1.5 Roller TIP rockers self aligning work on a Thirdgen?
Old Feb 26, 2002 | 12:25 AM
manuel's Avatar
Anyone has any idea if 1.5 roller tip self-aligning rocker arms work with this setup:
305 TBI engine
LT1 cam
305 TPI heads
Old Feb 26, 2002 | 12:28 AM
Tas's Avatar
Tas
yes
Old Feb 26, 2002 | 12:44 PM
manuel's Avatar
Thanks Tas!
A friend is selling me a set of Comp Cams self-aligning 1.5 roller tip rocker arms for $50.
I have no idea if they would work. Thanks.
Old Feb 26, 2002 | 02:43 PM
Audiman's Avatar
Comp Cams # CCA-1417-16 3/8" stud 265-400 c.i. 1.52 Ratio check it out in Summit. There for 1987-97 centerbolt heads.:lala:
Attached Thumbnails 1.5 Roller TIP rockers  self aligning work on a Thirdgen?-little-intake.jpg
Old Feb 26, 2002 | 02:58 PM
manuel's Avatar
Center bolt heads? What is that?
Are you suggesting vortec heads?
Thanks, i'm more confused now.
let me clarify...
I want to use 305 TPI heads on my LO3. The heads will be rebuilt, ported and polished. I was wondering if you'll could help if the 1.5 roller tip rocker arms will work for the 305TPI heads...
Thanks!
Old Feb 26, 2002 | 03:49 PM
86Z28TPI's Avatar
"Center bolt" heads have the valve cover bolts down the center and are 1987 - 92 3rd gen. Non-Center bolt heads are 86 and earlier 3rd gen. I have the Comp Cams 1.52 MAGNUM roller tip rockers in my '86. Piece o' cake.
Old Feb 26, 2002 | 04:07 PM
manuel's Avatar
Not to get all emotional but, thanks I apreciate your input.
So, I have center bolt heads. I understand now. It all makes sense.
Now I just have to HOPE that my friend won't sell me the wrong kind, because all I know is that they're:
CompCams-
1.5 roller tip
self-aligning rocker arms...
Old Feb 26, 2002 | 05:42 PM
NTChrist's Avatar
It's only the centrebolt that require S/A rocker arms. Normal SBC rockers will work as long as you use guideplates, too. I don't know how hard it is to add guideplates to centrebolt heads, tho.
Anyways, yes, those rockers will work.
Terrell351
Jun 13, 2021 01:13 PM
midge54
Dec 27, 2019 04:14 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
BrianI
Aug 9, 2015 11:52 AM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
