Do I need carbon canister
Old Apr 30, 2002 | 05:46 AM
89blackbird's Avatar
I just bought a cold air intake which mounts where the carbon canister is. Do I need the carbon canister? Can I take it off without getting codes?
Old Apr 30, 2002 | 01:55 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
You won't get codes, but you need some way to vent the fuel tank without getting fumes. Can't just cap off the vent line.
Old Apr 30, 2002 | 02:21 PM
Damon's Avatar
There is a weatherpack plug (2-wire) on one of the valves on top of the charcoal canister. This is so the computer can control when the canister "purge" happens. If it's not plugged in I beleive you will get a check engine light. So..... I would say that the canister does not need to be there, but the plug needs to plug into the purge solenoid or the ECM will know there's something wrong. Not sure about this, but I believe so.
But it is not otherwise required for the engine to run correctly.
Old Apr 30, 2002 | 02:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
89, is that the SLP piece? I thought it came with enough hose to relocate the charcoal can.
Old Apr 30, 2002 | 02:52 PM
wasp's Avatar
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
i also asked this question when i ran an air hose thru the flat metal that the canister sits on, slp said leave it there and also leave the purge valve connected as well..............i removed em to work then just reconnected em.............the purge vlave is that black plastic ball under the fender well that looks like the ball in a toilet tank
Old Apr 30, 2002 | 06:25 PM
It is an SLP set up that I bought used. I have no directions at all. I think I can relocate the canister on the same side just in towards the engine more if I make some brackets.???
Old Apr 30, 2002 | 08:25 PM
wasp's Avatar
yeah you can move it where ever you want just gota hook it back up thats all, i moved mine over a bit, if you notice theres a hole next to the horn that if you make a bit bigger is perfect for running a hose thru
Old May 1, 2002 | 03:44 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Its not real important. If you want to remove it, jsut plug the vacuum line going to it, and take the vapor line and secure it somewhere away from any flame in the engine bay. You dont want a flame going down the vapor line to the gas tank.
grngryoutmyway
Oct 18, 2016 05:48 PM
Quzyle
Oct 15, 2015 03:35 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
reactor60
Sep 22, 2015 01:44 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
