7
thats way to much lift for a 305
Old Feb 11, 2002 | 07:50 PM
wasp's Avatar
nah with afr heads it will be nice
Old Feb 11, 2002 | 07:54 PM
wasp's Avatar
maybe the techs at slp dont know what theyre doin, not sure why they would make and sell firehawks consistently if that was the case http://www.slponline.com/view_produc...RTNUMBER=51002
Old Feb 11, 2002 | 08:20 PM
Car: 89 Formula
Engine: Carbed 5.7
true but 340 bucks for a cam is steep. u can prob get just about the same cam froma diff compalny for cheaper. bhut anyways let me know how it performs. and i do give u props for not usin the lt1 cam that every1 is obsessed with. wut the deal with puttin a stock cam in your car. thats why they all run 15's lol good luck man
Old Feb 11, 2002 | 08:34 PM
wasp's Avatar
true but then again.i spent 1500 on my tranny and 1500 on my rear so 340 for a cam is no biggie.........i really wanted lingenfelter heads but they are 3000 a set...so ill go with afr they are 1500.............."how fast ya wana go? well how much money ya got?" i understand some people especially you young guys dont have the money to spend so ya gota be thrifty but theres and old saying...ya get what ya pay for.............
beastin91rs
Oct 9, 2015 07:38 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
