MAF sensor plug broken, won't stay connected. ARGH!
Old May 5, 2002 | 01:52 AM
tizzdizz's Avatar
Hey guys, i just got through putting on a homemade CAI, and somehow in the process, the plug that goes into the MAF sensor got broken. I'm talking about the housing around the prongs that the wire plugs onto. Its not just the clip, but the entire housing is broken off, and the prongs are totally exposed. Because of this, the plug won't stay on, and my MAF keeps getting disconnected. Any ideas on a cheap way to fix this, besides getting an entire new MAF sensor?
Old May 5, 2002 | 02:06 AM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Duct tape.....epoxy.......Cyanocrylic.....fiberglass.....other than that....hmmmm solder wires directly I don't think there is aky kind of professional fix for that....
Old May 5, 2002 | 02:20 AM
tizzdizz's Avatar
thats kinda what i was thinking. I mean the plug goes on, if there were some way to just secure it on there, i could just splice in another type of connector.
would it be a terrible idea to solder the wires to the prongs and then put in some different connector somewhere else on the wire? I think we may have pigtails at work (kragen) that i could get to work. ugh, I just don't want to think about it I'll look at it in the morning.
Old May 5, 2002 | 03:21 AM
JoelOl75's Avatar
Car: 88 Firebird WS6
I'm not sure what stores are around you, but A&A, Key Parts, and Pep Boys usually have these connectors in stock, ready to solder/splice in.
Otherwise, check the Help section, or cut a good one off a junker.
Old May 5, 2002 | 03:38 AM
tizzdizz's Avatar
thanks. For some reason i never think junkyards. someone always has to remind me. now i just gotta find one around here.
Old May 5, 2002 | 02:34 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
If you search this Tech forum for "MAF Connector", you'll find a message where I gave out the part #s for both the 3 pin and 5 pin f-body MAF sensors (from Motormite).
Old May 5, 2002 | 05:08 PM
tizzdizz's Avatar
its not really the connector i need, the plug thats on the sensor. I hate to replace the wholesensor just because of some stupid broken plug. I can get that connector through work for $38 (bah thats kragen for you) but I'm gonna try soldering.
Old May 5, 2002 | 08:51 PM
tizzdizz's Avatar
So how bad am I messing up my stuff everytime i drive w/o a MAF sensor working? I mean it runs and drives ok, just idles rough and dies if i don't keep the RPMs up. I gotta wait til tomorrow to go to the junkyard and try to find another MAF sensor, so if I have to drive it will I be ok for the day?
Old May 5, 2002 | 09:40 PM
breathment's Avatar
I think its just screwing up or gas milage and performance, nothing too bad.. my friend does it all the time in his 2.8L just runs funny
Old May 6, 2002 | 01:51 PM
85wilrocu's Avatar
It will mess with your ecm, which in the long runs mess everything up!
Old May 6, 2002 | 03:37 PM
breathment's Avatar
it can't do any permanent damage... it will just cause you not to have good performance or drivability..
Old May 6, 2002 | 07:26 PM
rezinn's Avatar
It will not mess up your ecm.
Old May 6, 2002 | 08:24 PM
tizzdizz's Avatar
Ok. Now its really broken. The thin wire inside the sensor got broken. I dont konw whether i just did it or if it's been that way, but I'm gonna need a new sensor, unless there's some way to bypass it, at least for now.
Anyone got an extra MAF sensor they wanna kick down?
Old May 7, 2002 | 11:08 AM
85wilrocu's Avatar
Don't mean to start a little flame ,but what do you think happens when the car doesn't have good performance? The ECM
Old May 7, 2002 | 02:15 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
well, your MAF is officially FUBAR. Time for a Wells.
World Discounts
(800) 288-6728
Part # SU-145
Price $166.45
LIFETIME WARRANTY!!! They even carry 'em in stock!!!
*this info was pilfered from somebody's sig, but it's where I bought mine and it came very quickly.
Old May 7, 2002 | 02:39 PM
Jim85IROC's Avatar
I don't think I follow you chief. You can drive around for 2 years without an MAF and it's not going to harm the computer in any way.
Old May 7, 2002 | 04:42 PM
85wilrocu's Avatar
Your ECM recieves codes from all the sensors in your car, after it gathers them all up then it tells the certains parts in the engine, like more gas, more air, etc. The maf sensor tells the ecm the amount of air. Well anyways i hope i don't look like an a$$, well hopefully someone can explain it better!
Old May 8, 2002 | 09:53 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
The original poster said "mess with", not "mess up". It won't hurt the ECM. But it will send its little silicon brain into logic ****-fits.
Logan Bryant
Aug 27, 2015 11:52 AM
mdtoren
Aug 23, 2015 12:52 PM
perZ
Aug 21, 2015 05:51 PM
mdtoren
Aug 16, 2015 05:45 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
