Engine Pictures Needed
Old Apr 18, 2002 | 01:37 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
I need someone with to take a picture of their engine around the AC and power steering pump. I am building a new 305 engine but I think I am missing some of the brackets that hold the power steering pump on. Can someone post a picture that shows the AC and power steeing pump and how they bolt up?
Old Apr 19, 2002 | 10:33 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Anybody????
Old Apr 19, 2002 | 10:38 AM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I can get a pic later tonite when I get home of the power steering, but not the AC, it ain't there no more.
Old Apr 19, 2002 | 01:51 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Thanks Mark, that is what I need most. If anyone else has a picture of theirs I would appreciate it. The power steering is what I think I am missing the brackets for. Most of the AC is together. Mark, when you take the picture, try to get one that shows the mounting brackets.
Old Apr 19, 2002 | 02:05 PM
redbird_400's Avatar
Car: 89 Formula Firebird
Engine: 305 - Demon 525
You might try the apperance and detailing boards. Bet you can get more replies there.
Old Apr 19, 2002 | 07:06 PM
Car: 99 Formula
Axle/Gears: 342
Here's the pics.
Old Apr 19, 2002 | 07:07 PM
Car: 99 Formula
Axle/Gears: 342
another
Old Apr 19, 2002 | 07:08 PM
Car: 99 Formula
Axle/Gears: 342
Last one, hope these help..
Old Apr 19, 2002 | 07:38 PM
Are those real braded hoses or the sleves?
Old Apr 19, 2002 | 07:59 PM
Car: 99 Formula
Axle/Gears: 342
Sleeves, you can tell with the radiator hose, cause it's just a bit small for the hose.
Old Apr 19, 2002 | 08:24 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Thanks Mark. That helped a lot. Now I know which bracket that I am missing. Is it possible to get a picture of where the steering pump mounts at the bottom. Thanks again.
Old Apr 19, 2002 | 08:31 PM
Car: 99 Formula
Axle/Gears: 342
It's dark out now, but I'll try and see what I can do, I'm about to go out and start sanding/polishing my last wheel, thank G0D it's almost over.
Now that I think of it, I don't think there is a bottom mounting bracket or anything, but I'll double check.
Old Apr 22, 2002 | 12:07 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Is there anyone else that can post pictures of their powersteering and AC pumps? I need to see the back and near the bottom of the PS pump. I thought it mounted to the engine block or water pump down at the bottom.
Old Apr 23, 2002 | 12:35 AM
SSRacer's Avatar
you are right there is a curved bracket that goes from the front of the block (right next to the timing cover) and up the back of the PS pump and attaches to another bracket that bolts to the front 2 exhaust studs, I will try to get pics, I just went through the same thing, even with a second car to copy it was a pain to piece together the 4 bracket puzzle. I go take some pics and post...give me an hour or so...
Old Apr 23, 2002 | 04:06 AM
SSRacer's Avatar
the pics
Can't seem to post multiple pics so here is 1 and I combine the rest
Old Apr 23, 2002 | 04:12 AM
SSRacer's Avatar
More Pics
Here is some other views
Old Apr 23, 2002 | 09:54 AM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Thanks SSRacer and Mark. Those helped. I found that I was missing one of the brackets. I got it this morning and got everything together.
Old Apr 24, 2002 | 03:54 AM
KiLLJ0Y
Guest
Posts: n/a
Hey Mark... did you always have a fan on the front of your water pump?? mine had an electric.. anyways... i was wondering something.
my electric fan died.. so i bought Duel Flex-a-lite fans from summit. Do you think i sould add a fan on the water pump and use the Duel fans as pushers on the front? or just use the duel set up as pullers?
Old Apr 24, 2002 | 04:56 AM
ChrisFormula355's Avatar
Car: Junk
Engine: Junk with nitrous
Transmission: Junk with gears
Originally posted by Mark A Shields
another
HOLY CRAP! you're still running a solid fan?!?? you realize thats an assload of near free horsepower there if you picked up a junkyard electric fan.
Frozer!!!
Jan 19, 2024 04:55 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
IROCZ1989
Jan 24, 2016 03:55 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
